RAK7204 AT Command Manual
You can configure your RAK7204 WisNode Sense Home by sending AT Commands via a Serial port tool running on your PC. The following list shows the AT Commands that you can use:
The AT commands can be classified in the following groups:
- Read Command : Reads the current configuration or status of the board. The command name and the list of parameters are separated by
=character. The<m>parameter is separated with its associated value<n>by the:character.
at+get_config=<m>:<n>
- Write Command : Writes/Modifies the current configuration of the board. The command name and the list of parameters are separated by
at+set_config=<m>:<n>
- Operational Commands : There are also commands that are neither read nor write commands. The purpose is to execute an action, for example:
at+send=lora:<m>:<n> // Sends data through the LoRa transceiver.
- Special Command : The RAK7204 UART port has two operational modes: Configuration Mode and Data Transmission Mode. When switching from data transmission mode to configuration mode the command to be entered is
+++and does not contain terminators such as\ rand\ n.
After executing the command, a response is sent back to the external MCU. The usual reply has the following format:
OK [information]\r\n
Only the read commands have information in the replied message, while Write commands do not have an informative description.
The firmware developed running in the external MCU will expect at a minimum string of Ok\r\n after sending a successful command to the board. On the other hand, when the command is not successfully executed by the board, you will receive a response in the following format:
ERROR: [ErrCode]\r\n
Error Code Table
| Error Code | Description |
| 1 | The last command received is an unsupported AT command. |
| 2 | Invalid parameter in the AT command. |
| 3 | There is an error when reading or writing the flash memory. |
| 4 | There is an error when reading or writing through IIC bus. |
| 5 | There is an error when sending data through the UART port. |
| 80 | The LoRa transceiver is busy, could not process a new command. |
| 81 | LoRa service is unknown. Unknown MAC command received by node. Execute commands that are not supported in the current state, such as sending at+join command in P2P mode. |
| 82 | The LoRa parameters are invalid. |
| 83 | The LoRa parameters are invalid. |
| 84 | The LoRa data rate (DR) is invalid. |
| 85 | The LoRa frequency and data rate are invalid. |
| 86 | The device has not joined into a LoRa network. |
| 87 | The length of the packet exceeded that maximum allowed by the LoRa protocol. |
| 88 | Service is closed by the server. Due to the limitation of duty cycle, the server will send "SRV_MAC_DUTY_CYCLE_REQ" MAC command to close the service. |
| 89 | This is an unsupported region code. |
| 90 | Duty cycle is restricted. Due to duty cycle, data cannot be sent at this time until the time limit is removed. |
| 91 | No valid LoRa channel could be found. |
| 92 | No available LoRa channel could be found. |
| 93 | Status is error. Generally, the internal state of the protocol stack is wrong. |
| 94 | Time out reached while sending the packet through the LoRa transceiver. |
| 95 | Time out reached while waiting for a packet in the LoRa RX1 window. |
| 96 | Time out reached while waiting for a packet in the LoRa RX2 window. |
| 97 | There is an error while receiving a packet during the LoRa RX1 window. |
| 98 | There is an error while receiving a packet during the LoRa RX2 window. |
| 99 | Failed to join into a LoRa network. |
| 100 | Duplicated downlink message is detected. A message with an invalid downlink count is received. |
| 101 | Payload size is not valid for the current data rate (DR). |
| 102 | Many downlink packets are lost. |
| 103 | Address fail. The address of the received packet does not match the address of the current node. |
| 104 | Invalid MIC is detected in the LoRa message. |
General AT Command
- at+version
This command is used to get the current firmware version number.
| Operation | Command | Response |
| Read | at+version | OK <version number> |
Parameter: NONE
Example:
at+version\r\n
OK V3.0.0.14.H.p_rst
- at+help
This command is used to obtain all AT commands supported by the current firmware.
