Water pH Sensor LoRaWAN Network Server Guide
Figure 1: LoRaWAN Application ScenariosLoRaWAN Application
Cloud Network Server Setup
The cloud network server deployment scenario involves connecting the gateway and devices to third-party cloud network servers. This setup integrates visualization applications to manage real-time Water pH data.
For this example, you will use the TTNv3 cloud server and RAK7289V2 WisGate Edge Lite 2 to demonstrate how to connect the RAK business gateway to a cloud server.
- Register the Gateway
- Register an account and log in to the TTN v3 website. If you already have a TTN account, you can log in with your The Things ID credentials.
The Gateway EUI serves as a distinct 64-bit extended identifier for the gateway, accessible from the Overview page of the gateway management platform or from the label situated behind the gateway.
Figure 1: Configure the gateway frequencyGenerate Token
- To generate a key file, navigate to API keys from the Overview page of the registered gateway, then click on Add API key.
Figure 1: Add API keys- In the Add API key page, set the Name field, tick of the checkboxes shown in Figure 8, then click Create API key.
Figure 1: Copy and save the API KeyRegister the Gateway
- Navigate back to the gateway management platform Web UI. Click on the left navigation bar to access the LoRa > Configuration tab. Complete the following settings and save them.
- Server URL:
8887 - Authentication Mode: TLS server & Client Token Authentication
- Trust (CA Certificate): Download the certificate
Figure 1: Select Create An Application- Click + Create application to initiate the creation of a node.
Figure 1: Enter the application ID- Click on the +Register end device button to add a new end device to the application.
Figure 1: Add the end device- Set the parameters of the end device, as shown in Figure 16.
- After completing the settings, return to the WisToolBox app, and click JOIN NETWORK to send the end device network access request.
Figure 1: Sending end device network join request- As shown in Figure 18, the Sensor Hub has successfully joined the TTNv3 network server.
Create Datacake Integration
- In the TTN console, navigate to Integrations on the sidebar, proceed to the Webhooks section, and then click +Add Webhooks to set up an integration.
Figure 1: Select the Datacake template- Generate an API key for webhook authentication on Datacake. To get started, register a Datacake account, and then log in.
Figure 1: Log in to the Datacake IoT platform- Navigate to the Datacake workspace. Select Members on the sidebar, and switch to the API Users tab, then click the Add API User button.
Figure 1: Create the Datacake WebhookAdd Sensor Hub to Datacake
- To add a new device, select Devices in the sidebar and click the +Add Device button.
Figure 1: Add a Device- Choose LoRaWAN from the options and click Next to proceed.
Figure 1: Choose LoRaWAN connectivity- As the Sensor Hub is a new device, there is no pre-existing template. Create a template by clicking New Product, enter the Product Name, and click Next to proceed.
Figure 1: Select the Things Stack V3- In the Step 3 Devices tab, enter the device DEVEUI and NAME fields, and click Next to continue.
Figure 1: Select a subscription plan- The registered devices can now be viewed on the Devices tab.
Figure 1: Registered deviceCreate a Payloader Decoder
Figure 1: Configuration tab
Figure 1: Decoder codeClick to view the example
var decoded = {};
function value(bytes) {
var value = (bytes[1] << 8) | bytes[0];
value = twosComplement (value, 16);
return value;
var offset = 0;
while (offset < bytes.length) {
var channel_id = bytes[offset++];
var channel_type = bytes[offset++];
if (channel_id === 0x15 && channel_type === 0xC1) {
var PH = (bytes[offset++] * 256 + bytes[offset++]) / 100;
decoded.PH = PH.toFixed(1);
} else {
break;
return decoded;
- Displace the menu bar to the +Add Field section and click +Add Field.
Figure 1: Add Field- The Add Field window appears. Fill out the fields shown in Figure 36 to configure the stored data in the device.
Figure 1: Configuration fields- Enter an appropriate name in the Name field.
- The Identifier field will be automatically filled based on the name.
- When an uplink is received, refresh the page, and the CURRENT VALUE field will be updated.
- When completed, it will look the same, as shown in Figure 37.
Figure 1: Successfully added fieldsCreate a Dashboard
- To create a dashboard, toggle the edit mode switch on the Dashboard tab of the device in Datacake.
Figure 1: Turn on the edit mode switch- Click +Add Widget to include a visualization widget.
Figure 1: Select Value to create a new dashboardYou can select various types of widgets to accommodate different data formats.
- In the Title field under the Basics tab, name the widget, for example, PH.
Figure 1: Name the Widget- Under the Data tab, click the Field dropdown arrow, select Water pH, and set the unit to pH.
