RAK3172 WisDuo LoRaWAN Module Quick Start Guide
Development Workflow
The RAK3172 supports two development workflows:
- AT Commands for rapid prototyping
- RUI3 API for custom firmware development
- RAK3172 as a Stand-Alone Device Using RUI3
- RAK3172 as a LoRa/LoRaWAN Modem via AT Command
- Connect to The Things Network (TTN)
- Connect with Chirpstack
- LoRa P2P Mode
There are three versions of the RAK3172 available:
- RAK3172 - Base model, using STM32WLE5 with an oscillator, suitable for standard temperature range
- RAK3172-T - Extended temperature module, using STM32WLE5 with a temperature controlled oscillator
- RAK3172-F - Provides an additional 512 kB external flash and uses the STM32WLE5 with a temperature-controlled oscillator
This guide is covering all three variants of the RAK3172.
Before going through the installation guide for the RAK3172 WisDuo LoRaWAN Module, ensure you have prepared the necessary items listed below.
- RAK3172 WisDuo LoRaWAN Module
- Computer
- USB to UART TTL adapter
If you are using Windows 10:
Do NOT install the Arduino IDE from the Microsoft App Store. Instead, install the original Arduino IDE from the Arduino official website. The Arduino app from the Microsoft App Store has problems using third-party Board Support Packages.
- Add RAK3172 as a supported board in Arduino IDE by updating Board Manager URLs in Preferences settings of Arduino IDE with the JSON URL below.
https://raw.githubusercontent.com/RAKWireless/RAKwireless-Arduino-BSP-Index/main/package_rakwireless_com_rui_index.json
After that, add RAKwireless RUI STM32 Boards via the Arduino board manager.
List of Acronyms
| Acronym | Definition |
| LoRa | Long Range |
| OTAA | Over-The-Air-Activation (OTAA) |
| TTN | The Things Network |
| DEVEUI | Device EUI (Extended Unique Identification) |
| APPEUI | Application EUI (Extended Unique Identification) |
| APPKEY | Application Key |
| DEVADDR | Device Address |
| NWKSKEY | Network Session Key |
| APPSKEY | Application Session Key |
| P2P | Point-to-Point |
| MSB | Most Significant Bit |
| LNS | LoRaWAN Network Service |
The RAK3172 requires a few hardware connections before it can work. The minimum requirement is a properly configured power section, reset button, antenna, and USB connection.
Firmware updates are done via UART2 pins. If you connect the module to an external device interfacing with UART2, take extra precautions in your board design to ensure you can still perform firmware updates. Your board design should include a way to disconnect the external device from the RAK3172 UART2 before connecting the module to a PC (via a USB-UART converter) for the firmware update process.
An alternative option to update firmware, aside from UART2, is to use SWD pins (SWCLK and SWDIO). This method requires external tools like ST-LINK and RAKDAP1.
Figure 1: RAK3172 Minimum SchematicEnsure that the antenna is properly connected for a good LoRa signal. Also note that powering the module without an antenna connected to the IPEX connector may damage the chip's RF section.
Figure 1: LoRa AntennaRAK3172 has a module variant with an IPEX connector where you can connect the LoRa antenna, as shown in Figure 3. If your ordered RAK3172 module lacks an IPEX connector, ensure an external antenna connected to the RF pin (Pin 12) of the module.
Figure 1: IPEX Connector of RAK3172 for LoRa AntennaDetailed information about the RAK3172 LoRa antenna can be found on the 863-870 MHz antenna datasheet or the 902-928 MHz antenna datasheet.
When using the LoRa transceiver, ensure that an antenna is always connected. Using the transceiver without an antenna may damage the module.
Software Setup
The default firmware of the RAK3172 is based on RUI3, which allows you to develop your own custom firmware to connect sensors and other peripherals. To develop custom firmware using the Arduino IDE, first add RAKwireless RUI STM32 boards to the Arduino board manager (as discussed in this guide). Then, use RUI3 APIs for your application. You can upload the custom firmware via UART. The RAK3172's AT commands remain available even with custom firmware compiled via RUI3; send AT commands via a UART2 connection.
RAK3172 RUI3 Board Support Package in Arduino IDE
If you don't have an Arduino IDE yet, you can download it on the Arduino official website and follow the installation procedure in the miscellaneous section of this document.
For Windows 10 and up users: If your Arduino IDE is installed from the Microsoft App Store, you need to reinstall your Arduino IDE by getting it from the Arduino official website. The Arduino app from the Microsoft App Store has problems using third-party Board Support Packages.
Once the Arduino IDE is successfully installed, you can configure the IDE to add the RAK3172 to its board selection by following these steps.
Figure 1: Arduino preferences- To add the RAK3172 to your Arduino Boards list, edit the Additional Board Manager URLs. Click the icon, as shown in Figure 5.
Figure 1: Modifying Additional Board Manager URLs- Copy the URL below and paste it into the field, as shown in Figure 6. If other URLs are already present, just add them on the next line. After adding the URL, click OK.
Figure 1: Add additional board manager URLs-
Restart the Arduino IDE.
Open the Boards Manager from the Tools Menu.
Figure 1: Opening Arduino boards manager-
Write
RAKin the search bar, as shown in Figure 8. This will show the available RAKwireless module boards that you can add to your Arduino Board list. -
Click on the area highlighted in blue to select RAKwireless RUI STM32 Boards. Install the latest version of the RAKwireless RUI STM32 Boards by clicking on Install button.
Figure 1: Installing RAKwireless RUI STM32 BoardsConfigure RAK3172 on Boards Manager
- Once the BSP is installed, select Tools > Boards Manager > RAKWireless RUI STM32 Modules > WisDuo RAK3172 Evaluation Board. The RAK3172 Evaluation board uses the RAK3172 WisDuo Module.
Figure 1: Selecting RAK3172 ModuleRAK3172 COM Port on Device Manager
Connect the RAK3172 via UART and check RAK3172 COM Port using Windows Device Manager. Double-click the reset button if the module is not detected.
Figure 1: Device manager ports (COM & LPT)Compile an Example with Arduino LED Breathing
- After completing the steps for adding your RAK3172 to the Arduino IDE, you can now try to run a simple program to test your setup. You need to add two LEDs to the bare minimum schematic of the RAK3172 module, as shown in Figure 11.
Figure 1: RAK3172 with two LEDs-
Launch Arduino IDE and configure WisDuo RAK3172 Evaluation Board on board selection. See Figure 9.
Connect the RAK3172 via UART and check RAK3172 COM Port. See Figure 10.
Open the Tools Menu and select a COM port. COM28 is currently used.
Figure 1: Select COM port- You can see the serial monitor icon and click it to connect to the COM port.
Figure 1: Open Arduino serial monitor- If the connection is successful, you can send AT Commands to RAK3172. For example: To check the RUI version, type
AT+VER=?in the text area, then click on the Send button, as shown in Figure 14.
Figure 1: Send AT command
Figure 1: Arduino serial monitor COM28- Open Arduino_Led_Breathing example code.
Figure 1: Arduino Led Breathing example- Click on the Verify icon to check if you have successfully compiled the example code.
Figure 1: Verify the example code- Click the Upload icon to send the compiled firmware to your RAK3172 module.
The RAK3172 should automatically enter BOOT mode when the firmware is uploaded via Arduino IDE.
If BOOT mode is not initiated, pull to ground the RESET pin twice (or double click the reset button if available) to force BOOT mode.
Figure 1: Upload the example code- If the upload is successful, you will see the Upgrade Complete message.
Figure 1: Device programmed successfully- After device programming is complete, you will see the LEDs blinking.
RAK3172 I/O Pins and Peripherals
This section discusses how to use and access RAK3172 pins using the RUI3 API. It shows basic code examples for digital I/O, analog input, UART, and I2C.