| Read | at+help | OK <all AT commands> |
Parameter: NONE
Example:
at+help\r\n
OK
===============AT Commands List==================
Device AT commands:
at+version
at+help
at+set_config=device:restart
at+set_config=device:sleep:X
at+get_config=device:status
at+set_config=device:uart:X:Y
at+set_config=device:uart_mode:X:Y
at+send=uart:X:YYY
at+set_config=device:gpio:X:Y
at+get_config=device:gpio:X
at+get_config=device:adc:X
LoRaWAN AT commands:
at+set_config=lora:default_parameters
at+join
at+send=lora:X:YYY
at+set_config=lora:region:XXX
at+get_config=lora:channel
at+set_config=lora:dev_eui:XXXX
at+set_config=lora:app_eui:XXXX
at+set_config=lora:app_key:XXXX
at+set_config=lora:dev_addr:XXXX
at+set_config=lora:apps_key:XXXX
at+set_config=lora:nwks_key:XXXX
at+set_config=lora:multicastenable:X
at+set_config=lora:multicast_dev_addr:XXXX
at+set_config=lora:multicast_apps_key:XXXX
at+set_config=lora:multicast_nwks_key:XXXX
at+set_config=lora:join_mode:X
at+set_config=lora:work_mode:X
at+set_config=lora:ch_mask:X:Y
at+set_config=lora:class:X
at+set_config=lora:confirm:X
at+set_config=lora:dr:X
at+set_config=lora:tx_power:X
at+set_config=lora:adr:X
at+set_config=lora:send_interval:X:Y
at+get_config=lora:status
at+set_config=lora:dutycycle_enable:X
at+set_config=lora:send_repeat_cnt:X
LoRaP2P AT commands:
at+set_config=lorap2p:XXX:Y:Z:A:B:C
at+set_config=lorap2p:transfer_mode:X
at+send=lorap2p:XXX
===================List End======================
- at+set_config=device:restart
This command is used to restart the device.
| Read | at+set_config=device:restart |
Parameter: NONE
Example:
LoRa (R) is a registered trademark or service mark of Semtech Corporation or its affiliates. LoRaWAN (R) is a licensed mark.
______ ___ _ __ _ _ _ _
| ___ \/ _ \ | | / / | | | (_) | |
| |_/ / /_\ \| |/ / | | | |_ _ __ ___| | ___ ___ ___
| /| _ || \ | |/\| | | '__/ _ \ |/ _ \/ __/ __|
| |\ \| | | || |\ \ \ /\ / | | | __/ | __/\__ \__ \
\_| \_\_| |_/\_| \_/ \/ \/|_|_| \___|_|\___||___/___/
RAK7204 Version:3.0.0.14.H.p_rst
periodic rst is enabled. (interval:86400)
UART1 work mode: RUI_UART_NORMAL, 115200, N81
UART3 work mode: RUI_UART_USER, 115200, N81
BME680 init success.
autosend_interval: 240s
Current work_mode:LoRaWAN, join_mode:OTAA, MulticastEnable: false, Class: A
Initialization OK
<status>
This command is used to change the current state of the device between the sleep and the wake-up mode.
| Write | at+set_config=device:sleep:<status> | OK<STATUS> |
Parameter:
| Status | 0: wake up 1: sleep |
Example:
at+set_config=device:sleep:1\r\n
OK Sleep
at+set_config=device:sleep:0\r\n
Go to Sleep
OK
This command is used to obtain the current status of the device.
| Read | at+get_config=device:status | OK<information> |
Parameter: None
Example:
at+get_config=device:status\r\n
OK.
===============Device Status List================
Board Core: RAK7204
MCU: STM32L151CB_A
LoRa chip: SX1276
Battery Voltage:4.195 V
BME680 sensor data:
Humidity:20.462 %RH
Temperature:23.51 degree
Pressure:628.91 hPa
Gas_resistance: 14748 Ohms
Interface Type AT Command
<index>:<baud_rate>
This command is used to configure the baud rate for a UART port.
There will be no reply after executing this configuration if a different baud rate is set. To make your UART serial communication work again, configure the UART baud rate setting of the Serial Port Tool based on the new baud rate.
| Write | at+set_config=device:uart:<index>:<baud_rate> | OK |
Parameter:
| index | UART Number: 1 or 3. Two UART ports are currently supported starting FW V3.0.0.14.H - UART1 and UART3 |
| baud_rate | UART Baud rate:1200, 2400, 4800, 9600, 19200, 38400, 57600,115200 |
Example:
at+set_config=device:uart:1:115200\r\n
OK.