Figure 1: Setting Parameters- Under the Gauge tab, select the gauge type and color, set the range of values for the widget, and then click Save.
Figure 1: Set Gauge- When you finish adding the widgets, turn off the edit mode switch to save the edits.
Figure 1: Added WidgetBuilt-In Network Server Setup
- Log in to ThingsBoard. If you don't have an account yet, create one before proceeding.
Figure 1: ThingsBoard Homepage- Navigate to the Integration center > Data converter menu bar to create a data converter for the uplink.
Figure 1: Create a Data Converter- Click on the Add Data Converter icon and choose the Create new converter option.
Figure 1: Create a new Converter- Enter the name of the decoder in the Name field (for example, Uplink decoder), leave the Type field as Uplink, and select the JavaScript option.
Figure 1: Add the decoder code- Edit the decoder code by copying the following code into the edit box. Then, click Add to include the uplink decoder.
/** Decoder **/
// decode payload to string
var payloadStr = decodeToString (payload);
var data = JSON.parse ( payloadStr ).data;
var bytes = atob (data).split('').map(function(c) {
return c.charCodeAt (0);
var values = {};
let i = 0;
while (i < bytes.length) {
var value;
if (channelId === 0x15C1) {
value = (bytes[i + 2] * 256 + bytes[i + 3]) / 100;
i += 4;
values.ph = value;
} else {
break;
var deviceName = 'sensorhub_ph';
var result = {
deviceName: deviceName,
attributes: {
ph: values.ph,},
/** Helper functions **/
return String.fromCharCode.apply (String, payload);
return result;
- Navigate to the Integration Center > Integrations menu and click the Add Integration icon to add the MQTT integration.
Figure 1: Add the MQTT Integration- Enter the name of the integration (for example, MQTT Integration) in the Name field and select MQTT in the Type drop-down menu. Click Next to continue.
Figure 1: Basic Settings- In the Uplink data converter options, click Select existing to choose the previously created decoder (Uplink Decoder), then click Next.
Figure 1: Select the created decoder- In the Downlink data converter interface, no configuration is necessary. Simply click Skip to bypass this setup.
Figure 1: WisGate OS Web Management Platform-
Enter the address
broker.hivemq.comin the Host field, with the port number1883. Click the Add topic filter button to configure the subscription topic:
Figure 1: WisGate OS Web Management Platformapplication/{{ application_name }}/device/{{ device_EUI }}/join
application/{{ application_name }}/device/{{ device_EUI }}/ rx
application/{{ application_name }}/device/{{ device_EUI }}/ tx
application/{{ application_name }}/device/{{ device_EUI }}/ack
application/{{ application_name }}/device/{{ device_EUI }}/status
- application_name: the aapplication ID created in the gateway.
- device_EUI: the device EUI of the end device.
Modify the parameter values corresponding to the topics based on the actual application created and the device used.
Figure 1: WisGate OS Web Management Platform- After configuring the details, click on Add to save and complete the settings.
Figure 1: WisGate OS Web Management PlatformConfigure the Gateway
This section will use RAK7268 V2 WisGate Edge Lite 2 as an example.
- To access the gateway web management platform, refer to the WisGateOS V2 User Manual for details.
Figure 1: WisGate OS Web Management Platform- After successfully logging in, navigate to the LoRa® menu in the left navigation tree. Set the Work mode of the gateway to Built-in network server.
Figure 1: Applications Tab- Configure the following information: Application name, Application Description, and Application Type.
Figure 1: Unified Application Key- After enabling the Auto Add Device option, configure the Application EUI option. The value needs to be consistent with the node value. Once you have verified the application EUI and key, the device will be added automatically to the application.
- Separate Application keys: Each device has its own application key. Add the key when registering the device.
Figure 1: Add Application Key-
Figure 1: End Devices Tab- Click the Add end device button. In the End device information interface, fill in the following information:
- Choosing ABP mode creates two additional fields: Application Session Key and Network Session Key. In this example, you’re using OTAA activation mode.
- Class: Select Class A for the device's operating mode.
- Frame Counter Width: Maintain the default value.
- LoRaWAN MAC Version: The protocol version (V1.0.3) of the node.
Figure 1: Add the device to the device list- In the Adding end devices interface, enter the device EUI in the End Device EUI (main) field and select the Add to End Devices list button. Then click Add end devices to complete adding the end device.
Figure 1: Confirm to add the end device- When finished, you will enter the End devices interface, where you can see the created end device.
Connect Sensor Hub to Built-In Network Server
For specific configuration on how to connect SensorHub to the server, please refer to SensorHub Network Configuration > LoRaWAN Application Scenario. Once completed, the device will join the network. As shown in Figure 69, the end device SensorHub has successfully connected to the gateway's built-in server.