RAK3172 and RAK3172-T
Figure 1: Available Peripherals and Digital I/O pins in RAK3172 moduleRAK3172-F
Figure 1: Available Peripherals and Digital I/O pins in RAK3172-F moduleHow to Use Digital I/O
You can use any of the pins below as a digital pin.
| Pin Name | Alternative Pin Usage | Pin Name | Alternative Pin Usage |
| PA0 | - | PA10 | I2C_SDA / ADC4 |
| PA1 | - | PA15 | ADC5 |
| PA4 | SPI1 NSS | PB2 | ADC3 |
| PA5 | SPI1 SCK | PB3 | ADC1 |
| PA6 | SPI1 MISO | PB4 | ADC2 |
| PA7 | SPI1 MOSI | PB5 | - |
| PA8 | - | PB6 | UART1_TX |
| PA9 | I2C_SCL | PB7 | UART1_RX |
Figure 1: Available Digital I/O pins in RAK3172 moduleRAK3172-F
The RAK3172-F has a compatible pinout but provides additional GPIOs.
| PA0 | - | PB5 | - |
| PA1 | - | PB6 | UART1_TX |
| PA4 | SPI1 NSS | PB7 | UART1_RX |
| PA5 | SPI1 SCK | PB9 | SPI2 NSS |
| PA6 | SPI1 MISO | PB10 | SPI2 SCK |
| PA7 | SPI1 MOSI | PB11 | - |
| PA8 | - | PB13 | - |
| PA9 | - | PB14 | - |
| PA10 | ADC4 | PB15 | - |
| PA11 | I2C_SCL | PC0 | - |
| PA12 | I2C_SDA | PC1 | SPI2 MOSI |
| PA15 | ADC5 | PC2 | SPI2 MISO |
| PB1 | - | PC3 | - |
| PB2 | ADC3 | PC4 | - |
| PB3 | ADC1 | PC5 | - |
| PB4 | ADC2 | PC6 | - |
Figure 1: Available Digital I/O pins in RAK3172-F moduleThe pins listed below must not be used.
| Pin name | Pin Usage |
| PA2 | UART2_TX |
| PA3 | UART2_RX |
| PA13 | SWDIO |
| PA14 | SWCLK |
| PB8 | RAK3172 Internal |
| PB12 | Internal 10k pull-up resistor for RAK3172 high frequency variant (8xx - 9xx Mhz) or pull-down resistor for RAK3172 low frequency variant (4xx Mhz) |
- Use Arduino digitalRead to read the value from a specified Digital I/O pin, either HIGH or LOW.
- Use Arduino digitalWrite to write a HIGH or a LOW value to a Digital I/O pin.
The GPIO Pin Name is the one to be used on the digitalRead and digitalWrite and NOT the pin numbers.
Example code
void setup()
pinMode(PA0, OUTPUT); //Change the P0_04 to any digital pin you want. Also, you can set this to INPUT or OUTPUT
void loop()
digitalWrite(PA0,HIGH); //Change the PA0 to any digital pin you want. Also, you can set this to HIGH or LOW state.
digitalWrite(PA0,LOW); //Change the PA0 to any digital pin you want. Also, you can set this to HIGH or LOW state.
How to Use Analog Input
You can use any of the pins below as Analog Input.
| Analog Port | Pin Name |
| ADC1 | PB3 |
| ADC2 | PB4 |
| ADC3 | PB2 |
| ADC4 | PA10 |
| ADC5 | PA15 |
Use Arduino analogRead to read the value from the specified Analog Input pin.
Figure 1: Available Analog pins in RAK3172RAK3172-F
Figure 1: Available Analog pins in RAK3172-FExample code
#define analogPin PB3
void setup()
Serial.begin(115200);
void loop()
delay(100);
How to Use Serial Interfaces
UART
There are two UART peripherals available on the RAK3172 module. There are also different Serial Operating Modes possible in RUI3, namely Binary Mode, AT Mode, and Custom Mode.
| Serial Port | Serial Instance Assignment | Default Mode |
| UART1 (pins 4, 5) | Serial1 | Custom Mode |
| UART2 (pins 1, 2) | Serial | AT Command |
Figure 1: Available UART pins in RAK3172Example Code
void setup()
Serial1.begin(115200); // use Serial1 for UART1 and Serial for UART2
// you can designate separate baudrate for each.
void loop()
Serial1.println("RAK3172 UART1 TEST!");
Serial.println("RAK3172 UART2 TEST!");
I2C
There is one I2C peripheral available on RAK3172.
| I2C Pin Number | I2C Pin Name |
| PA12 | I2C_SCL |
| PA11 | I2C_SDA |
- Use Arduino Wire library to communicate with I2C devices.
Figure 1: Available I2C pins in RAK3172Example Code
Make sure you have an I2C device connected to specified I2C pins to run the I2C scanner code below:
Click to view the code
#include <Wire.h>
void setup()
Wire.begin();
while (!Serial);
void loop()
byte error, address;
int nDevices;
nDevices = 0;
// the Write.endTransmission to see if
if (error == 0)
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
else
Serial.println("done\n");
The Arduino Serial Monitor shows the I2C device found.
17:29:15.690 -> Scanning...
17:29:15.738 -> I2C device found at address 0x28 !
17:29:15.831 -> done
17:29:15.831 ->
17:29:20.686 -> Scanning...
17:29:20.733 -> I2C device found at address 0x28 !
17:29:20.814 -> done
17:29:20.814 ->
SPI
If your RUI3 project uses SPI, then PA4 to PA7 pins are reserved for RUI3 SPI interface.
Related Hardware for Prototyping
The hardware below can help you evaluate the RAK3172 module more easily before designing your own carrier board or production hardware.
Evaluate the RAK3172 before designing a custom carrier board, with convenient access to power, UART, reset, antenna, and basic I/O connections.
Follow the Arduino IDE and RUI3 examples in this guide without building the minimum hardware circuit, with optional expansion using compatible WisBlock sensors and I/O modules.
PA13 and PA14 pins are reserved for SWD debug interface. Check the Connect to the RAK3172 section.
LoRaWAN Example
This example illustrates how to program RAK3172 module as a stand-alone LoRaWAN end-device via RUI3 Arduino APIs. To use RAK3172 module as a LoRaWAN end-device, it needs to be within reach of a working LoRaWAN gateway registered to a LoRaWAN network server (LNS) or one with a built-in network server.
If you are new to LoRaWAN, here are a few good references about LoRaWAN and gateways:
- LoRaWAN 101
- What is a LoRaWAN Gateway
- How do LoRaWAN Gateways work?
- Things to Consider When Picking A LoRaWAN Gateway
RAKwireless LoRaWAN gateway models like WisGate Edge have built-in network servers. It is also common that the LoRaWAN network server is external or in the cloud. The popular LoRaWAN network server in the cloud that you can use for free (but offers enterprise service, too) is TTN.
To run this example correctly, configure the LoRaWAN parameters and create an OTAA application on your LoRaWAN gateway.
Register the LoRaWAN Gateway on TTNv3 Community Edition
After configuring your gateway, you need to register it in TTNv3:
- Log in to the TTNv3 Network Server with a web browser.
- Navigate to the Console page and click on gateway icon, as shown in Figure 25.
Figure 1: TTNv3 gateway registration and configuration- On General Settings, enter the Gateway ID, Gateway EUI, and Gateway Name. This information is available in your LoRaWAN gateway configuration. Select the Gateway Server address according to the region where the LoRaWAN gateway will be installed.
Figure 1: TTNv3 gateway registration and configuration- Select the Frequency plan for your region (with used by TTN), then click on the Create gateway button. This will add a new gateway to TTNv3.