<index>:<mode>
This command is used to set the UART operation between the AT configuration mode and the data transmission mode.
| Write | at+set_config=device:uart_mode:<index>:<mode> | OK |
Parameter:
| mode | UART Mode: Only 1 can be selected, which means the UART is set to data transmission mode |
Example:
at+set_config=device:uart_mode:1:1\r\n
Uart transparent mode configure success
OK
at+send=uart:
<index>:<data>
This command is used to send data over a UART port.
| Write | at+send=uart:<index>:<data> | OK |
Parameter:
| index | UART Port Number. Currently, the RAK7204 only supports UART1. |
| mode | The data you want to send. The maximum length of data is 250 characters, equivalent to 255 — the length of at+... — the length of \ r\ n. |
Example:
at+send=uart:1:12345\r\n
OK12345
<pin_num>:<status>
This command is used to set the voltage level state (high or low) of a pin on a board.
| Read | at+get_config=device:gpio:<pin_num> | OK<status> |
Parameter:
| pin_num | Pin index of the board |
| status | 0: Low voltage level 1: High voltage level |
Example:
at+set_config=device:gpio:2:0\r\n
OK
<pin_num>
This command is used to obtain the voltage level status of a pin on a board.
| Write | at+set_config=device:gpio:<pin_num>:<status> | OK |
Parameter:
| status(Return Value) | 0: Low voltage level 1: High voltage level |
Example:
at+get_config=device:gpio:2\r\n
OK 1
<pin_num>
This command is used to obtain the voltage level of an ADC pin of the board.
| Read | at+get_config=device:adc:<pin_num> | OK<voltage> |
Parameter:
| pin_num | ADC pin index of the board |
| Voltage(Return Value) | Voltage,Unit: mV |
Example:
at+get_config=device:adc:2\r\n
OK 681mV
LoRaWAN Type AT Command
- at+join
This command is used to join a LoRaWAN network.
at+join | OK Join Success |
Parameter: NONE
Example:
at+join\r\n
OTAA:
DevEui:00662CA006D4F7E5
AppEui:70B3D57ED003CBC5
AppKey:72E181E4428C4F305827284D2FD54618
OTAA Join Start...
[LoRa]:Join Success
OK
at+send=lora:
<port>:<data>
This command is used to send data via LoRaWAN.
at+send=lora:<port>:<data> | OK |
Parameter:
| port | Sending port of LoRa. The value range is 1-223. |
| data | The sending data format is in hexadecimal format. The possible values are between 00-FF. The board will internally cast every two characters into a byte before sending it to the LoRa transceiver. The maximum length varies depending on the band frequency and DR (LoRaWAN standard). Refer to Appendix III. |
Example:
When sending data as unconfirmed uplink:
at+send=lora:1:5A00\r\n
OK
When sending data as confirmed uplink:
OK
at+recv=0,-48,7,0
When sending a confirmed message, you will receive an ACK response, i.e. at+recv=....
The 0, -105, -12,0 stands for:
0: For the LoRa port;-105: For the RSSI;-12: For the SNR;0: For the length of the data (no valid data in ACK).
<region>
This command is used to set the appropriate working frequency band.
| Write | at+set_config=lora:region:<region> | OK |
Parameter:
| region | EU433, CN470, IN865, EU868, US915, AU915, KR920, AS923. The default is EU868. |
Example:
at+set_config=lora:region:EU868\r\n
OK
In the AS923 frequency band, the supported frequency plan is "as2" and dwell is set to 1.
- at+get_config=lora:channel
This command is used to read all the LoRa channel information for the device's current region.
| Read | at+get_config=lora:channel | OK <channel information> |
Parameter: NONE
Example: EU868 region
at+get_config=lora:channel\r\n
OK * 0,on,868100000,0,5; * 1,on,868300000,0,5; * 2,on,868500000,0,5; 3,off,0,0,0; 4,off,0,0,0; 5,off,0,0,0; 6,off,0,0,0; 7,off,0,0,0; * 8,on,867100000,0,5; * 9,on,867300000,0,5; *10,on,867500000,0,5; *11,on,867700000,0,5; *12,on,867900000,0,5; 13,off,0,0,0; 14,off,0,0,0; 15,off,0,0,0
With *0,on,868100000,0,5 as an example,the following is the channel parameter analysis:
*at the beginning if the channel is open;0is the channel ID;onindicates the current status of the channel;868100000is the actual frequency of the channel,unit is Hz;0,5indicates the DR of the channel, DR0~DR5.
