Barometric Pressure Monitoring Sensor Quick Start Guide
What Do You Need?
Before proceeding with each step for using the RAK2560 WisNode Sensor Hub module, ensure that you have the necessary items listed below:
Hardware Tools
- Sensor Hub Barometric Pressure Monitoring Solution
- Solar Battery Lite for Sensor Hub (Optional)
Figure 1: Sensor Hub Solar Radiation Solution AccesoriesSoftware
Solution Configuration
Sensor Hub Setup
SIM Card Installation
Wall Mounting
Figure 1: Installation preparation- Secure the mounting bracket to the wall by using self-tapping screws.
- Secure the mounting bracket to the pole using a steel strap.
Figure 1: Fix the Mounting BracketMount the bracket on a pole with a 50-80 mm diameter. For larger poles, use a bigger steel strap. The standard kit does not include a larger steel strap. Purchase separately if needed.
Figure 1: Fasten the device and the bracketInstall the Barometric Pressure Sensor
The RAK1902 Barometric Pressure monitoring Sensor is pre-connected to the Sensor Hub at the factory, eliminating the need for any additional assembly by the user.
Figure 1: Sensor Probe InstallationPower Supply Setup
The SensorHub Barometric Pressure Monitoring Sensor RAK1902 supports three power supply methods: battery-powered, connected to a solar panel, or a 12 VDC power supply.
- Mount the bracket on a pole with a 50-80 mm diameter. For larger poles, use a bigger steel strap. The standard kit does not include a larger steel strap. Purchase separately if needed.
- The Sensor Hub supports a power supply using 2 to 4 ER18505 non-rechargeable batteries, which should be purchased separately if needed. For more information on compatible batteries, refer to the Sensor Hub user manual.
- The Sensor Hub has two models based on the communication mode: LoRaWAN only and LoRaWAN+NB-IoT. The Sensor Hub's NB-IoT module supports two LTE (Long-Term Evolution) categories: CAT M1 and CAT NB2. CAT M1 offers higher data transfer rates and lower latency, while CAT NB2 provides ultra-low power consumption and a larger coverage range, making it ideal for battery-powered devices requiring long-term connectivity.
- Secure the mounting bracket on the pole with two steel straps.
Figure 1: Secure the mounting bracket- Attach the mounting plate to the RAK9154 with two (2) M3 screws.
Figure 1: Attach the mounting plate- Install the RAK9154 to the back of the solar panel with four (4) screws and nuts.
Figure 1: Attach the RAK9154 to solar panel- Connect the cable of the solar panel to the PV input connector of RAK9154. Install two (2) M6 screws to the mounting plate with a clearance of about 3 mm.
Figure 1: RAK9154 and Solar Panel Connection- Suspend the solar panel on the mounting bracket, adjust its angle and direction, and then tighten the two (2) M6 screws along with the remaining two screws.
Figure 1: Install the solar panel combination- Connect Sensor Hub and RAK9154. Use a cable to link the remaining connection port of the Sensor Hub to the lithium battery Output 1 SP11 connection port of RAK9154.
Figure 1: Connect the Sensor Hub and RAK9154- Once the connection is complete, the Sensor Hub is ready to be powered up.
- Connect the power adapter to the external power cable of Sensor Hub using a circular DC connector.
Figure 1: Power adapter connection- Connect the external power cable to the Sensor Hub using the SP11 connector.
- Align the white dot mark on the SP11 connector plug of the external power cable with the white dot mark on the Sensor Hub SP11 connector socket, and push the plug firmly into the socket.
- After the plug and socket are connected, tighten the locking nut to secure the connection of the SP11 connector. The external power cable can connect to any Sensor Hub connection port.
Figure 1: Connect external power supplySoftware Configuration Guide
Sensor Hub Configuration
Power Up Sensor Hub
Figure 1: Start App- On the Select connection mode menu, choose NFC Activation.
Figure 1: Click on the CONNECT button- Hold your mobile device close to the N symbol on the Sensor Hub device.
