index
Attach a WisConnector
WisBlock Power modules are installed in the dedicated Power Slot of compatible WisBlock Base Boards. Secure the installed module using compatible screws to ensure a reliable mechanical connection.
Figure 1: RAK19013 mounting connection to WisBlock Base moduleDetach a WisConnector
The procedure for disassembling any type of WisBlock module is the same.
- First, remove the screws.
Figure 1: Removing screws from the WisBlock module- Once the screws are removed, check the module's silkscreen to find the correct location for applying force.
Figure 1: Detach silkscreen on the WisBlock module-
Apply even force to the marked connector area on the module PCB to detach the module from the Base Board.
Figure 1: Applying even forces on the proper location of a WisBlock module