<channel_number>:<status>
This command is used to switch a channel (turn on or off) in the current region.
| Write | at+set_config=lora:ch_mask:<channel_number>:<status> | OK |
Parameter:
| channel_number | Channel number |
| status | 0: off 1: on |
Example:
at+set_config=lora:ch_mask:0:0\r\n
OK
<dev_eui>
This command is used to set the Device EUI parameter for the LoRaWAN OTAA mode.
| Write | at+set_config=lora:dev_eui:<dev_eui> | OK |
Parameter:
| dev_eui | Device EUI |
Example:
at+set_config=lora:dev_eui:3530353064377716\r\n
OK
<app_eui>
This command is used to set the Application EUI parameter for the LoRaWAN OTAA mode.
| Write | at+set_config=lora:app_eui:<app_eui> | OK |
Parameter:
| app_eui | Application EUI |
Example:
at+set_config=lora:app_eui:0000000000000001\r\n
OK
<app_key>
This command is used to set the Application Key parameter for the LoRaWAN OTAA mode.
| Write | at+set_config=lora:app_key:<app_key> | OK |
Parameter:
| app_key | Application Key |
Example:
at+set_config=lora:app_key:841986913ACD00BBC2BE2479D70F3228\r\n
OK
<dev_addr>
This command is used to set the Device Address parameter for the LoRaWAN ABP mode.
| Write | at+set_config=lora:dev_addr:<dev_addr> | OK |
Parameter:
| dev_addr | Device Address |
Example:
at+set_config=lora:dev_addr:260125D7\r\n
OK
<apps_key>
This command is used to set the Application Session Key parameter for the LoRaWAN ABP mode.
| Write | at+set_config=lora:apps_key:<apps_key> | OK |
Parameter:
| apps_key | Application Session Key |
Example:
at+set_config=lora:apps_key:841986913ACD00BBC2BE2479D70F3228\r\n
OK
<nwks_key>
This command is used to set the Network Session Key parameter for the LoRaWAN ABP mode.
| Read | at+set_config=lora:nwks_key:<nwks_key> | OK |
Parameter:
| nwks_key | Network Session Key |
Example:
at+set_config=lora:nwks_key:69AF20AEA26C01B243945A28C9172B42\r\n
OK
<mode>
This command is used to switch the LoRaWAN access mode between the OTAA and the ABP mode.
| Write | at+set_config=lora:join_mode:<mode> | OK |
Parameter:
| mode | Activation mode 0: OTAA 1: ABP The default is OTAA. |
Example:
at+set_config=lora:join_mode:0\r\n
OK
<class>
This command is used to set the LoRaWAN class to Class A, Class B, or Class C.
| Write | at+set_config=lora:class:<class> | OK |
Parameter:
| class | 0: Class A 1: Class B (Not supported at this time) 2: Class C The default is Class A. |
Example:
at+set_config=lora:class:0\r\n
OK
<type>
This command is used to set the type messages to be sent: Confirmed/Unconfirmed.
| Write | at+set_config=lora:confirm:<type> | OK |
Parameter:
| type | 0: unconfirm type 1: confirm type The default is unconfirm type. |
Example:
at+set_config=lora:confirm:0\r\n
OK
<dr>
This command is used to set the data rate (DR) of LoRa.
| Write | at+set_config=lora:dr:<dr> | OK |
Parameter:
| dr | The data rate of LoRa is related to the current region. In most of the LoRa areas, it is common to use 0 to 5. Detailed reference can be made to LoRaWAN 1.0.2 specification. |
Example:
at+set_config=lora:dr:5\r\n
OK
<tx_power>
This command is used to set the RF transmission power level of the LoRa transceiver. The unit is in dBm.