Figure 1: Uplink Settings option- Once configured, click SAVE SELECTION, and then the APPLY button to implement the configuration options.
LoRaWAN Configuration
- Click the LORA & LORAWAN PARAMETERS tab. Configure the following parameters:
- Global settings
Figure 1: Global Settings- Join mode: Configure the Join mode based on the device's network access mode: Over-The-Air Activation (OTAA) or Activation By Personalization (ABP). Make sure it matches the join mode registered on the network server.
- Active region: Set the Active region to the device's frequency plan. Ensure that it is consistent with the gateway and device frequency plan registered on the network server. Supported frequency bands include CN470, RU864, IN865, EU868, US915, AU915, KR920, AS923-1/2/3/4.
- For the OTAA join mode, configure the following parameters: Application EUI, Application key, and Device EUI.
Figure 1: LoRaWAN parameters-
Application EUI: Confirm that it matches the device's Application EUI as registered in the network server.
Application key: Verify its alignment with the device's Application key registered in the network server. Click GENERATE KEY to create a new key if needed.
Device EUI: Confirm that it matches the device's EUI as registered in the network server.
For the ABP join mode, configure the following parameters: Application session key, Device address, and Network session key.
Data on LoRa® Network
Figure 1: Data on LoRa® Network- Confirm mode: Message confirmation mode.
Figure 1: Join the networkNB-IoT/LTE CAT-M1 Configuration
Figure 1: View the NB-IOT PARAMETERS tab parametersLTE-M Network
- OPERATOR: Shows the Network operator. If the operator's name is displayed, it indicates that the device has recognized the SIM card. For example, T-Mobile.
IP Network
- Server address: Input the server address. Using the external MQTT broker as an example, enter
broker.hivemq.com. Enter the address based on your specific use case. - Server Port: Specify the server port according to your configuration.
Figure 1: Configure the Subscription Topics- Publish Topic: Specify the topic for publishing messages.
Figure 1: Apply the modified configuration- When configured correctly and successfully connected to the server, the Connection Status will display as connected.
This section details the configuration process of the RAK1902 Barometric Pressure sensor. It shows how to access the monitoring data and device details of the Barometric Pressure sensor. Additionally, there’s an option to configure other information for each monitoring parameter, such as the uplink data sending period and threshold.
- To start with, click the SENSOR PROBE tab to display the connected Barometric Pressure sensor.
Figure 1: Barometric Pressure Sensor- Click the dropdown arrow to expand the details of the sensor.
Figure 1: Sensor Information- Temperature: Temperature value.
- Pressure: Pressure value.
- Device details
Figure 1: Sensor Details- Click the downward arrow in the Pressure tab bar to set the periodic uplink sending of the pressure parameters, thresholds, and other related information.
Figure 1: Sensor details- Sensor data: Data provided by the sensor.
- FETCH DATA: Update the latest sensor data.
- Sensor interval(s): The payload sending interval in seconds. It determines how often the sensor sends uplink data to the server, with a range interval from 60~86,400 seconds. Set this parameter when the Send periodic uplink is enabled.
- Lower threshold, hPa: Specifies the minimum acceptable barometric pressure value.
- Send uplink if below threshold: Trigger the transmission of uplink data if the value falls below the lower threshold.
- Upper threshold, hPa: Maximum acceptable barometric presure value.
- Send uplink if above threshold: Send uplink data if the value exceeds the upper threshold.
- Threshold, hPa: Range of acceptable values.
- Send uplink if between threshold: Send uplink data if the value falls within the specified threshold range.
Click the downward arrow in the Temperature tab bar to set the periodic uplink sending, thresholds, and other information, in the same way you configured the pressure values in the previous step.
After completing the modifications, a message Commands in queue will appear at the bottom of the interface. Click APPLY to send the parameter update commands.
Figure 1: Set the sensor parameters- When the message All commands applied successfully, appears on the interface, it indicates that the parameter update commands have been successfully sent.
Figure 1: Apply commandsOther Operations
- REMOVE SENSOR PROBE: Detach the sensor.
