RAK612 WisNode Button AT Command Manual
The purpose of this section is to demonstrate on how to configure the LPWAN Button thru the use of AT Commands via a Serial Port Tool running in your Windows PC. The list below shows the AT Commands available for use:
| AT Command | Description |
at+version | Get the current firmware version. |
at+mode=0 | Set the LPWAN Button to work LoRaWAN mode. |
at+band=XXX | Set the region for LoRa. • XXX - one of the following items: EU868 EU433, CN470, IN865, EU868, AU915, US915, KR920, AS923. |
at+get_config=dev_eui | Check the current device EUI |
at+set_config=join_mode:X | Set the activation method • X - 0: ABP, 1: OTAA |
at+set_config=dev_eui:XXXX | Set the device EUI for OTAA. • XXXX - the device EUI. |
at+set_config=app_eui:XXXX | Set the application EUI for OTAA. • XXXX - the application EUI. |
at+set_config=app_key:XXXX | Set the application key for OTAA. • XXXX - the application key. |
at+set_config=dev_addr:XXXX | Set the device address for ABP. • XXXX - the device address. |
at+set_config=nwks_key:XXXX | Set the network session key for ABP. • XXXX - the network session key. |
at+set_config=apps_key:XXXX | Set the application session key for ABP. • XXXX - the application session key. |
at+set_config=timer_sleep:XX | The cycle time in seconds before the LPWAN Button will turn off since the last time you pressed any key • XX - time in seconds; 0 - the default value meaning that it will not power cycle. |
at+get_config=timer_sleep | Get the current sleep timer value. |
at+key_config=X,YY,ZZZZ | Customize the function of each key. • X - the number of the key that you want to customize • YY - the frame port where you are sending the data • ZZZZ - the actual data that you want to send when you press this specific key of the LPWAN Button. |
at+send=X | The type of data that you are sending. • X - 0: unconfirm, 1: confirm |
at+join=otaa | Join via OTAA. |
at+join=abp | Join via ABP. |
at+reset=0 | Restart the LPWAN Button. |
