index
The Diagnostics section provides access to system logs and built-in network utilities that help monitor gateway behavior, verify connectivity, and troubleshoot network or device issues.
System Log
You can view real-time system logs directly from the Web UI under Diagnostics > System Log. Enable Auto Refresh to continuously stream new log entries as the gateway operates.
If you need deeper analysis or remote access to logs, the gateway supports multiple ways to view and retrieve them:
Access System Logs
This comprehensive guide provides an overview of all available methods to access system logs on RAK LoRaWAN® gateways.
Guide Link: How to Access System Logs on RAK LoRaWAN® Gateways
Network Utilities
The Network Utilities section provides diagnostic tools to test and validate network connectivity. Access them via Diagnostics > Network Utilities in the Web UI.
- Ping – Test the reachability of a host and measure network latency.
- Trace – Display the route packets take to reach a destination and identify possible routing issues.
- Nslookup – Verify DNS resolution by checking domain name mappings to IP addresses.
These tools are useful for troubleshooting communication problems, confirming Internet access, or diagnosing server connectivity.
For detailed usage instructions, refer to the WisGateOS 2 User Manual > Diagnostics > Network Utilities.