Figure 1: TTNv3 add new GatewayRegister the Device on TTNv3
The next step is to follow the procedure described in the section TTN OTAA Device Registration.
Upload the LoRaWAN Example to RAK3172
After a successful registration of the RAK3172 device on the LNS, you can now proceed with running the LoRaWAN OTAA demo application example.
Open the example code under RAK WisBlock RUI examples: File -> Examples -> RAK WisBlock RUI examples -> Example -> LoRaWan_OTAA.
Figure 1: OTAA LoRaWAN application example- In the example code, you need to modify the device EUI OTAA_DEVEUI, the application EUI OTAA_APPEUI, and the application key OTAA_APPKEY.
- The OTAA_DEVEUI parameter should match the device EUI registered in your network server. Note that your RAK3172 module has a sticker with a QR code printed on it. You can use the QR code information to configure the OTAA_DEVEUI parameter. The OTAA_DEVEUI format is MSB first.
// OTAA Device EUI MSB
#define OTAA_DEVEUI {0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x04, 0xF1, 0xC0}
- The OTAA_APPEUI parameter. This parameter should also be the same as the APPEUI in the network server you configured.
// OTAA Application EUI MSB
#define OTAA_APPEUI {0x70, 0xB3, 0xD5, 0x7E, 0xD0,0x03, 0xAB, 0xA2}
- Another important parameter to change is the application key, OTAA_APPKEY. This parameter should also be the same as the APPKEY in the network server you configured. The OTAA_APPKEY format is MSB first.
// OTAA Application Key MSB
#define OTAA_APPKEY {0xB4, 0x85, 0x7E, 0xFE, 0x1C, 0xB5, 0x15, 0xEB, 0x44, 0x61, 0x0D, 0x9B, 0x20, 0x6A, 0xF3, 0x3A}
Figure 1: Configuring DEVEUI, APPEUI and APPKEY- Depending on the regional band you selected, you might need to configure the sub-band of your RAK module to match the gateway and LoRaWAN network server. This is especially important for regional bands like US915, AU915, and CN470.
This guide uses the US915 regional band, so you need to update the band in the code as well. In addition, you also need to set up the channel mask (channels 8 to 15 are the most commonly used channels in the US915 band).
if (!api.lorawan.band.set(OTAA_BAND)) {
Serial.printf("LoRaWan OTAA - set band is incorrect! \r\n");
return;
uint16_t maskBuff = 0x0002;
if (!api.lorawan.mask.set(&maskBuff)) {
Serial.printf("LoRaWan OTAA - set mask is incorrect! \r\n");
return;
RAK3172 supports the following regions:
- RAK_REGION_EU433 = 0
- RAK_REGION_CN470 = 1
- RAK_REGION_RU864 = 2
- RAK_REGION_IN865 = 3
- RAK_REGION_EU868 = 4
- RAK_REGION_US915 = 5
- RAK_REGION_AU915 = 6
- RAK_REGION_KR920 = 7
- RAK_REGION_AS923 = 8
- RAK_REGION_AS923-2 = 9
- RAK_REGION_AS923-3 = 10
- RAK_REGION_AS923-4 = 11
Figure 1: Updating to US915 and setting up channel mask-
Ensure you have configured the correct RAK board before uploading the code. See Configure RAK3172 on Boards Manager section.
Also, check RAK3172 COM Port on Device Manager section.
- Open the Tools Menu and select a COM port. COM28 is currently used.
Figure 1: Select COM port- The last step is to upload the code by clicking the Upload icon on Arduino IDE. Note that you should select the correct board and COM port.
Figure 1: Uploading the code- You should now be able to see the console logs using the Arduino IDE's serial monitor. Sometimes the COM port will disconnect, so you may not see the terminal output immediately. You can reconnect the module or try pressing the reset button to see the terminal output.
Figure 1: Arduino serial monitor logs- Check on the LoRaWAN network TTN console logs to see if your device has been successfully joined with the
join-requestandjoin-acceptmessages.
Figure 1: TTN console logThe modified LoRaWAN_OTAA project is available below.
#define OTAA_PERIOD (20000)
LoRaWAN band setting:
RAK_REGION_EU433
RAK_REGION_CN470
RAK_REGION_RU864
RAK_REGION_IN865
RAK_REGION_EU868
RAK_REGION_US915
RAK_REGION_AU915
RAK_REGION_KR920
RAK_REGION_AS923
#define OTAA_BAND (RAK_REGION_US915)
/** Packet buffer for sending */
uint8_t collected_data[64] = { 0 };
void recvCallback(SERVICE_LORA_RECEIVE_T * data)
if (data->BufferSize > 0) {
Serial.println("Something received!");
for (int i = 0; i < data->BufferSize; i++) {
Serial.printf("%x", data->Buffer[i]);
Serial.print("\r\n");
void joinCallback(int32_t status)
Serial.printf("Join status: %d\r\n", status);
void sendCallback(int32_t status)
if (status == 0) {
Serial.println("Successfully sent");
} else {
Serial.println("Sending failed");
void setup()
Serial.begin(115200, RAK_AT_MODE);
Serial.println("RAKwireless LoRaWan OTAA Example");
Serial.println("------------------------------------------------------");
// OTAA Device EUI MSB first
uint8_t node_device_eui[8] = OTAA_DEVEUI;
// OTAA Application EUI MSB first
uint8_t node_app_eui[8] = OTAA_APPEUI;
// OTAA Application Key MSB first
uint8_t node_app_key[16] = OTAA_APPKEY;
if (!api.lorawan.appeui.set(node_app_eui, 8)) {
Serial.printf("LoRaWan OTAA - set application EUI is incorrect! \r\n");
return;
if (!api.lorawan.appkey.set(node_app_key, 16)) {
Serial.printf("LoRaWan OTAA - set application key is incorrect! \r\n");
return;
if (!api.lorawan.deui.set(node_device_eui, 8)) {
Serial.printf("LoRaWan OTAA - set device EUI is incorrect! \r\n");
return;
return;
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan OTAA - set device class is incorrect! \r\n");
return;
if (!api.lorawan.njm.set(RAK_LORA_OTAA)) // Set the network join mode to OTAA
Serial.printf
("LoRaWan OTAA - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.join()) // Join to Gateway
Serial.printf("LoRaWan OTAA - join fail! \r\n");
return;
/** Wait for Join success */
while (api.lorawan.njs.get() == 0) {
Serial.print("Wait for LoRaWAN join...");
api.lorawan.join();
delay(10000);
if (!api.lorawan.adr.set(true)) {
Serial.printf
("LoRaWan OTAA - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(1)) {
Serial.printf("LoRaWan OTAA - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan OTAA - set confirm mode is incorrect! \r\n");
return;
/** Check LoRaWan Status*/
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get()? "ON" : "OFF"); // Check Duty Cycle status
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get()? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
uint8_t assigned_dev_addr[4] = { 0 };
api.lorawan.daddr.get(assigned_dev_addr, 4);
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.printf("Uplink period is %ums\r\n", OTAA_PERIOD);
Serial.println("");
api.lorawan.registerRecvCallback(recvCallback);
api.lorawan.registerJoinCallback(joinCallback);
api.lorawan.registerSendCallback(sendCallback);
void uplink_routine()
/** Payload of Uplink */
uint8_t data_len = 0;
collected_data[data_len++] = (uint8_t) 't';
collected_data[data_len++] = (uint8_t) 'e';
collected_data[data_len++] = (uint8_t) 's';
Serial.println("Data Packet:");
for (int i = 0; i < data_len; i++) {
Serial.printf("0x%02X ", collected_data[i]);
Serial.println("");
/** Send the data package */
if (api.lorawan.send(data_len, (uint8_t *) & collected_data, 2, true, 1)) {
Serial.println("Sending is requested");
} else {
void loop()
static uint64_t last = 0;
static uint64_t elapsed;
if ((elapsed = millis() - last) > OTAA_PERIOD) {
uplink_routine();
last = millis();
//Serial.printf("Try sleep %ums..", OTAA_PERIOD);
api.system.sleep.all(OTAA_PERIOD);
//Serial.println("Wakeup..");
More examples for the RAK3172 can be found in the RUI3-Best-Practices on Github.