| Write | at+set_config=lora:tx_power:<tx_power> | OK |
Parameter:
| tx_power | LoRa transmit power level varies depending on frequency band and DR. Refer to the LoRaWAN 1.0.2 specification or Appendix II for details. The default is 0. |
Example:
at+set_config=lora:tx_power:0\r\n
OK
<status>
This command is used to turn on/off the ADR feature of the LoRa communication.
| Write | at+set_config=lora:adr:<status> | OK |
Parameter:
| status | 0: Turn off 1: Turn on The default is on. |
Example:
at+set_config=lora:adr:1\r\n
OK
- at+get_config=lora:status
This command is used to get all the information related to the current LoRa status, except the channel information.
| Read | at+get_config=lora:status | OK <lora status detail> |
Parameter: NONE
Example:
at+get_config=lora:status\r\n
OK Work Mode: LoRaWAN
Region: EU868
Send_interval: 200s
Auto send status: true
Send_interval work at sleep
DutycycleEnable: false
Send_repeat_cnt: 0
Join_mode: OTAA
DevEui: 00662CA006D4F7E5
AppEui: 70B3D57ED003CBC5
AppKey: 72E181E4428C4F305827284D2FD54618
Class: A
Joined Network:true
IsConfirm: confirm
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 869525000, RX2_CHANNEL_DR:3
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 5
Primeval Datarate: 5
ChannelsTxPower: 0
UpLinkCounter: 2
DownLinkCounter: 0
<status>:<interval>
This command is used to set the time interval for sending data.
| Write | at+set_config=lora:send_interval:<status>:<interval> | OK |
Parameter:
| status | Enable/disable the mechanism for sending data in intervals. 0: the device will not send data automatically. 1: the device will send data every 'interval' seconds. |
| interval | Time in seconds. This parameter is only valid if 'status' is set to 1. |
Example:
at+set_config=lora:send_interval:1:120\r\n
OK
<mode>
This command is used to set the Working Mode:
| Write | at+set_config=lora:work_mode:<mode> | OK |
Parameter:
| mode | 0: LoRaWAN® 1: LoRaP2P 2: Test Mode. |
Example:
at+set_config=lora:work_mode:0\r\n
autosend_interval: 200s
Initialization OK
<status>
This command is used to enable or disable the Duty Cycle feature.
| Write | at+set_config=lora:dutycycle_enable:<status> | OK |
Parameter:
| status | 0: disable 1: enable The default is disable. |
Example:
at+set_config=lora:dutycycle_enable:1\r\n
OK
<IsEnable>
This commands is used to enable multicasting.
| Write | at+set_config=lora:multicastenable:<IsEnable> | OK |
Parameter:
| IsEnable | 0: disable 1: enable The default is disable. |
Example:
at+set_config=lora:multicastenable:1\r\n
OK
<multicast_dev_addr>
This command is used to set the Device Address for the multicast feature.
| Write | at+set_config=lora:multicast_dev_addr:<multicast_dev_addr> | OK |
Parameter:
| multicast_dev_addr | Multicast Device Address |
Example:
at+set_config=lora:multicast_dev_addr:260111fd\r\n
OK
<multicast_apps_key>
This command is used to set the Application Session Key for the multicast feature.
| Write | at+set_config=lora:multicast_apps_key:<multicast_apps_key> | OK |
Parameter:
| multicast_app_addr | Multicast Application Session Key |
Example:
at+set_config=lora:multicast_apps_key:F13DDFA2619B10411F02F042E1C0F356\r\n
OK
<multicast_nwks_key>
This command is used to set the Network Session Key for the multicast feature.
| Write | at+set_config=lora:multicast_nwks_key:<multicast_nwks_key> | OK |
Parameter:
| multicast_nwks_key | Multicast Network Session Key |
Example:
at+set_config=lora:multicast_nwks_key:1D1991F5377C675879C39B6908D437A6\r\n
OK
- set_config=lora:default_parameters
This command is used to restore the factory setting.
| Write | at+set_config=lora:default_parameters | OK |
Parameter: NONE
Example:
at+set_config=lora:default_parameters\r\n
OK
set_config=lora:periodic_rst_interval:
<time>
This command is used to set a periodic restart.
