WisMesh Repeater Mini V2 Quick Start Guide
WisMesh Repeater Mini V2 is a solar-powered repeater that comes in a waterproof enclosure with a high-performance built-in antenna, making it deployable anywhere regardless of power availability or weather conditions.
Prerequisite
Before going through each and every step on using WisMesh Repeater Mini, make sure to prepare the necessary items listed below:
The WisBlock Core module of the WisMesh Repeater Mini V2 comes pre-flashed with the Meshtastic firmware.
However, to connect the device to the Meshtastic network, you will have to configure it. The recommended way to configure the WisMesh Repeater Mini V2 is using a mobile phone via a BLE connection with either of these configurations:
Alternatively, the WisMesh Repeater Mini V2 has an USB connector inside. With the USB connection, you can use either of these configurations:
To access the USB port, follow these simple steps:
- Remove the rubber plug on the side of the enclosure, as shown in Figure 1.
Figure 1: Remove the rubber plug- Access the USB port, as shown in Figure 2
Figure 1: Access the USB portProduct Configuration
The WisMesh Repeater Mini V2 comes fully assembled with the battery already connected.
- The WisMesh Repeater Mini V2 is set to deep sleep mode to prevent the internal battery from discharging during transportation.
- To use the WisMesh Repeater Mini V2, connect it to a computer using a USB cable to initiate the automatic wake-up. Without this step, the device will not advertise over BLE, and it cannot be set up.
To recharge the battery, mount the WisMesh Repeater Mini V2 with its solar panel facing direct sunlight, ensuring there is no shadow. Alternatively, you can charge the battery through the USB port.
For more details about the mounting options of the WisMesh Repeater, refer to the WisBlock Unify enclosure mounting accessories.
Antenna
The WisMesh Repeater Mini V2 has an internal BLE antenna and an external LoRa antenna. Make sure that the LoRa antenna is plugged in properly before powering up the unit.
Assembling and Disassembling of WisMesh Repeater Mini V2
It is strongly recommended to keep the WisMesh Repeater Mini V2 closed at all times. If the devices are opened, make sure the assembly of the lid is properly done to avoid water intrusions into the enclosure.
Software Setup
To set up the WisMesh Repeater Mini V2 for the Meshtastic network, follow the Meshtastic configuration guide.
Firmware Upgrade
WisMesh Repeater Mini V2 comes pre-flashed with Meshtastic firmware. If you encounter issues or need to update the firmware, follow the steps below.
If you have a RAK14000 WisBlock E-Ink Display connected, use the firmware specifically built for the E-Ink Display. For all other configurations, use the standard firmware for WisMesh Repeater Mini V2.
- Go to Meshtastic firmware and download the firmware package.
- Extract the package and locate the firmware file specifically built for WisMesh Repeater Mini V2:
- For RAK10728 (WisMesh Repeater Mini V2), use Meshtastic
firmware-rak_wismesh_repeater_mini-w.x.yy.zzzzzz.uf2 - For RAK10729 (WisMesh Repeater Mini V2 HP), use Meshtastic
firmware-rak_wismesh_repeater_mini_hp-w.x.yy.zzzzzz.uf2
- Follow the Guide to flash nRF52 devices to flash the firmware.
Select the firmware specifically built for WisMesh Repeater Mini V2. Do not use the generic RAK4631 firmware file.
