index
Select a development environment supported by the installed WisBlock Core.
Arduino IDE
Install the RAKwireless Arduino BSP to add supported WisBlock Core boards and examples to Arduino IDE.
The RAKwireless BSP package and supported board definitions are available in the RAKwireless Arduino BSP Repository.
After the BSP is installed, compatible WisBlock examples are available from the Arduino IDE examples menu.
PlatformIO
Install the RAKwireless board support package by following the PlatformIO BSP Installation Guide.
PlatformIO examples for supported WisBlock modules are available in the WisBlock PlatformIO Repository.
WisBlock Example Code
Example code for WisBlock Core and WisBlock Modules is available in the WisBlock Examples Repository. Examples in the common folder are compatible with the RAK4631, RAK11200, and RAK11310 WisBlock Core modules.