AT Command via UART2
The RAK3172 module can be configured using AT commands via the UART2 interface. A USB-to-UART TTL adapter is needed to connect the RAK3172 to your computer's USB port, along with a serial terminal tool. You can use the RAK Serial Port Tool so you can easily send AT commands and view the replies from the console output. The RAK Serial Port Tool commands still use the RUI V2 AT commands by default. You can modify it to use RUI3 AT commands and then save it.
Firmware updates and AT command functionality are done via UART2 pins. If you connect the module to an external host MCU that sends AT commands via UART2, take extra precautions in your board design to ensure you can still perform firmware updates. Your board design should include a way to disconnect the host MCU UART to connect to the RAK3172 UART2 before connecting the module to a PC (via a USB-UART converter) for the firmware update process.
An alternative firmware update method, aside from UART2, is to use SWD pins (SWCLK & SWDIO). This method requires external tools like ST-LINK and RAKDAP1.
- Connect the RAK3172 to the serial port of a general-purpose computer (USB port) using a USB to UART TTL adapter like RAKDAP1, as shown in Figure 35.
Any serial communication tool can be used; but, it is recommended to use the RAK Serial Port Tool.
Configure the serial communication tool by selecting the appropriate port detected by the computer and configure the link as follows:
- Baud Rate: 115200 baud
- Data Bits: 8 bits
- Stop Bits: 1 stop bit
- Parity: NONE
RAK3172 Configuration for LoRaWAN or LoRa P2P
To enable the RAK3172 module as a LoRa P2P module or LoRaWAN end-device, it must be configured by sending AT commands. You can configure the RAK3172 in two ways:
- LoRaWAN End-Device - RAK3172 as LoRaWAN IoT device.
- LoRa P2P - Point-to-point communication between two RAK3172 modules.
Configure RAK3172 as LoRaWAN End-Device
To enable the RAK3172 module as a LoRaWAN end device, a device must first be registered in the LoRaWAN network server. This guide covers both TTN and ChirpStack LoRaWAN network servers and the associated AT commands for the RAK3172.
- TheThingsNetwork Guide - How to log in, register new accounts and create new applications on TTN.
- RAK3172 TTN OTAA Guide - How to add OTAA device on TTN and what AT commands to use on RAK3172 OTAA activation.
- RAK3172 TTN ABP Guide - How to add ABP device on TTN and what AT commands to use on RAK3172 ABP activation.
- Chirpstack Guide - How to create new applications on Chirpstack.
- RAK3172 Chirpstack OTAA Guide - How to add OTAA device to Chirpstack and what AT commands to use on RAK3172 OTAA activation.
- RAK3172 Chirpstack ABP Guide - How to add ABP device on Chirpstack and what AT commands to use on RAK3172 ABP activation.
This section provides a quick tutorial on connecting the RAK3172 module to the TTN platform.
In this guide, you will need a working gateway connected to TTN, or you must be within the coverage of a TTN community network.
Figure 1: RAK3172 EVB in the context of the TTNAs shown in Figure 36, The Things Stack (TTN V3) is an open-source LoRaWAN Network Server suitable for global, geo-distributed public and private deployments, as well as for small local networks. The architecture follows the LoRaWAN Network Reference Model for standards compliance and interoperability. This project is actively maintained by The Things Industries.
The RAK3172 WisDuo Module can be part of this ecosystem as a device, and the objective of this section is to demonstrate how simple it is to send data to The Things Stack using the LoRaWAN protocol. To achieve this, the module must be located within the coverage of a LoRaWAN gateway connected to The Things Stack server.
- The first step is to go to The Things Network and sign up an account shown in Figure 37. Then select a cluster as shown in Figure 39.
Figure 1: Signing up an account in TTN
Figure 1: Selecting Cluster in TTN
Figure 1: Signing up through the Things ID
Figure 1: Creation of an account through the Things ID
Figure 1: Creation of an account through the Things IDYou can use the same login credentials on TTN V2 if you have one. If you do not yet have an account, you need to create one.
- Now that you are logged in to the platform, the next step is to create an application. Click Create an application.
Figure 1: The Things Stack Platform
Figure 1: Creating TTN application for your LoRaWAN devices- To register an application, first input the specific details and necessary information, then click Create application.
Figure 1: Details of the TTN application
Figure 1: Details of the TTN application- If you have no errors in the previous step, you should now be on the application console page. The next step is to add end devices to your TTN application.
LoRaWAN specifications require that each end device be personalized and activated. There are two options for registering devices, depending on the activation mode selected. Activation can be done via Over-the-Air Activation (OTAA) or Activation by Personalization (ABP).
- Go to your application console to register a device. To start adding an OTAA end-device, click + Register end device, as shown in Figure 47.
Figure 1: Register end device- To register the board, click the Enter end device specifics manually.
Figure 1: Enter end device specifics manually- Next step is to set up Frequency plan, compatible LoRaWAN version, and Regional Parameters version supported. Then provide the JoinEUI credentials by entering zeroes into it.
Figure 1: Setting up for your device
Figure 1: Setting up for your device- Then click Show advanced activation, LoRaWAN class and cluster settings. Configure the activation mode by selecting Over the air activation (OTAA) and Additional LoRaWAN class capabilities to class A only. Then click Confirm.
Figure 1: Setting up for your device- Once done, provide the DevEUI credentials of your device into the DevEUI portion. This will automatically generate the specific end-device ID of your board. Click Generate in AppKey tab under Provisioning information section. Then click Register end device.
The AppEUI, DevEUI, and AppKey are hidden in this section as these are unique from a specific device. The DevEUI credential is unique to every RAK3172 device. Also, you should generate your own AppEUI and AppKey credentials for your specific device and application.
The AppEUI is the same as JoinEUI.
Figure 1: Register end device- You should now be able to see the device on the TTN console after you fully register your device, as shown in Figure 58.
The AppEUI, DevEUI, and AppKey are the parameters that you will need to activate your LoRaWAN end-device via OTAA. The AppKey is hidden by default for security reasons, but you can easily show it by clicking the show button. You can also copy the parameters quickly using the copy button.
The three OTAA parameters on the TTN device console are MSB by default.
These parameters are always accessible on the device console page, as shown in Figure 58.
Figure 1: OTAA device successfully registered to TTNOTAA Configuration for TTN
The RAK3172 module can be configured using WisToolBox to do the OTAA configuration. WisToolBox is a software tool that supports RAK3172 module. It automatically detects the RAK3172 module once it is connected to the PC. Below are the options in WisToolBox where the OTAA configuration can be done.
OTAA Configuration for TTN via WisToolBox UI
The RAK3172 should have the correct OTAA credentials to connect to TTN. This can be done using WisToolBox UI. Below are the steps on setting up your RAK3172 using WisToolBox.
Connect your RAK3172 with your chosen WisBlock base board to the PC via USB cable and open the WisToolBox application.
Click CONNECT DEVICE button to launch the WisToolBox Dashboard.
Figure 1: CONNECT DEVICE- Then select your target port where your RAK3172 is connected. Once recognized, click CONNECT, as shown in Figure 60.
Figure 1: Setting up your device
Figure 1: Setting up your device- Once done, RAK3172 will appear in the dashboard then select it.
Figure 1: Device seen from WisToolBox dashboard- Then click PARAMETERS configure your RAK3172.
