Meshtastic 1W Booster Starter Kit Quick Start Guide
WisMesh 1W Booster Starter Kit is a versatile DIY kit, ideal for DIY enthusiasts who want a hassle-free Meshtastic node. This guide covers the basics for the Meshtastic Starter Kit that are not handled by the Meshtastic documentation.
For detailed instructions how to configure the devices for the Meshtastic network, follow the Meshtastic Getting Started guide. You can also check the Meshtastic Basic Device Setup Guide:
Due to the high power consumption during the 1 W LoRa transmission, the device has to be powered either by a battery or by an external 5 V supply to work correctly. The selection of the power supply is done through a jumper on the RAK13302 module.
Power Selector Jumper
You have multiple options to power the device:
- With jumper set to internal
- USB + Li-Ion battery (3.7 V)
- Solar + Li-Ion battery (3.7 V)
- 5 V through solar connector + Li-Ion battery (3.7 V)
- This setting always requires a battery connected to provide the required power.
- With jumper set to external
- 5 VDC supply with 1.5 A thorough connector on the RAK13302. This will supply the whole setup, Base Board, Core module and 1W transceiver. It will as well charge a battery if connected.
The 3-pin jumper header is to select the supply source for the booster chip.
| Jumper Position | Supply Source |
| IN_5V to 5 V | Supply from WisBlock Base Board Battery |
| EX_5V to 5 V | Supply from Jx connector |
If the supply is through EX_5V, the whole WisBlock Base Board can be supplied through this source.
Figure 1: RAK13302 5 V supply selectionExternal power supply cable connections:
Figure 1: RAK13302 5 V supply selectionPower Supply Path
Figure 1: RAK13302 5 V supply selectionTo ensure you are running the latest version of the Meshtastic firmware, download the latest Meshtastic firmware and upload it to your RAKwireless device to make it compatible with the Meshtastic network.
- All base boards with RAK3401 and the RAK13302 1 W (30 dBm) LoRa module use:
firmware-rak3401-1watt-w.x.yy.zzzzzzz.uf2
Prerequisite
Before going through each and every step on using Meshtastic Starter Kit, make sure to prepare the necessary items listed below:
- One ( 1 ) WisBlock Base Board RAK19007
- One ( 1 ) WisBlock Core Module RAK3401
- One ( 1 ) WisBlock LoRa module RAK13302
- One ( 1 ) Wi-Fi/BLE PCB antenna
- One ( 1 ) 900 MHz LoRa PCB antenna
- One ( 1 ) USB cable
- One ( 1 ) IPEX to SMA cable for LoRa Antenna
- One ( 1 ) SMA Rubber LoRa Antenna
- Two ( 2 ) 5 V supply cable (same as used on WisBlock Audio Amplifier module)
- One ( 1 ) set of screws
The WisBlock Core module of the Meshtastic Starter Kit comes pre-flashed with the Meshtastic firmware. However, to connect the device to the Meshtastic network, it must first be configured using one of several available applications:
RAK3401 Installation on the WisBlock Base Board
The Meshtastic 1W Booster Starter Kit comes with the RAK3401 module already assembled on the WisBlock Base board. The WisBlock Base provides a USB connection for programming the RAK3401. It also provides a power source and various interfaces to RAK3401 so that it can be connected to other WisBlock modules via different module slots.
In case you need to change the RAK3401 or install additional modules, this guide illustrates how the RAK3401 can be connected to RAK19007 WisBlock Base, as shown in Figure 1.
Figure 1: RAK3401 Connection to WisBlock Base RAK19007- The RAK3401 can be assembled on other base boards in the same way.
- Assembly guides for additional modules are available in their respective Quick Start Guides.
Assemble WisBlock Modules
Figure 2 shows how to mount the RAK3401 module onto a WisBlock Base board (RAK19007). Follow the steps in the WisBlock module assembly/disassembly guide to ensure a secure connection. Once mounted, fasten the module with one or more M1.2x3 mm screws, depending on the module type.
Figure 1: RAK3401 Mounting SketchDisassemble WisBlock Modules
- Start by removing the screws.
Figure 1: Removing screws from the WisBlock module- Once the screws are removed, check the silkscreen of the module to find the correct location where force can be applied.
Figure 1: Detaching silkscreen on the WisBlock module- Apply force to the module at the position of the connector, as shown in Figure 5, to detach the module from the baseboard.
Figure 1: Applying even forces on the proper location of a WisBlock moduleLoRa and BLE Antenna
Antennas are an essential part of the Meshtastic Starter Kit. The kit includes the following:
- LoRa Rubber Antenna: A 2 dBi rubber antenna with a SMA connector and an IPEX-to-SMA pigtail cable.
Figure 1: LoRa Rubber AntennaDetailed information about the 2 dBi rubber antennas can be found on the antenna datasheet.
- LoRa PCB Antenna: A compact PCB antenna for LoRa.
Figure 1: LoRa PCB Antenna- Connect the LoRa antenna to the IPEX connector on the RAK13302 LoRa transceiver module.
- Detailed information about the LoRa antennas can be found in the 863-870 MHz antenna datasheet or the 902-928 MHz antenna datasheet.
- BLE PCB Antenna: A PCB antenna for Bluetooth Low Energy that connects directly to the RAK3401.
Figure 1: BLE PCB Antenna- Never power the module without an antenna connected to the IPEX connector. Doing so may damage the RF section of the chip.
- Always ensure the correct antenna is attached when using LoRa or Bluetooth Low Energy transceivers.
Power Supply Setup
Due to the high power consumption of the 1 W transceiver during the LoRa transmission, the device has to be powered either by battery or by an external 5 V supply.
Depending on the selected power supply, make sure the jumper on the RAK13302 is set in the correct position:
| IN_5 V to 5 V | Supply from WisBlock Base Board Battery |
| EX_5 V to 5 V | Supply from Jx connector |
If the supply is through EX_5 V, the whole WisBlock Base Board can be supplied through this source.
Figure 1: RAK13302 5 V supply cableSoftware Setup
- All the base boards with RAK3401 -
The Meshtastic Starter Kits come pre-flashed with the Meshtastic firmware. If you encounter problems, update the Meshtastic firmware to the latest version.
For the setup of the Meshtastic Starter Kit for the Meshtastic network, follow the configuration guide in the Meshtastic documentation.
RAK3401 and WisBlock Base Boards
Detailed information can be found in the documentation for the different modules:
