WisMesh Pocket Quick Start Guide
WisMesh Pocket is a go-to device for ready-to-use and long-lasting connectivity. Ideal for users seeking a hassle-free Meshtastic node.
For Firmware 1.3 and 2.0 (from November 1, 2022), the WisBlock Base board is autodetected. This device works with the stock firmware.
- All the base boards with RAK4631/RAK4630: -
firmware-rak4631-w.x.yy.zzzzzzz.uf2 - For WisMesh Pocket: DO NOT USE -
Prerequisite
Before going through each and every step on using WisMesh Pocket, make sure to prepare the necessary items listed below:
- WisMesh Pocket
- USB Cable
The WisBlock Core module of the WisMesh Pocket comes pre-flashed with the Meshtastic firmware.
However to connect the device to the Meshtastic network you will have to configure it. Listed below are several applications for the configuration:
The WisMesh Pocket comes fully assembled with an internal battery. However, it is recommended to fully recharge the battery before switching the device on. It supports Li-Ion batteries, 5 V (e.g. from solar panel) supply, integrated user button, battery disconnect switch and a dedicated connector for a 1.3 inches OLED display.
WisMesh Pocket also includes all GPIOs on pin headers, three WisBlock Sensor Slots, one WisBlock IO slot, and an integrated GNSS location chip on the Base Board.
The WisMesh Pocket is based on the WisMesh Base Board, which is specifically designed for the Meshtastic usage. Technical details of the WisMesh Base Board can be found in the WisMesh Base Board documentation.
Battery Connector and Solar Panel (5 V) Connector
The WisMesh Pocket has internal a connector for a Li-Ion battery. In case the battery needs to be changed, double check the polarity of the battery cable. The matching connector for the battery wires is a JST PHR-2 2 mm pitch female.
WisMesh Pocket also has an internal connector for direct 5 V supply or connection of a solar panel. In case this connector is used, make sure to double-check the polarity of the supply cable.
The matching connector for the solar panel wires is an JST ZHR-2 1.5 mm pitch female.
Figure 1: WisMesh Pocket Battery & 5 V/Solar PanelRecharge the Battery
To recharge the device, plug a USB-C cable into the device and connected it to a 5 V 2 A USB wall charger. Recharging the battery via a USB port on your computer is not recommended due to the potential low current output.
Charge the WisMesh Pocket faster by keeping it off with the ON/OFF switch in the off position.
Antenna
The LoRa antenna needs to be plugged into the SMA connector of the WisMesh Pocket. Make sure the connector is screwed in correct and is secured by tightening the connection.
The BLE antenna and GNSS antenna are inside the enclosure and already connected.
Assembling and Disassembling of WisMesh Pocket
If you want to add additional WisBlock modules, you can do so by opening the device and plugging the modules into their sensor or IO slots.
Disassembling
- Unscrew the four screws on the corners of the enclosure with a screwdriver.
Figure 1: WisMesh Pocket Disassembly Enclosure Screws- Open the enclosure carefully, as there are battery cables between the top and bottom part, do not use force to pull the cables. Then separate three IPEX connectors from PCBA.
Figure 1: WisMesh Pocket Disassembly Opening - Disconnect antenna cables- Unscrew four screws that hold the Base Board in the enclosure. Then you can remove the Base Board from the enclosure
Figure 1: WisMesh Pocket Disassembly Base Board removal- Separate the battery cable from the Base Board.
Figure 1: WisMesh Pocket Disassembly Battery disconnectAssembling
- Plug the battery cable into the Base Board.
Figure 1: WisMesh Pocket Assembly Battery connection- Put the Base Board into the enclosure and fix it with four screws.
Figure 1: WisMesh Pocket Assembly Mount Base Board- Plug the IPEX connectors on the sockets on the Base Board. Make sure to connect each antenna to the correct socket, and then close the enclosure.
Figure 1: WisMesh Pocket Assembly Connect antennas- Put the four nuts into the slots on the bottom of the enclosure, then fix the screws.
Figure 1: WisMesh Pocket Assembly Fix enclosureSoftware Setup
The WisMesh Pocket comes pre-flashed with the Meshtastic firmware. If you encounter problems, update the Meshtastic firmware to the latest version.
For the setup of the WisMesh Pocket for the Meshtastic network, follow the configuration guide in the Meshtastic documentation.