Figure 1: End device SensoHub has been connectedConfigure MQTT Integration
Navigate to the LoRa® > Configuration > Integration Interface Parameters section.
Enable the Enable Integration Interface option and select Generic MQTT as the Integration mode.
broker.hivemq.comthen click Save changes. -
Figure 1: Automatically created decoder device- Click the device, and navigate to the Attributes tab, and check on the node data.
Figure 1: Node data-
To visualize the data, simply select the values you wish to display, then click the Show on widget button.
On the next page, choose the desired widget for your data from the Current bundle drop-down menu. In this example, select Outdoor Environment, and then select the appropriate visualization chart for the Water pH by clicking the slide icon .
Figure 1: Select Widget- After selecting the widget, click Add to dashboard.
By default, the profile does not have a dashboard, so you need to select Create new dashboard and enter a name for the dashboard in the New dashboard title field, for example, SensorHub_ph.
Figure 1: Add data to Dashboard- After setting the name of the dashboard, click the Add button to add more widgets. Alternatively, check the Open dashboard option to automatically open the created dashboard after adding the widget.
Figure 1: Enter the dashboard nameIf the Open dashboard option is not selected, users can still easily view the added widgets via Dashboard groups > All > [Group Name].
Click the Edit mode icon
to set the appropriate name and unit for the Water pH Sensor. -
Click the Edit widget icon
and complete the following setup steps:
- Select the Water pH unit in the Value drop-down menu; in this example, it's pH.
- Click the Apply button to apply the settings.
- Click the exit icon
, and then click the save icon
to save the settings.
- The parameter values will be automatically rounded based on the type of widget selected for the data. If needed, adjust the number of decimal places in the icon edit mode.
- The ThingsBoard visualization dashboard editor allows you to adjust the size and shape of widgets by dragging the edges of the widgets in the Edit mode.
If the above settings are correct, the final visualization widget on the Dashboard should resemble Figure 78.
Figure 1: Dashboard createdNB-IoT/LTE CAT-M1 Application
In the Network Server and Visualization Configuration section, the server in the example has been set as a public MQTT broker: broker.hivemq.com. Refer to the corresponding section for details. Users can also choose other brokers or servers, such as AWS IoT Core (optional), according to actual usage scenarios.
Figure 1: NB-IoT/LTE CAT-M1 application scenarioVisualize Data Through Datacake
In this example, we will utilize Datacake as the visualization platform. Datacake is a versatile IoT platform designed to visualize data from nodes in a user-friendly manner.
Figure 1: Devices Page- Select the API option and click Next to proceed.
Figure 1: Add Devices- Select the preferred subscription plan, then click Add 1 device. For this example, choose Free.
Figure 1: Copy the serial number- Continue scrolling down to the MQTT Configuration option and configure the external MQTT Broker.
- Click +Add new MQTT server and configure the relevant parameters.
Figure 1: Configure the external MQTT Broker- Fill in the relevant information based on the actual server used, then click Test Connection to verify whether Datacake can successfully connect to the MQTT Broker.
Figure 1: Connection established successfully- After successfully adding the MQTT server, click on +Add Uplink Decoder to add a decoder.
Figure 1: Add MQTT Server- A new window will appear, and fill in the fields according to your project.
var decoded = [];
var data = JSON.parse ( payload.replace (/\s*/g,""));
for (var key in data) {
decoded.push (
device: "1ca52561-0252-4d9c-b277-6f684270bfb1",
field: key,
value: data[key]
return decoded;
In the above code, make sure that the parameter serial_number (device: 1ca52561-0252-4d9c-b277-6f684270bfb1) matches the serial number saved locally earlier.
- In the Fields option, click +Add Field to show the monitoring values of the devices. Each device can create a certain number of fields, also known as a data points.
Figure 1: Set the related parameters of the field- Set the necessary parameters of the Fields. For Fields with multiple data points, add them one by one. Once done, click Add Field.
Figure 1: Added sensor monitoring valuesCreate a Dashboard to Visualize Data
- On the device details page, navigate to the Dashboard tab, then toggle on the edit mode switch.
- Click on the + Add Widget button to add a widget for visualizing data.
Figure 1: Open the edit mode- Choose what type of widgets you want to display. For this example, select Value to visualize the Water pH values.
Figure 1: Select and add widgets for visualizing data- Click on the Data tab. Choose the field for visualization from the Field options and set the unit of the field, which is pH in this example.
Figure 1: Select the visualization data field- After configuring the widget, click Save. Once done with the dashboard configuration, turn off the edit mode switch to save the settings.
Figure 1: Water pH data visualization
