Environmental Monitoring Solution Quick Start Guide
Before proceeding with each step for using the Environmental Monitoring Solutions, ensure you have the necessary items.
 Figure 1: Solutions package inclusion
Figure 1: Solutions package inclusionHardware
- Sensor Hub Environmental Monitoring Solution
- Solar Battery Lite for Sensor Hub (optional)
- Additional accessories: Probe Cable, Probe Splitter, Power Supply, and others (numbers and variations depending on the use case)
Sensor Hub Setup
SIM Card Installation
 Figure 1: Remove the back cover
 Figure 1: Insert the SIM card
Wall Mounting
 Figure 1: Installation preparation
Figure 1: Installation preparation- Secure the mounting bracket to the wall by using tapping screws.
 Figure 1: Secure the mounting bracket
 Figure 1: Align the device with the hanging tabs
- Secure the mounting bracket to the pole using a steel strap.
 Figure 1: Fix the mounting bracket
Figure 1: Fix the mounting bracket- Mount the bracket on a pole with a 50-80 mm diameter. For larger poles, use a bigger steel strap.
- The standard kit does not include a larger steel strap. Purchase separately if needed.
 Figure 1: Device installation
 Figure 1: Fasten the device and the bracket
Figure 1: Fasten the device and the bracketRAK2560 WisNode Sensor Hub + Temperature & Humidity Sensor Setup
Sensor Hub + Temperature & Humidity Sensor Installation
The RAK1901 Temperature and Humidity sensor comes pre-assembled with Sensor Hub by default at the factory. No additional assembly is required; simply connect the Temperature & Humidity Sensor and Sensor Hub.
 Figure 1: Installation completed
Figure 1: Installation completedPower Supply Setup
The Sensor Hub Environmental Monitoring Solution supports a battery, solar panel, or 12 VDC power supply.
- Secure the mounting bracket on the pole with two steel straps.
Figure 1: Secure the mounting bracket- Attach the mounting plate to the RAK9154 with two (2) M3 screws.
 Figure 1: Secure the mounting plate
Figure 1: Secure the mounting plate- Install the RAK9154 to the back of the solar panel with four (4) screws and nuts.
 Figure 1: Attach RAK9154 to solar panel
Figure 1: Attach RAK9154 to solar panel- Connect the cable of the solar panel to the PV input connector of RAK9154. Install two (2) M6 screws to the mounting plate with a clearance of about 3 mm.
 Figure 1: RAK9154 and Solar Panel Connection
Figure 1: RAK9154 and Solar Panel Connection- Suspend the solar panel on the mounting bracket, adjust its angle and direction, and then tighten the two (2) M6 screws along with the remaining two screws.
 Figure 1: Install the solar panel combination
Figure 1: Install the solar panel combination- Connect Sensor Hub and RAK9154. Use a cable to link the remaining connection port of the Sensor Hub to the lithium battery Output 1 SP11 connection port of RAK9154.
 Figure 1: Connect Sensor Hub and RAK9154
Figure 1: Connect Sensor Hub and RAK9154- Once the connection is complete, the Sensor Hub is ready to be powered up.
- Connect the power adapter to the external power cable of the Sensor Hub using a circular DC connector.
 Figure 1: Power adapter connection
Figure 1: Power adapter connection- Connect the external power cable to the Sensor Hub using the SP11 connector.
- Align the white dot symbol on the SP11 connector plug of the external power cable with the white dot symbol on the Sensor Hub SP11 connector socket and push the plug firmly into the socket.
- After the plug and socket are connected, tighten the locking nut to secure the connection of the SP11 connector. The external power cable can connect to any Sensor Hub connection port.
 Figure 1: Connect the external power cable
Figure 1: Connect the external power cableSoftware Configuration Guide
Sensor Hub Configuration
Power Up Sensor Hub
- Download and install the WisToolBox app on your smart mobile device. The WisToolBox app is available for download from the Apple App Store and the Android Google Play Store.
- Initiate the app and confirm that NFC and Bluetooth are enabled on your mobile device. Click on START.
 Figure 1: Start the app
Figure 1: Start the app- On the Select connection mode menu, choose NFC Activation.
 Figure 1: Select NFC Activation
 Figure 1: Select Sensor Hub
 Figure 1: Click on the CONNECT button
Figure 1: Click on the CONNECT button- Hold your mobile device close to the N symbol on the Sensor Hub device.
 Figure 1: Scanning in progress
 Figure 1: Scan Successful
 Figure 1: Sync Device
 Figure 1: SENSOR HUB INFO page
 Figure 1: Uplink Settings option
Figure 1: Uplink Settings option- Once configured, click SAVE SELECTION, and then the APPLY button to implement the configuration options.
