RAK Hotspot V2 Quick Start Guide
Before starting the setup process, make sure:
- RAK Hotspot V2 hardware installation is complete.
- The LoRa antenna system is connected.
Complete Unboxing & Installation before powering on RAK Hotspot V2.
Download the Helium App
The application is available for both Android and iOS. You can manually search for it or simply scan the QR code.
Figure 1: QR Codes
Figure 1: iOS and Android AppPower On the RAK Hotspot V2
- Connect the LoRa antenna before powering on the device.
When powering on the Hotspot, DO NOT leave the port antenna open to avoid potential damage to the device.
- Plug in and connect the included power supply to the USB-C port on the RAK Hotspot V2.
- After approximately one minute, you can add the RAK Hotspot V2 to the Helium app. Press the pairing button on the side to enable the Hotspot Pairing mode.
- Select Set up Hotspot in the app and follow the instructions. Press the Pairing button when requested.
To reconnect to the app in the future, simply press the button.
Account Security
When setting up your account, you will be prompted to enter a 12-word seed phrase. This phrase is essential for recovering or transferring your account to a new phone if needed.
Figure 1: Account recovery or transfer keywords
