LoRa® Packet Logger
The LoRa® Packet Logger extension records and manages all uplink and downlink LoRa packets with configurable retention periods and health monitoring. It provides a reliable local data source for network analysis, performance monitoring, and troubleshooting.
This extension is only compatible with WisGateOS 2 2.2.15 and later.
Install the LoRa® Packet Logger Extension
Configure the LoRa® Packet Logger Extension
- To access the LoRa® Packet Logger extension, click Launch.
Figure 1: Extensions tab- In Storage Duration, select how long to keep the LoRa logs. The configuration saves automatically after selection.
Figure 1: Set storage duration-
OFF
7 Days
15 Days
30 Days
- When the status shows Currently recording packet logs to CSV file, the logger is active. Log files will appear under Log File Management, named as
lora-packets-YYYY-MM-DD.csv.
Figure 1: Recoding Packet LogsManage Packet Logs
- In Log File Management, check the box log files to select them.
Figure 1: Manage Packet Logs- Click Download to save the selected files to your local device, or Delete to remove them from the gateway.
To download or delete a single file, click the corresponding
or
icon under the Actions column.
Viewing CSV Files
Open the downloaded CSV file to view the recorded packet logs.
Figure 1: Check LogsThe downloaded CSV file contains the following columns:
| Field Name | Description |
| Time | Local time when the packet was received or transmitted by the gateway. |
| FType | Frame type and direction. |
| Freq | Center frequency (MHz) at which the packet was transmitted or received. |
| RSSI | Received Signal Strength Indicator (dBm); values closer to 0 indicate stronger signals. |
| SNR | Signal-to-Noise Ratio (dB), reflecting signal quality. |
| TxPwr | Transmit power (dBm); - means not recorded for uplink packets. |
| CRC | CRC check result (CRC_OK means passed, UNKNOWN means no CRC or undetectable). |
| Mod | Modulation type, e.g., LORA for LoRa modulation. |
| CR | Coding rate, e.g., CR_4/5. |
| DataRate | Data rate, e.g., SF10BW125 means spreading factor SF10 and bandwidth 125 kHz. |
| FCnt | Frame counter. |
| AirTime | Airtime (ms), the duration the packet occupies the radio channel. |
| DevAddr | LoRaWAN device address (hexadecimal). |
| FPort | LoRaWAN port number. |
| Size | Payload size in bytes. |
| MacCmd | MAC command(s), if present. |
| Data | Payload in Base64 encoding. |
