RAK10701-P Field Tester Pro for LoRaWAN Quick Start Guide
Before going through each and every step in the installation guide of the RAK10701-P Field Tester Pro for LoRaWAN, make sure to prepare the necessary items listed below:
Hardware Tools
- RAK10701-P Field Tester Pro for LoRaWAN
- LoRa SubGHz Antenna with RP-SMA connector
- USB Type-C Cable
- Windows/Linux/macOS for PC or iOS/Android for mobile
Software Tools
WisToolBox for configuration and firmware update.
It is mandatory that you are within the coverage of the LoRaWAN Gateway of the network you are trying to join. Without the coverage, the Field Tester will not be useable.