Figure 1: Setting up your device- Click Global settings to set the network mode to LoRaWAN and join mode to OTAA. Make sure that the active region is using EU868 for this configuration. If you wish to work on other regional bands, you can choose among active regions based on your location.
- LoRa network mode: LoRaWAN
- LoRaWAN join mode: OTAA
- LoRaWAN region: EU868
Figure 1: Global settings
Figure 1: Global settings- Click LoRaWAN keys, ID, EUI to configure the Application EUI (AppEUI), Application key (AppKey), and Device EUI (DevEUI).
Figure 1: LoRaWAN keys, ID, EUI
Figure 1: Setting up your device- Then go back to the console where your RAK3172 end-device is created previously. Copy the credentials from there since it will be used in the WisToolBox dashboard. Once encoded into the dashboard, click APPLY COMMAND to update your device, as shown in Figure 75.
- The AppEUI, DevEUI, and AppKey are hidden in this section as these are unique from a specific device.
Figure 1: Your created OTAA device from your console- For Application EUI (AppEUI)
Figure 1: Copying the AppEUI credential from TTN to WisToolBox
Figure 1: Copying the AppEUI credential from TTN to WisToolBox- For Application key (AppKey)
Figure 1: Copying the AppKey credential from TTN to WisToolBox
Figure 1: Copying the AppKey credential from TTN to WisToolBox- For Device EUI (DevEUI)
Figure 1: Copying the DevEUI credential from TTN to WisToolBox
Figure 1: Copying the DevEUI credential from TTN to WisToolBox- WisToolBox Dashboard
Figure 1: Used credentials from your console in WisToolBox dashboard- Once done, you will see the summary of commands that is applied to your device. Then click CLOSE.
Figure 1: Summary of commands- Now, you will see it return to the dashboard with updated credentials of your device.
Figure 1: Successfully configured OTAA device via WisToolBox dashboard- After your device's credentials are updated, it can now join the network. To do this, you need to go to Data on LoRa network under PARAMETERS, and then click JOIN NETWORK under LoRaWAN join settings. After a few seconds, it will notify you that your OTAA device has already joined the TTN server. You can also access your TTN console if your device has successfully joined the TTN.
Figure 1: Joining mode of your OTAA device
Figure 1: OTAA device successfully joined the TTN server
Figure 1: OTAA device successfully joined the TTN serverOTAA Configuration for TTN via WisToolBox Console
Here's another way of OTAA configuration using WisToolBox Console. Below are the steps on setting up your RAK3172 using WisToolBox Console.
Figure 1: CONNECT DEVICE- Select your target port where your RAK3172 is connected. Once recognized, click CONNECT, as shown in Figure 83.
Figure 1: Setting up your device- Once done, RAK3172 will appear in the dashboard, then select it.
Figure 1: Device seen from WisToolBox dashboard- Then click ADVANCED.
Figure 1: Setting up your device- Once done, click OPEN CONSOLE to do the configuration.
Figure 1: OPEN CONSOLE
Figure 1: Opening the Console terminal of WisToolBox
Figure 1: Opening the Console terminal of WisToolBox- To start the configuration, type
ATEso you can echo the commands you input during your configuration. Then press Enter.
AT
ATE
You will receive OK when you input the two commands. After setting ATE, you can now see all the commands you input together with the replies.
Figure 1: Setting up your Console
Figure 1: Setting up your Console- Then configure the LoRaWAN join mode to OTAA. You can check what parameter you will input by typing AT+NJM? and then Enter into the console terminal. For OTAA, you should input AT+NJM=1 and then press Enter, as shown in Figure 92.
Figure 1: Setting up your Console- Once done, set your LoRaWAN region to EU868. You can check what parameter you will input by typing
AT+BAND?then Enter into the console terminal. For EU868, you should input AT+BAND=4 then press Enter. If you wish to work on other regional bands, you may check the list of band parameter options below.
AT+BAND=4
Depending on the Regional Band you selected, you might need to configure the sub-band of your RAK3172 to match the gateway and LoRaWAN network server. This is especially important for regional bands like US915, AU915, and CN470.
To configure the masking of channels for the sub-bands, you can use the AT+MASK command that can be found on the AT Command Manual.
To illustrate, you can use sub-band 2 by sending the command AT+MASK=0002.
List of band parameter options
| Code | Regional Band |
| 0 | EU433 |
| 1 | CN470 |
| 2 | RU864 |
| 3 | IN865 |
| 4 | EU868 |
| 5 | US915 |
| 6 | AU915 |
| 7 | KR920 |
| 8 | AS923-1 |
| 9 | AS923-2 |
| 10 | AS923-3 |
| 11 | AS923-4 |
Figure 1: Setting up your Console- Then next to this will be updating the OTAA credentials of your device. First on this list will be the Application EUI (AppEUI). Go back to your console where your RAK3172 End device was created to copy the AppEUI credential, then paste it to the WisToolBox Console and press Enter.
Figure 1: Your created OTAA device from your TTN console
Figure 1: Setting up your Console- Once done, do the same procedure to Application key (AppKey) and Device EUI (DevEUI).
Figure 1: Setting up your Console- For Device EUI (DevEUI)
Figure 1: Setting up your Console- Once done, click Dashboard to check the updated credentials of your OTAA device. Click PARAMETERS to open the Global Settings and LoRaWAN keys, ID, EUI, and check whether these portions are updated.
Figure 1: PARAMETERS
Figure 1: Global settings and LoRaWAN keys, ID, EUI
Figure 1: Global settings and LoRaWAN keys, ID, EUI details-
Now you have a configured OTAA device using WisToolBox Console. You can now join the network using the WisToolBox console.
To do this, you need to go back to the WisToolBox console and type AT+JOIN. Edit it to AT+JOIN=1 and press Enter to join the network.
AT+JOIN command parameters are optional. You can configure the settings for auto-join, reattempt interval, and the number of join attempts if your application needs it. If not configured, it will use the default parameter values.
AT+JOIN and AT+JOIN=1 also share the common functionality of trying to join the network.
| Parameter | Description |
After 5 or 6 seconds, if the request is successfully received by a LoRa gateway, you should see +EVT:JOINED status reply, as shown in the figure below:
If the OTAA device failed to join, you need to check if your device is within reach of a working LoRaWAN gateway that is configured to connect to TTN. It is also important to check that all your OTAA parameters (DEVEUI, APPEUI, and APPKEY) are correct using the AT+DEVEUI=?, AT+APPEUI=?, and AT+APPKEY=? commands. Lastly, ensure that the antenna of your device is properly connected.
Figure 1: Joining mode using WisToolBox Console
Figure 1: OTAA device successfully joined the network- With the end-device properly joined to the TTN, you can now try to send some payload after a successful join. Send command format:
AT+SEND=<port>:<payload>
AT+SEND=2:12345678
Figure 1: OTAA device sending payload to the network
Figure 1: OTAA device sending payload to the network- You can see the data sent by the RAK3172 module on the TTN device console Live data section. Also, the Last seen info should be a few seconds or minutes ago.
Figure 1: OTAA Test Sample Data Sent Viewed in TTNTTN ABP Device Registration
- To register an ABP device, go to your application console and select the application to which you want your device to be added. Then click + Register end device, as shown in Figure 129.
Figure 1: Adding ABP Device- To register the board, click the Enter end device specifics manually.
Figure 1: Setting up for your device- Then click Show advanced activation, LoRaWAN class and cluster settings. Configure the activation mode by selecting Activation by personalization (ABP) and Additional LoRaWAN class capabilities to class A only.
Figure 1: Setting up for your device- Once done, provide the DevEUI credentials of your device into the DevEUI portion. This will automatically generate the specific End device ID of your board. Then click Generate under Device address, AppSKey, and NwkSKey under the Provisioning information section. Then click Register end device.