 Figure 1: Apply the configuration options
 Figure 1: Commands applied successfully
LoRaWAN Configuration
Refer to the Connect Gateway to TTN and Connect Sensor Hub to TTN sections for detailed instructions.
- Click on the LORA & LORAWAN PARAMETERS tab. Configure the following parameters:
- Global Settings
 Figure 1: Global Settings
Figure 1: Global Settings- Join Mode: Configure the Join mode based on the device's network access mode: Over-The-Air Activation (OTAA) or Activation By Personalization (ABP). Make sure it matches the join mode registered on the network server.
- Active Region: Set the Active region to the device's frequency plan. Ensure that it is consistent with the gateway and device frequency plan registered on the network server.
LoRaWAN keys, ID, EUI- For the OTAA join mode, configure the following parameters: Application EUI, Application key, and Device EUI.
 Figure 1: OTAA Join Mode Configuration
Figure 1: OTAA Join Mode Configuration-
Application EUI: Confirm that it matches the device's Application EUI as registered in the network server.
Application key: Verify its alignment with the device's Application key registered in the network server. Click GENERATE KEY to create a new key if needed.
Device EUI: Confirm that it matches the Device EUI registered in the network server.
For the ABP join mode, configure the required parameters: Application session key, Device address, and Network session key.
 Figure 1: ABP Join Mode
Figure 1: ABP Join Mode- Data on LoRa® network
 Figure 1: Data on LoRa® network
Figure 1: Data on LoRa® network- Confirm mode: Message confirmation mode.
- Enable Auto Join: Determine whether to activate automatic network access. When enabled, the device will join the network automatically upon powering up.
- Network Status: Indicates the status of the network connection. It will activate automatically once connected to the network.
- ADR: The Adaptive Data Rate optimizes the data rates in the network. Toggle the button to enable and disable it.
- JOIN NETWORK: After completing the network parameter configuration, click the JOIN NETWORK button to run the join network command.
 Figure 1: Join the network
Figure 1: Join the networkNB-IoT/LTE CAT-M1 Configuration
 Figure 1: View the LTE-M Parameters tab
Figure 1: View the LTE-M Parameters tab- OPERATOR: Shows the network operator. If the operator's name is displayed (for example, T-Mobile), it indicates that the device has recognized the SIM card.
 Figure 1: Configure the cellular network parameters
- Server address: Input the server address. Using the external MQTT broker as an example, enter broker.hivemq.com. Enter the address based on your specific use case.
- Server Port: Specify the server port according to your configuration.
- Publish Topic: Specify the topic for publishing messages.
 Figure 1: Apply the modified configuration
Figure 1: Apply the modified configuration- When configured correctly and successfully connected to the server, the Connection Status will display as connected.
 Figure 1: Successfully connected to the server
This section details the configuration process of the RAK1901 Temperature and Humidity Sensor. It shows how to access the monitoring data and device details of the sensor. Additionally, there’s an option to configure other information for each monitoring parameter, such as the uplink data sending period and threshold.
- To start with, click the SENSOR PROBE tab to display the connected sensor on the interface.
 Figure 1: Connected temperature and humidity sensor
Figure 1: Connected temperature and humidity sensor- Click the dropdown to expand the details of the environmental monitoring sensor.
 Figure 1: Sensor details
Figure 1: Sensor details- Temperature
- Humidity
- Device details
Figure 1: Sensor details- Fetch the temperature data and configure the periodic uplink data sending, thresholds, and other relevant information for the sensor.
 Figure 1: Set the sensor parameters
Figure 1: Set the sensor parameters- Sensor data: Data provided by the sensor.
- FETCH DATA: Update the latest sensor data.
- Sensor interval(s): The payload sending interval in seconds. It determines how often the sensor sends uplink data to the server, with a range interval from 60~86, 400 seconds. Set this parameter when the Send periodic uplink is enabled.
- Lower threshold: The minimum acceptable value.
- Send uplink if below threshold: Send uplink data if the value is below the lower threshold.
- Upper threshold: Maximum acceptable value.
- Send uplink if above threshold: Send uplink data if the value exceeds the upper threshold.
- Threshold, m/s: Range of acceptable values.
- Send uplink if between threshold: Send uplink data if the value falls within the threshold range.
- After completing the modifications, a message Commands in queue will appear at the bottom of the interface. Click APPLY to send the parameter update commands.
 Figure 1: Apply commands
Figure 1: Apply commands- When the message All commands applied successfully, appears on the interface, it indicates that the parameter update commands have been successfully sent.
Figure 1: Commands applied successfully- REMOVE SENSOR PROBE: Detach the sensor.
s
