Soil Moisture, Temperature, and Electrical Conductivity Solution LoRaWAN Network Server Guide
Figure 1: Application scenariosLoRaWAN Application
Cloud Network Server Setup
The cloud network server deployment scenario involves connecting the gateway and devices to third-party cloud network servers. This server integrates visualization applications to manage real-time soil moisture, temperature, and EC data.
Figure 1: Cloud Network Server Application FlowConnect Gateway to TTN
- Register the Gateway
- Register an account and log in to the TTN v3 website. If you already have a TTN account, you can log in using your The Things ID credentials.
Figure 1: Configure the Gateway frequencyYour gateway dashboard should look the same with Figure 7.
Figure 1: Successfully registered the gateway- Generate a Token
- To generate a key file, navigate to API keys from the Overview page of the registered gateway, then click Add API key.
Figure 1: Configure the API key- A new window pops up with the generated key. Copy the new API key by clicking the icon and then the I have copied the key button.
Figure 1: Copy and save the API keyConfigure the Gateway
- Navigate back to the gateway management platform Web UI. Click on the left navigation bar to access the LoRa > Configuration tab. Complete the following settings and save them.
- Server URL:
8887 - Authentication Mode: TLS server & Client Token - Authentication
- Trust (CA Certificate): Click the link to download.
Figure 1: Configure the Gateway- After saving the changes, return to the TTN gateway interface, and navigate to the Gateways tab to confirm that the gateway is now connected to TTNv3 as a Basics Station.
Figure 1: Gateway connected SuccessfullyConnect Sensor Hub to TTN
Figure 1: Select create an application- Click + Create application to initiate the creation of a node.
Figure 1: Fill in the Application ID field- Click on the + Register end device button to add a new end device to the application.
Figure 1: End device parameters- JoinEUI, DevEUI, and AppKey can be automatically generated by clicking Generate on the TTN web page. These parameters are customizable as well.
- After completing the settings, return to the WisToolBox app, and click JOIN NETWORK to send the end device network join request.
Figure 1: Successfully joined the TTNv3 networks serverVisualize Data Through Datacake
Create Datacake Integration
- In the TTN console, navigate to Integrations on the sidebar, proceed to the Webhooks section, and then click +Add webhooks to set up an integration.
Figure 1: Select the Datacake template- Generate an API key on Datacake to enable webhook authentication. To get started, register a Datacake account, and then log in.
Figure 1: Datacake IoT platform main page- Navigate to the Datacake workspace. Select Members on the sidebar, switch to the API Users tab, then click the Add API User button.
Figure 1: Set parameters- Click the Copy button to copy the generated Datacake API Token.
Figure 1: Create Datacake WebhookAdd Sensor Hub to Datacake
- To add a new device, select Devices in the sidebar and click the +Add Device button.
Figure 1: Add Device- Choose LoRaWAN from the options and click Next to proceed.
Figure 1: Select LoRaWAN- As the Sensor Hub is a new device, there is no pre-existing template. Create a template by clicking New Product, enter the Product Name, and click Next to proceed.
Figure 1: Create a new product- Choose a network server for your device. In this guide, select The Things Stack V3, then click Next to continue.
Figure 1: Registered DeviceCreate a Payload Decoder
Figure 1: Configuration tab
Figure 1: Decoder CodeClick to view the code
var decoded = {};
var str = bin2HexStr(bytes);
var i = 0;
while (i < str.length) {
var channelId = parseShort(str.slice(i, i + 4), 16);
var value = parseShort(str.slice(i + 4, i + 8), 16);
i += 8;
switch (channelId) {
case 0x0167:
decoded.temperature = value / 10.0;
break;
case 0x0270:
decoded.humidity = value / 10.0;
break;
case 0x03C0:
decoded.electric_conductivity = value / 1000.0;
break;
default:
break;
try {
decoded.lorawan_rssi = (port && port.metadata && port.metadata.rssi) || 0;
decoded.lorawan_snr = (port && port.metadata && port.metadata.snr) || 0;
decoded.lorawan_datarate = (port && port.metadata && port.metadata.data_rate) || '';
} catch (e) {
console.log('Failed to read gateway metadata');
return decoded;
function bin2HexStr(bytesArr) {
var str = '';
for (var i = 0; i < bytesArr.length; i++) {
var tmp = (bytesArr[i] & 0xff).toString(16);
if (tmp.length == 1) {
tmp = '0' + tmp;
str += tmp;
return str;
// convert string to short integer
function parseShort(str, base) {
var n = parseInt(str, base);
return (n << 16) >> 16;
// convert string to triple bytes integer
function parseTriple (str, base) {
var n = parseInt (str, base);
return (n << 8) >> 8;
- Displace the menu bar to the +Add Field section, and click +Add Field.
Figure 1: Add Field- The Add Field window appears. Fill out the fields shown in Figure 37 to configure the stored data in the device.