- The DevEUI, Device address, AppSKey, and NwkSKey are hidden in this section as these are unique from a specific device. The DevEUI credential is unique to every RAK3172 device. Also, you should generate your own Device address, AppSKey, and NwkSKey credentials for your specific device and application.
Figure 1: Register end device- You should now be able to see the device on the TTN console after you fully register your device, as shown in Figure 142.
Figure 1: ABP device successfully registered to TTNABP Configuration for TTN
The RAK3172 module can be configured using WisToolBox to do the ABP configuration. WisToolBox is a software tool that supports RAK3172 module. It automatically detects the RAK3172 module once it is connected to the PC. Below are the options in WisToolBox where the ABP configuration can be done.
ABP Configuration for TTN via WisToolBox UI
The RAK3172 should have the correct ABP credentials to connect to TTN. This can be done using WisToolBox. Below are the steps on setting up your RAK3172 using WisToolBox.
Click the CONNECT DEVICE button to launch the WisToolBox Dashboard.
Figure 1: CONNECT DEVICE- Select your target port where your RAK3172 is connected. Once recognized, click CONNECT, as shown in Figure 145.
Figure 1: Setting up your device- Once done, RAK3172 will appear in the dashboard, and then select it.
Figure 1: Device seen from WisToolBox dashboard- Then click PARAMETERS to do the configuration in your RAK3172.
- The AppSKey, Device address, and NwkSKey are hidden in this section as these are unique from a specific device.
Figure 1: Setting up your device- Click Global settings to set the network mode into LoRaWAN and join mode to ABP. Make sure that the active region is using EU868 for this configuration. If you wish to work on other regional bands, you can choose among active regions based on your location.
- LoRaWAN join mode: ABP
Figure 1: Global settings- Then click LoRaWAN keys, ID, EUI to configure the Application session key (AppSKey), Device address and Network session key (NwkSKey).
Figure 1: Setting up your device- Then go back to the console where your RAK3172 End device is created previously. Then copy all the credentials from there. Those will be the ones to be used also in the WisToolBox dashboard. Once encoded into the dashboard, click APPLY COMMANDS to update your device, as shown in Figure 159.
Figure 1: Your created ABP device from your console- For Application session key (AppSKey)
Figure 1: Copying the AppSKey credential from TTN to WisToolBox
Figure 1: Copying the AppSKey credential from TTN to WisToolBox- For Device address
Figure 1: Copying the Device address credential from TTN to WisToolBox
Figure 1: Copying the Device address credential from TTN to WisToolBox- For Network session key (NwkSKey)
Figure 1: Copying the NwkSKey credential from TTN to WisToolBox
Figure 1: Copying the NwkSKey credential from TTN to WisToolBox- WisToolBox Dashboard
Figure 1: Summary of commands- Now, you will see it returns to the dashboard with updated credentials of your device.
Figure 1: Successfully configured ABP device via WisToolBox dashboardABP Configuration for TTN via WisToolBox Console
Here's another way of ABP configuration using WisToolBox Console. Below are the steps on setting up your RAK3172 using WisToolBox Console.
Figure 1: CONNECT DEVICE- Select your target port where your RAK3172 is connected. Once recognized, click CONNECT, as shown in Figure 164.
Figure 1: Opening the Console terminal of WisToolBox- To start the configuration, type ATE so you can echo the commands you input during your configuration. Then press Enter.
AT
ATE
Figure 1: Setting up your Console- Then configure the LoRaWAN join mode to ABP. You can check what parameter you will input by typing AT+NJM?, and then Enter into the console terminal. For ABP, you should input AT+NJM=0, and then press Enter as shown in Figure 173.
Figure 1: Setting up your Console- Once done, set up your LoRaWAN region to EU868. You can check what parameter you will input by typing AT+BAND?, and then Enter into the console terminal. For EU868, you should input AT+BAND=4 then press Enter. If you wish to work on other regional bands, you may check the list of band parameter options below.
AT+BAND=4
Depending on the Regional Band you selected, you might need to configure the sub-band of your RAK3172 to match the gateway and LoRaWAN network server. This is especially important for Regional Bands like US915, AU915, and CN470.
| 0 | EU433 |
| 1 | CN470 |
| 2 | RU864 |
| 3 | IN865 |
| 4 | EU868 |
| 5 | US915 |
| 6 | AU915 |
| 7 | KR920 |
| 8 | AS923-1 |
| 9 | AS923-2 |
| 10 | AS923-3 |
| 11 | AS923-4 |
Figure 1: Setting up your Console- Then next to this will be updating the ABP credentials of your device. First to this will be the Application session key (AppSKey). Go back to your console where your RAK3172 End device was created to copy the AppSKey credential then paste it to the WisToolBox Console then press Enter.
Figure 1: Your created ABP device from your TTN console
Figure 1: Setting up your Console- Once done, do the same procedure to Device address and Network session key (NwkSKey).
Figure 1: Setting up your Console- For Network session key (NwkSKey)
Figure 1: Setting up your Console- Once done, click Dashboard to check the updated credentials of your ABP device. Click PARAMETERS to open the Global Settings and LoRaWAN keys, ID, EUI, and check whether these portions are updated.
Now you have a configured ABP device using WisToolBox Console. ABP-configured devices are directly tied to the network once done with the above procedures so the joining procedure is not needed.
Now, you can try sending the payload to TTN. Open again the terminal console of WisToolBox to send some payload using it. Send command format:
AT+SEND=2:12345678
Figure 1: ABP device sending payload to the network
Figure 1: ABP device sending payload to the network- You can see the data sent by the RAK3172 module on the TTN device console Live data section. Also, the Last seen info should be a few seconds or minutes ago.
Figure 1: ABP Test Sample Data Sent Viewed in TTNConnecting with ChirpStack
This section shows how to connect the RAK3172 module to the ChirpStack platform.
Figure 1: RAK3172 Module in the Context of the ChirpStack PlatformThe ChirpStack, previously known as the LoRaServer project, provides open-source components for building LoRaWAN networks. In the case of TTN, the RAK3172 module is located in the periphery and will transmit the data to the backend servers through a LoRa gateway. Learn more about ChirpStack.
It is assumed that you are using a RAK Gateway and its built-in ChirpStack. Also, the gateway with the ChirpStack must be configured successfully. For further information, check the RAK documents for more details.
- In a ChirpStack online gateway, the frequency band of the nodes should be consistent with the frequency band of the gateway in use.
- The RAK Serial Port Tool provided by RAK
- RAK3172 module
The frequency band used in the demonstration is EU868. Use a high-frequency version of RAK3172. The product number should be RAK3172 (H).
Create a New Application
Log in to the ChirpStack server using your account and password.
Go to the Application section, as shown in Figure 206.
Figure 1: Application Section- By default, you should create a new application, although you can reuse existing ones. For this setup, create a new Application by clicking on the CREATE button and filling in the required parameters, as shown in Figure 207 and Figure 208.
Figure 1: Creating a New Application- For this setup, create an Application named rak_node_test.
ChirpStack LoraServer supports multiple system configurations, with only one by default.
- Service profile: Field is to select the system profile.
- Payload codec: It is the parsing method for selecting load data, such as parsing LPP format data.
Figure 1: Filling Parameters of an Application-
Choose the Application created in the previous step, then select the DEVICES tab, as shown in Figure 209 and Figure 210.
Once done, click the + CREATE button.
Figure 1: List of Applications Created
Figure 1: Device Tab of an Application- Once inside the DEVICES tab, create a new device (LoRaWAN node) by clicking on the + CREATE button.