| Write | at+set_config=lora:periodic_rst_interval:<time> | OK |
Parameter:
| time | Time in seconds. |
Example:
at+set_config=lora:periodic_rst_interval:864000\r\n
interval_time=864000
OK
LoraP2P AT Command
<frequency>:<spreadfact>:<bandwidth>:<codingrate>:<preamlen>:<power>
This command is used to set the relevant parameters of LoRAP2p mode and is only valid when the LoRa mode was switched to LoRaP2P before.
| Write | at+set_config=lorap2p:<frequency>:<spreadfact>:<bandwidth>:<codingrate>:<preamlen>:<power> | OK |
Parameter:
| frequency | Frequency, the unit is Hz The default is 869525000Hz. |
| spreadfact | Spreading factor The default is 12. |
| bandwidth | 0: 125KHz 1: 250KHz 2: 500KHz The default is 0. |
| codeingrate | 1: 4/5 2: 4/6 3: 4/7 4: 4/8 The default is 1. |
| preamble | Preamble Length. 5~65535 The default is 8. |
| power | TX power. The unit is in dBm. 5~20 The default is 20. |
Example:
at+set_config=lorap2p:869525000:12:0:1:8:20\r\n
OK
<mode>
This command is used to switch the state of the LoRa transceiver between sending and receiving state, and it’s only valid when the LoRa mode was set to LoRaP2P before.
| Write | at+set_config=lorap2p: transfer_mode:<mode> | OK |
Parameter:
| mode | 1: receiver mode 2: sender mode The default is sender mode. |
Example:
at+set_config=lorap2p:transfer_mode:1\r\n
OK
at+send=lorap2p:
<data>
This command is used to send data through LoRaP2P, and only valid when the LoRa work mode was set to LoRaP2P before.
| Send | at+send=lorap2p:<data> | OK |
Parameter:
Example:
at+send=lorap2p:1234\r\n
OK
In LoRa P2P mode, the receiving node receives the data and outputs the data in the following format:
at+recv=<RSSI>,<SNR>,< Data Length >:< Data >
Appendix I: Data Rate by Region
EU433/EU868/AS923| Data Rate | Configuration | Indicative Physical Bit Rate [bit/s] |
| 0 | LoRa: SF12 / 125 kHz | 250 |
| 1 | LoRa: SF11 / 125 kHz | 440 |
| 2 | LoRa: SF10 / 125 kHz | 980 |
| 3 | LoRa: SF9 / 125 kHz | 1760 |
| 4 | LoRa: SF8 / 125 kHz | 3125 |
| 5 | LoRa: SF7 / 125 kHz | 5470 |
| 6 | LoRa: SF7 / 250 kHz | 11000 |
| 7 | FSK: 50 kbps | 50000 |
| 8 ~ 15 | RFU |
CN470/KR920
| 6 ~ 15 | RFU |
US915
| 0 | LoRa: SF10 / 125 kHz | 980 |
| 1 | LoRa: SF9 / 125 kHz | 1760 |
| 2 | LoRa: SF8 / 125 kHz | 3125 |
| 3 | LoRa: SF7 / 125 kHz | 5470 |
| 4 | LoRa: SF8 / 500 kHz | 12500 |
| 5 ~ 7 | RFU | |
| 8 | LoRa: SF12 / 500 kHz | 980 |
| 9 | LoRa: SF11 / 500 kHz | 1760 |
| 10 | LoRa: SF10 / 500 kHz | 3900 |
| 11 | LoRa: SF9 / 500 kHz | 7000 |
| 12 | LoRa: SF8 / 500 kHz | 12500 |
| 13 | LoRa: SF7 / 500 kHz | 21900 |
| 14 ~ 15 | RFU |
AU915
| 6 | LoRa: SF8 / 500 kHz | 12500 |
| 7 | RFU | RFU |
IN865
| 6 | RFU | RFU |
| 8 ~ 15 | RFU | RFU |
Appendix II: TX Power by Region
EU868By default, MaxEIRP is considered to be +16 dBm.