Figure 1: Configuration fields- Enter a suitable name in the Name field.
- When an uplink is received, refresh the page, and the CURRENT VALUE field will be updated.
- When completed, it will look the same, as shown in Figure 38.
Figure 1: Successfully added fieldsCreate a Dashboard
- To create a dashboard, click the edit mode switch on the Dashboard tab of the device on Datacake.
Figure 1: Add Visualization Widget- Select Value from the menu to create a new dashboard.
- In the Title field under the Basics tab, name the widget as Temperature.
Figure 1: Name the widget- Under the Data tab, click the Field tab dropdown arrow, select Temperature, and set the unit to °C.
Figure 1: Set the unit- Under the Gauge tab, select the gauge type and color, set the range of values for the widget, and then click Save.
Figure 1: Set the widget type- To add another widget, ensure the edit mode switch is ON, then click the +Add Widget button again.
Figure 1: Added Widget- When you finish adding the widgets, turn off the edit mode switch to save the edits.
Figure 1: Save the edits- Return to the WisToolBox APP, and click JOIN NETWORK to send the end device network access request. Once the request is successfully returned, the data will be uploaded within 60 seconds.
Figure 1: Send the end device network access requestBuilt-In Network Server Setup
Figure 1: Gateway Built-in Server Application FlowConfigure the ThingsBoard
- Log in to ThingsBoard. If you don't have an account, create one before proceeding.
Figure 1: Sign up ThingsBoard- After successfully logging in, you will be directed to the ThingsBoard homepage.
Figure 1: ThingsBoard homepage- Navigate through Integration center > Integrations > Data converters in the left navigation tree to create a data converter for the uplink.
Figure 1: Create a data converter for the uplink- Click the Add Data Converter icon and choose the Create new converter option.
Figure 1: Select Create new converter- Enter the name of the decoder in the Name field (for example, Uplink decoder), leave the Type field as Uplink, and select the JavaScript option.
Figure 1: Add Data Converter- Edit the decoder code by copying the following code into the edit box, then click Add to include the uplink decoder.
/** Decoder **/
// decode payload to string
var payloadStr = decodeToString (payload);
var bytes = atob(data).split('').map(function (c) {
return c.charCodeAt(0);
var values = {};
let i = 0;
while (i < bytes.length) {
var value = (bytes[i + 2] << 8) | bytes[i + 3];
i += 4;
case 0x0167:
values.temperature = value / 10.0;
break;
case 0x0270:
values.humidity = value / 10.0;
break;
case 0x03C0:
values.electric_conductivity = value / 1000;
break;
default:
break;
var deviceName = 'dev_ac1f09fffe0903ec';
var result = {
deviceName: deviceName,
attributes: {
temperature: values.temperature,
humidity: values.humidity,
pressure: values.electric_conductivity,
/** Helper functions **/
return String.fromCharCode.apply(String, payload);
return result;
- Navigate to the Integration Center > Integrations menu and click the Add Integration icon to add the MQTT integration.
Figure 1: Add the MQTT integration- Enter the name of the integration (for example, MQTT Integration) in the Name field and select MQTT in the Type drop-down menu. Click Next to continue.
Figure 1: Fill in the integration name- In the Uplink data converter options, click Select existing to choose the previously created decoder (Uplink Decoder), then click Next.
Figure 1: Select the created decoder- In the Downlink data converter interface, no configuration is necessary and just click Skip to bypass this setup.
- Configure connection options. Host is the MQTT broker address used for messages. The Host of the external MQTT broker used in this example is
broker.hivemq.com. You can choose to use other brokers with a different Host. - Enter the address
Figure 1: Configure the connection optionsConfigure the subscription topic
application/{{application_name}}/device/{{ device_EUI }}/join
application/{{application_name}}/device/{{device_EUI}}/rx
application/{{application_name}}/device/{{device_EUI}}/tx
application/{{application_name}}/device/{{device_EUI}}/ack
application/{{application_name}}/device/{{device_EUI}}/status
- Modify the parameter values corresponding to the topics based on the actual application created and the device used. After configuring the details, click the Add button to save and complete the settings.
Figure 1: Configure and add the subscription topicsConfigure the Gateway
Figure 1: WisGate OS Web Management Platform- After successfully logging in, navigate to the LoRa® menu in the left navigation tree and set the Work mode of the gateway to the Built-in network server.
Figure 1: Set the Work mode- Once done with the setting, click the Applications tab, then the Add application button. You can also click add one now text link to add a new application.
Figure 1: Applications tab- Configure the following information: Application name, Application description, and Application Type.
Figure 1: Configure the Application- After enabling the Auto Add Device option, configure the Application EUI option. The value needs to be consistent with the node value. Once you have verified the application EUI and key, the device will be added automatically to the application.
Figure 1: End Device Tab- Click the Add end device button. In the End device information interface, fill in the following information:
- Activation Mode: Select the activation mode of the device, OTAA or ABP.