Figure 1: Add a New Device
Figure 1: Chirpstack Adding Node into the RAK3172 Module- Once the node is created, fill in the necessary data. You can generate a Device EUI automatically by clicking the following icon, or you can write a correct Device EUI in the edit box.
Device name and Device description: These are descriptive texts about your device.
Device EUI: This interface allows you to generate a Device EUI automatically by clicking the generate icon. You can also add a specific Device EUI directly in the form.
Device Profile:
Device profiles DeviceProfile_OTAA and DeviceProfile_ABP are only available if you are using the built-in Chirpstack LoRaWAN Server of RAK Gateways.
If you have your own Chirpstack installation, you can set up the device profile with LoRaWAN MAC version 1.0.4 and LoRaWAN Regional Parameters revision B to make it compatible with RAK3172.
Figure 1: Generate a New Device EUI Chirpstack OTAA Device Registration
- If you have selected DeviceProfile_OTAA, as shown in Figure 214, then after the device is created, an Application Key must be also created for this device.
Figure 1: Chirpstack OTAA Activation- A previously created Application Key can be entered here, or a new one can be generated automatically by clicking the icon highlighted in red in Figure 215.
Figure 1: Chirpstack OTAA Set Application Keys- Once the Application Key is added to the form, the process can be finalized by clicking on the SET DEVICE-KEYS button.
- As shown in Figure 216, a new device should be listed in the DEVICES tab. The most important parameters, such as the Device EUI, are shown in the summary.
Figure 1: Chirpstack OTAA List of Device in the Device Tab- To end the process, it is a good practice to review that the Application Key is properly associated with this device. The Application Key can be verified in the KEYS (OTAA) tab, as shown in Figure 217.
Figure 1: Application Key Associated with the New DeviceStandard OTAA mode requires the Device EUI, Application Key, and Application EUI, but in ChirpStack’s implementation, only the Device EUI and the Application Key are mandatory. The Application EUI is not required and not recorded in the Application tab. Nevertheless, you can reuse the Device EUI as the Application EUI during the configuration on the side of the node.
OTAA Configuration for Chirpstack
The RAK3172 module supports a series of AT commands to configure its internal parameters and control the functionalities of the module.
- To set up the RAK3172 module to join the Chirpstack using OTAA, start by connecting the RAK3172 module to the Computer (see Figure 35) and open the RAK Serial Port Tool. Select the right COM port and set the baud rate to 115200.
It is recommended to start by testing the serial communication and verify that the current configuration is working by sending these two AT commands:
AT
ATE
You will receive OK when you input the two commands. After setting ATE, you can now see all the commands you input together with the replies. Try again AT and you should see it on the terminal followed by OK, as shown in Figure 218.
If there is no OK or any reply, you need to check if the wiring of your UART lines is correct and if the baud is correctly configured to 115200. Also, you can check if the device is powered correctly. If you are getting power from a USB port, ensure that you have a good USB cable.
Figure 1: at+version command response- The next step is to configure the OTAA LoRaWAN parameters in RAK3172:
- LoRa work mode: LoRaWAN
- LoRaWAN class: Class A
Set the work mode to LoRaWAN.
AT+NWM=1
AT+NJM=1
AT+CLASS=A
AT+BAND=4
| 0 | EU433 |
| 1 | CN470 |
| 2 | RU864 |
| 3 | IN865 |
| 4 | EU868 |
| 5 | US915 |
| 6 | AU915 |
| 7 | KR920 |
| 8 | AS923-1 |
| 9 | AS923-2 |
| 10 | AS923-3 |
| 11 | AS923-4 |
Figure 1: Configuring LoRa Parameters- After the configuration of the LoRaWAN parameters, the next step is to set up the DevEUI and AppKey. You need the use the values from the Chirpstack device console.
The Application EUI parameter is not required in the ChirpStack platform; therefore, it is possible to use the same id as the Device EUI.
- Device EUI: 5E9D1E0857CF25F1
- Application EUI: 5E9D1E0857CF25F1
- Application Key: F921D50CD7D02EE3C5E6142154F274B2
Set the Device EUI.
AT+DEVEUI=5E9D1E0857CF25F1
Set the Application EUI.
AT+APPEUI=5E9D1E0857CF25F1
Set the Application Key.
Figure 1: Configuring LoRa Parameters- After EUI and key configuration, the device can now join the network and send some payload.
AT+JOIN=1:0:10:8
| z | Number of join attempts (0-255) - 0 is the default. |
After 5 or 6 seconds, if the request is successfully received by a LoRa gateway, you should see the JOINED status reply.
If the OTAA device failed to join, you need to check if your device is within reach of a working LoRaWAN gateway that is configured to connect to Chirpstack. It is also important to check that all your OTAA parameters (DEVEUI and APPKEY) are correct, using the AT+DEVEUI=? and AT+APPKEY=? commands. Lastly, ensure that the antenna of your device is properly connected.
- With the end-device properly activated, you can now try to send some payload after a successful join.
AT+SEND=2:12345678
Send command format: AT+SEND=<port>:<payload>
Figure 1: OTAA Test Sample Data Sent via RAK Serial Port ToolOn the ChirpStack platform, you should see the join and uplink messages in the LORAWAN FRAMES tab, as shown in Figure 222. By convention, messages sent from nodes to gateways are considered as Uplinks while messages sent by gateways to nodes are considered as Downlinks.
Figure 1: Chirpstack Data Received PreviewChirpstack ABP Device Registration
- During the registration of a new device, if you select DeviceProfile_ABP, as shown in Figure 223, then the ChirpStack platform will assume that this device will join the LoRaWAN network using the ABP mode.
Tick the checkbox Disable counting frame verification. During the test, when the module is restarted, the frame counting number will also be restarted from zero. This would cause a synchronization problem with the ChirpStack server treating it as a replay attack. For testing purposes, it is safe to disable this feature, but remember to activate it in a production environment.
Figure 1: ChirpStack Console, Configuring a Device- After selecting the ABP mode, the following parameters appear in the ACTIVATION tab:
Then, you can see that there are some parameters for ABP in the ACTIVATION item:
- Device address
- Network Session Key
- Application Session Key
Figure 1: Chirpstack ABP Activation Parameters Needed- The parameters can be generated as random numbers by the platform or can be set with user values. Once these parameters are filled in properly, the process is completed by clicking on the ACTIVATE DEVICE button.
ABP Configuration for Chirpstack
- To set up the RAK3172 module to join the Chirpstack using ABP, start by connecting the RAK3172 module to the Computer (see Figure 35) and open the RAK Serial Port Tool. Select the right COM port and set the baud rate to 115200.
AT
ATE
You will receive OK when you input the two commands. After setting ATE, you can now see all the commands you input together with the replies. Try again AT and you should see it on the terminal followed by OK, as shown in Figure 225.
Figure 1: at+version command response- The next step is to configure the ABP LoRaWAN parameters in RAK3172:
Set the work mode to LoRaWAN. It can be set to P2P as well but by default, the device is in LoRaWAN mode.
AT+NWM=1
AT+NJM=0
AT+CLASS=A
AT+BAND=4
Depending on the Regional Band you selected, you might need to configure the sub-band of your RAK3172 to match the gateway and LoRaWAN network server. This is especially important on Regional Bands like US915, AU915, and CN470.
To configure the masking of channels for the sub-bands, you can use the AT+MASK command that can be found on the AT Commands Manual.
| 0 | EU433 |
| 1 | CN470 |
| 2 | RU864 |
| 3 | IN865 |
| 4 | EU868 |
| 5 | US915 |
| 6 | AU915 |
| 7 | KR920 |
| 8 | AS923-1 |
| 9 | AS923-2 |
| 10 | AS923-3 |
| 11 | AS923-4 |
Figure 1: Configuring LoRa Parameters- After the configuration of the LoRaWAN parameters, the next step is to set up the device address and session keys. You need the use the values from the TTN device console.
