index
This section provides tools and metrics to help you monitor gateway performance and LoRaWAN® communication activity after setup.
Gateway Overview
Access the Gateway Overview from Dashboard > Overview to monitor your gateway’s real-time operating status.
This page provides key system information such as model, EUI, firmware version, uptime, and network interfaces, as well as critical indicators like SD card health, CPU and memory usage, and GPS signal status.
For detailed parameter descriptions, see the WisGateOS 2 User Manual > Overview.
For more details on specific monitoring features, see the dedicated guides for SD Card Health Monitoring and GPS Signal Status.
The SD card health indicator displays the current read/write status and storage integrity.
It helps identify early signs of degradation, ensuring reliable log storage and data buffering.
Guide Link: Sd Card Health Check Monitoring
GPS Signal Status
The GPS section displays the number of satellites in view and the signal quality.
A stable GPS lock ensures accurate timestamping and precise location data for network synchronization.
Guide Link: Check GPS Status and Signal Quality on RAK LoRaWAN® Gateways
LoRaWAN Statistics
Access the LoRa Statistics from Dashboard > LoRa Statistics to monitor your gateway’s LoRaWAN® traffic and signal qualitys. It displays packet counts (uplink/downlink), active devices, channel usage, and signal metrics (RSSI/SNR), allowing you to analyze network behavior in real time.
For detailed data definitions, refer to the WisGateOS 2 User Manual > LoRa Statistics.