- Class: Select Class A for device’s operating mode.
- LoRaWAN MAC Version: The protocol version (v1.0.3) of the end device.
Figure 1: Add new end devices-
After completing, click Add end devices to proceed to the next step.
In the Adding end devices interface, enter the device EUI in the End Device EUI (Main) field and select the Add to End Devices list button. Then click Add end devices to complete adding the end device.
Figure 1: Add the device to the device list- Click the Add button to confirm adding the device.
Figure 1: End Device CreatedConnect the Sensor Hub to the Built-In Network Server
Once completed, the device will join the network. As shown in Figure below, the end device SensorHub has successfully connected to the gateway's built-in server.
Figure 1: End Device SensorHub has been connectedConfigure the MQTT Integration
- Go to the LoRa® > Configuration > Integration Interface Parameters section.
- Toggle the Enable Integration Interface option and select Generic MQTT as the Integration mode.
Figure 1: Set Up MQTT Integration-
broker.hivemq.comthen click Save changes. -
Figure 1: Automatically created decoder device- Click the device and go to the Attributes tab, where you will see the node data.
Figure 1: Data Visualization- To visualize the data, simply select the values you wish to display, then click the Show on widget button.
Figure 1: Select the value- On the next page, select the desired widget for the data from the Current bundle drop-down menu. In this example, select Humidity.
Figure 1: Select widget for data- After selecting the widget, click Add to dashboard to proceed.
Figure 1: Selecting a widget- The Add widget to dashboard window will appear. By default, there is no dashboard in the profile, so you need to select Create new dashboard and enter a name for the dashboard in the new dashboard title field.
- In this guide, name the dashboard sensorhub_soil_multparam.
Figure 1: Enter the Dashboard name- After setting the dashboard name, click the Add button to add more widgets. Alternatively, check the Open dashboard option to automatically open the created dashboard after adding the widget.
If the Open dashboard option is not selected, you can still easily view the added widgets via Dashboard groups > All > [Group Name].
Figure 1: Dashboard created- You can visualize other data from the device following the same steps as above. The only difference is that when adding the widget, instead of Create a new dashboard, click Select existing dashboard.
Figure 1: Adding widgetsNB-IoT/LTE CAT-M1 Application
In the Network Server and Visualization Configuration section, the server has been set as a public MQTT broker: broker.hivemq.com. You can also choose other brokers or servers, such as AWS IoT Core (optional), according to the actual usage scenario.
Figure 1: NB-IoT LTE CAT-M1 Application ScenarioVisualize Data Through Datacake
Figure 1: Add the end device, SensorHub- Select the API option and click Next to proceed.
Figure 1: Keep the serial number- Select the preferred subscription plan, then click Add 1 device. For this example, choose Free.
Figure 1: Registered DeviceMQTT Configuration
Figure 1: Configuration Tab- Scroll down to the API Configuration option and copy the Serial number. Save it locally for later use.
Figure 1: Copy the serial number-
Figure 1: Configure the external MQTT broker- Fill in the relevant information based on the actual server used, then click Test Connection to verify whether Datacake can successfully connect to the MQTT Broker.
Figure 1: Configure the relevant parameters- After successfully adding the MQTT server, click on +Add Uplink Decoder to add a decoder.
Figure 1: Add Uplink decoder- A new window will appear, and fill in the fields according to your project.
var decoded = [];
var data = JSON.parse ( payload .replace (/\s*/g,"") );
for (var key in data) {
decoded. push (
device: "ddc5e012-30e4-4091-a050-b7318bacb209",
field: key,
value: data[key]
return decoded;
In the above code, make sure that the parameter serial_number (device: 9f05fd20-56b0-4eca-8549-fe544d783056) matches the serial number saved locally earlier.
- In the Fields option, click +Add Field to show the monitoring values of the devices. Each device can create a certain number of fields, also known as a data point.
Figure 1: Add Field- Set the necessary parameters of the Field. For Fields with multiple data points, add them one by one. Once done, click Add Field.
Figure 1: Added sensor monitoring valuesCreate a Dashboard to Visualize Data
- On the device details page, navigate to the Dashboard tab, then toggle on the edit mode switch.
- Click on the + Add Widget button to add a widget for visualizing data.
Figure 1: Open the edit mode- Choose what type of widgets you want to display. For this example, select Value to visualize temperature monitoring values.
Figure 1: Select and add widgets for visualizing data- Go to the Data tab and choose the data you want to visualize from the available Field options. For this example, select Temperature and set the unit of the field to °C.
Figure 1: Select the visualization data field- After configuring the widget, click Save. You should now see the successfully created Temperature widget on the Dashboard interface.
Figure 1: Successfully created Temperature widget-
To add more parameter widgets, click the +Add Widget button again with the edit mode toggle switch ON, then repeat Steps 3-5.
Once done with the dashboard configuration, turn off the edit mode switch to save the settings.
Figure 1: Weather Station data visualization