| TXPower | Configuration (EIRP) |
| 0 | MaxEIRP |
| 1 | MaxEIRP - 2 dB |
| 2 | MaxEIRP - 4 dB |
| 3 | MaxEIRP - 6 dB |
| 4 | MaxEIRP - 8 dB |
| 5 | MaxEIRP - 10 dB |
| 6 | MaxEIRP - 12 dB |
| 7 | MaxEIRP - 14 dB |
| 8 ~ 15 | RFU |
US915
| TXPower | Configuration (conducted power) |
| 0 | 30 dBm - 2*TXpower |
| 1 | 28 dBm |
| 2 | 26 dBm |
| 3 ~ 9 | |
| 10 | 10 dBm |
| 11 ~ 15 | RFU |
AU915
By default, MaxEIRP is considered to be +30 dBm.
| 0 | MaxEIRP |
| 1 ~ 10 | MaxEIRP - 2*TXPower |
| 11 ~ 10 | RFU |
KR920
By default, MaxEIRP is considered to be +14 dBm.
| 0 | MaxEIRP |
| 8 ~ 15 | RFU |
AS923
By default, Max EIRP shall be 16 dBm.
| 0 | MaxEIRP |
| 8 ~ 15 | RFU |
IN865
By default, MaxEIRP is considered to be 30 dBm.
| 0 | MaxEIRP |
| 8 | MaxEIRP - 16 dB |
| 9 | MaxEIRP - 18 dB |
| 10 | MaxEIRP - 20 dB |
| 11 ~ 15 | RFU |
CN470
By default, MaxEIRP is considered to be +19.15 dBm.
| 0 | MaxEIRP |
| 8 ~ 15 | RFU |
EU433
By default, MAxEIRP is considered to be +12.15 dBm.
| 0 | MaxEIRP |
| 6 ~ 15 | RFU |
Appendix III: Maximum Transmission Load by Region
M in the following list is the length with MAC header, N is the length without MAC header, and the maximum sending data length is N.
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
| 6 | 250 | 242 |
| 7 | 250 | 242 |
| 8 ~ 15 | Not Defined | Not Defined |
US915
| Data Rate | M | N |
| 0 | 19 | 11 |
| 1 | 61 | 53 |
| 2 | 133 | 125 |
| 3 | 250 | 242 |
| 4 | 250 | 242 |
| 5 ~ 7 | Not Defined | Not Defined |
| 8 | 61 | 53 |
| 9 | 137 | 129 |
| 10 | 250 | 242 |
| 11 | 250 | 242 |
| 12 | 250 | 242 |
| 13 | 250 | 242 |
| 14 ~ 15 | Not Defined | Not Defined |
AU915
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
| 6 | 250 | 242 |
| 8 | 61 | 53 |
| 9 | 137 | 129 |
| 10 | 250 | 242 |
| 11 | 250 | 242 |
| 12 | 250 | 242 |
| 13 | 250 | 242 |
KR920
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
| 6 ~ 15 | Not Defined | Not Defined |
AS923
| Data Rate | Uplink MAC Payload Size (M) | Downlink MAC Payload Size (M) | ||
| UplinkDwellTime = 0 | UplinkDwellTime = 1 | DownlinkDwellTime = 0 | DownlinkDwellTime = 1 | |
| 0 | 59 | N/A | 59 | N/A |
| 1 | 59 | N/A | 59 | N/A |
| 2 | 59 | 19 | 59 | 19 |
| 3 | 123 | 61 | 123 | 61 |
| 4 | 250 | 133 | 250 | 133 |
| 5 | 250 | 250 | 250 | 250 |
| 6 | 250 | 250 | 250 | 250 |
| 7 | 250 | 250 | 250 | 250 |
| 8 | RFU | RFU | ||
IN865
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
| 6 | 250 | 242 |
| 7 | 250 | 242 |
CN470
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
EU433
| Data Rate | M | N |
| 0 | 59 | 51 |
| 1 | 59 | 51 |
| 2 | 59 | 51 |
| 3 | 123 | 115 |
| 4 | 250 | 242 |
| 5 | 250 | 242 |
| 6 | 250 | 242 |
| 7 | 250 | 242 |