- Device Address: 26011AF9
- Application Session Key: 4D42EC5CAF97F03D833CDAf5003F69E1
- Network Session Key: C280CB8D1DF688BC18601A97025C5488
Set the Device Address.
AT+DEVADDR=26011AF9
Set the Network Session Key.
Figure 1: Configuring LoRa ParametersAfter EUI and keys configuration, the device can now join the network and send some payload.
AT+JOIN=1:0:10:8
After 5 or 6 seconds, if the request is successfully received by a LoRa gateway, then you should see the JOINED status reply.
You can now try to send some payload after a successful join.
AT+SEND=2:12341234
Figure 1: ABP Test Sample Data Sent via RAK Serial Port ToolLoRa P2P Mode
This section will show you how to set up and connect two RAK3172 units to work in the LoRa P2P mode. The configuration of the RAK3172 units is done by connecting the two modules to a general-purpose computer using a USB-UART converter. The setup of each RAK3172 can be done separately, but testing the LoRa P2P mode will require having both units connected simultaneously. This could be done by having one computer with two USB ports or two computers with one USB port each.
It is recommended to start by testing the serial communication and verify the current configuration is working by sending these two AT commands:
AT
ATE
Try again AT and you should see it on the terminal followed by OK.
Figure 1: at+version command response- In setting up the RAK3172 to work in LoRa P2P mode, you need to change the LoRa network work mode command on both RAK3172 modules.
AT+NWM=0
AT+NWM parameter mode can be either 0=LoRa P2P or 1=LoRaWAN.
Figure 1: P2P Mode- The device will start automatically if you change modes from LoRaWAN to LoRa P2P and vice-versa.
- You might need to input the
ATEcommand again to ensure that your succeeding commands on P2P mode echo on the terminal.
- You need to input the P2P setup on both RAK3172 modules. The parameters should be exactly the same in the two modules.
For this P2P setup, the LoRa parameters are the following:
- Spreading factor: 7
- Bandwidth: 125 kHz
- Coding Rate: 0 = 4/5
- Preamble Length: 10
- Power: 14 dBm
Refer to the P2P Mode section of the AT command documentation to learn more about the definition of the parameters used and the individual commands if you want specific parameters changed.
Figure 1: Configuring P2P in both RAK3172 Module- To set one module as the receiver (RX), you need to set the value of the P2P receive command.
LoRa P2P default setting is Transmitter (TX) mode. This consumes lower power compared to Receiver (RX) mode where the radio is always listening for LoRa packets.
a. P2P LoRa RX configurable duration value is from 1 to 65533 ms. In this example, the device will listen and wait for LoRa P2P Packets for 30000 ms or 30 seconds. It will automatically disable RX mode and switch to TX mode after the timeout. If the device did not receive any packets within the time period, then the callback after timeout is +EVT:RXP2P RECEIVE TIMEOUT.
AT+PRECV=30000
b. If the AT+PRECV value is set to 65535, the device will listen to P2P LoRa packets without a timeout, but it will stop listening once a P2P LoRa packet is received. After receiving the packets, it will disable RX mode and automatically switch to TX mode again.
AT+PRECV=65535
c. If the AT+PRECV value is set to 65534, the device will continuously listen to P2P LoRa packets without any timeout. They will continuously stay in RX mode until AT+PRECV is set to 0.
AT+PRECV=65534
d. If the AT+PRECV value is set to 0, the device will stop listening to P2P LoRa packets. It disables LoRa P2P RX mode and switches to TX mode.
AT+PRECV=0
- With one module configured as Transmitter (TX) and the other device will be the Receiver (RX), you can now try to send or transmit P2P payload data.
AT+PSEND= <payload>
AT_PARAM_ERRORis returned when setting the wrong or malformed value.AT_BUSY_ERRORis returned if the device is still in RX mode and you try to send or reconfigure the RX period. If theAT+PRECVcommand is set to 65534, you need to execute firstAT+PRECV=0to be able to configure again the TX and RX state and avoidAT_BUSY_ERROR.<payload>: 2 ~ 500 digit length, must be an even number of digits and character 0-9, a-f, A-F only, representing 1 ~ 256 hexadecimal numbers. For example, if the payload is like0x03, 0xAA, 0x32, then the AT command should beAT+PSEND = 03AA32.
Figure 1: Configuring P2P in both RAK3172 ModuleMiscellaneous
Upgrade the Firmware
If you want to upgrade to the latest version of the firmware of the module, you can follow this section. The latest firmware can be found in the software section of RAK3172 Datasheet.
What if the RAK3172 module stops responding to AT commands and firmware updates?
You can recover your device by using the .hex file in the datasheet and uploading it using STM32CubeProgrammer. The guide on updating STM32 firmware using STM32CubeProgrammer can be found in the Learn section.
Uploading the .hex file via STM32CubeProgrammer will erase all configured data on the device.
Firmware Upgrade Through UART2
Refer to the table for the minimum hardware and software required to perform the firmware upgrade via UART2:
| Firmware File | Bin firmware file downloaded from the website |
| Others | A USB to TTL module |
Firmware Upgrade Procedure
Execute the following procedure to upgrade the firmware in Device Firmware Upgrade (DFU) mode through the UART2 interface.
RAK3172 should automatically go to BOOT mode when the firmware is uploaded via RAK DFU Tool or WisToolBox.
If BOOT mode is not initiated, you can manually send AT+BOOT command to start bootloader mode.
Download the latest application firmware of the RAK3172.
Make sure to flash the correct firmware!
For RAK3172 use firmware RAK3172-E_latest. This version will not work with RAK3172-T or RAK3172-F
For RAK3172-T use firmware RAK3172-T_latest. This version will not work with the RAK3172 or the RAK3172-F
For RAK3172-F use firmware RAK3172-F_latest. This version will not work with the RAK3172 or the RAK3172-T
You can also refer to the table below:
| Model | Version | Source |
| RAK3172 (.bin) | RUI3 Application Code only (default baudrate = 115200) | Download |
| RAK3172 (.hex) | RUI3 Bootloader and Application Code(default baudrate = 115200) | Download |
| RAK3172-T (.bin) | RUI3 Application Code only(default baudrate = 115200) | Download |
| RAK3172-T (.hex) | RUI3 Bootloader and Application Code (default baudrate = 115200) | Download |
| RAK3172-F (.bin) | RUI3 Application Code only(default baudrate = 115200) | Download |
| RAK3172-F (.hex) | RUI3 Bootloader and Application Code (default baudrate = 115200) | Download |
| RAK3172 (OLD) | DEPRECATED V1.0.4 (default baudrate = 9600) | Download |
There are RAK3172 devices loaded with old firmware versions which are not based on RUI3 (RAKwireless Unified Interface V3). These devices have v1.0.4 and below.
If the host microcontroller code is based on this old firmware, refer to the RAK3172 AT Command Migration guide that explains in detail the few differences between the two AT commands set.
Download the RAK Device Firmware Upgrade (DFU) tool.
Connect the RAK3172 module with a computer through a USB to TTL. Refer to Figure 35.
Open the Device Firmware Upgrade tool. Select the serial port and baud rate (115200) of the module and click the Select Port button.
If your firmware upload always fails, check your current baud rate setting using the AT+BAUD=? command and use that baud rate value in the RAK DFU Tool. You can also check if you selected the right COM port.
Figure 1: Device Firmware Upgrade Tool- Select the application firmware file of the module with the suffix .bin.
Figure 1: Select firmware- Click the Upgrade button to upgrade the device. After the upgrade is complete, the RAK3172 will be ready to work with the new firmware.
Figure 1: Firmware upgrading
Figure 1: Upgrade successfulArduino Installation
Refer to Software section.
