Water Conductivity Monitoring Solution Quick Start Guide
Before proceeding with each step for using the Water Conductivity Solution, ensure that you have the necessary items.
Figure 1: Water Conductivity Solution Package InclusionHardware Tools
- Sensor Hub Water Conductivity Monitoring Solution
- Solar Battery Lite for Sensor Hub (optional)
- Additional accessories: Probe Cable, Probe Splitter, Power Supply, and others (numbers and variations depending on the use case)
Sensor Hub Setup
SIM Card Installation
If the selected solution uses the NB-IoT/LTE CAT-M wireless communication, follow these steps to insert a SIM card. If you choose the LoRaWAN wireless communication mode, skip this section, as a SIM card is not required.
Figure 1: Remove the back cover- Insert the SIM card in the groove, then gently push it into the card slot.
Wall Mounting
Figure 1: Installation preparation- Secure the mounting bracket to the wall by using self-tapping screws.
Figure 1: Secure the mounting bracket- Align the device's hanging tab with the slots on the bracket, then insert the tab into the slots. Pull the device downwards until it snaps into place.
- Fix the mounting bracket to the pole using a steel strip.
Figure 1: Fix the mounting bracketMount the bracket on a pole with a 50-80 mm diameter. For larger poles, use a bigger steel strap. The standard kit does not include a larger steel strap. Purchase separately if needed.
Figure 1: Fasten the device and the bracketRAK2560 WisNode Sensor Hub + Water Conductivity Sensor Setup
Sensor Probe IO + Water Conductivity Sensor Installation
The Water Conductivity Sensor comes pre-assembled with the Sensor Probe IO by default at the factory. Therefore, no additional assembly is necessary.
Figure 1: Insert the Cable Connector into the Sensor ConnectorSensor Hub + Sensor Probe IO + Water Conductivity Sensor Installation.
Connect the Sensor Probe IO to the SensorHub using the SP11 connector.
Align the white dot mark on the Sensor Probe IO SP11 connector plug with the white dot mark on the Sensor Hub SP11 connector socket and push the plug firmly into the socket.
Once connected, tighten the locking nut to secure the SP11 connector. The Sensor Probe IO can be linked to any Sensor Hub SP11 connector port. Refer to the actual use and connect to the appropriate port as illustrated in Figure 11.
Figure 1: Installation completedPower Supply Setup
The Sensor Hub relies on the Sensor Probe IO for connectivity to the water conductivity monitoring sensors. Consequently, it cannot be powered by batteries alone and requires a connection to either a solar panel or a 12 VDC power supply for operation.
- Secure the mounting bracket to the pole using two steel straps.
Figure 1: Secure the mounting bracket- Attach the mounting plate to RAK9154 using two (2) M3 screws.
Figure 1: Attach the mounting plate- Secure RAK9154 onto the back of the solar panel using four (4) screws and nuts..
Figure 1: Attach RAK9154 to solar panel- Connect the cable of the solar panel to the PV Input connector of RAK9154. Install two (2) M6 screws to the mounting plate and leave a gap of about 3 mm.
Figure 1: Connector the RAK9154- Suspend the solar panel on the mounting bracket, adjust its angle and direction, and then tighten the two (2) M6 screws along with the remaining two screws.
Figure 1: Install the solar panel combination- Connect the Sensor Hub to the RAK9154. Use a cable to link the remaining connection ports of the Sensor Hub to the lithium battery Output 1 SP11 connection port of the RAK9154.
Figure 1: Connect the Sensor Hub and RAK9154- Once the connection is complete, Sensor Hub is ready to be powered up.
- Connect the power adapter and the external power cable of the Sensor Hub through the circular DC interface.
Figure 1: Power Adapter Connection-
Connect the external power cable to the Sensor Hub through the SP11 connector.
Align the white dot symbol on the SP11 connector plug of the external power cable with the white dot mark on the Sensor Hub SP11 connector socket and push the plug firmly into the socket.
After the plug and socket are connected, tighten the locking nut to secure the SP11 connector. The external power cable can connect to any Sensor Hub connection port.
Figure 1: Connect the external power cableSoftware Configuration Guide
Sensor Hub Configuration
Power Up Sensor Hub
After installing all hardware, connect the power supply. If the power supply consists of a solar panel and a battery, the device will power on automatically once all hardware has been installed.
To prevent damage to the device, avoid powering up the Sensor Hub before connecting it to the sensor. For optimal performance, use the 12 VDC adapter provided with the Sensor Hub.
Figure 1: Start App- On the Select connection mode menu, choose NFC Activation.
Figure 1: Click on the CONNECT button- Hold your mobile device close to the N symbol on the Sensor Hub device.
Figure 1: Sync Device-
By default, if no connection is established within 30 seconds, the BLE broadcast of the Sensor Hub will automatically shut down. To establish a connection, connect the RAK device immediately after turning on the power or restart the power.
Certain Android smartphones may necessitate enabling GPS to connect to BLE. Enabling GPS does not involve the use or sharing of sensitive information with the app.
Figure 1: Uplink Settings option- Once configured, click SAVE SELECTION, and then the APPLY to implement the configuration options.
LoRaWAN Configuration
Refer to the Connect Gateway to TTN and Connect Sensor Hub to TTN sections for detailed instructions.
- Click the LORA & LORAWAN PARAMETERS tab. Configure the following parameters:
- Global settings
Figure 1: Global Settings-
Join mode: Configure the Join mode based on the device's network access mode: Over-The-Air Activation (OTAA) or Activation By Personalization (ABP). Make sure it matches the join mode registered on the network server.
Active region: Set the Active region to the device's frequency plan. Ensure that it is consistent with the gateway and device frequency plan registered on the network server.
Supported frequency bands: CN470, RU864, IN865, EU868, US915, AU915, KR920, AS923-1/2/3/4.
For the OTAA join mode, configure the following parameters: Application EUI, Application key, and Device EUI.
Figure 1: OTAA join mode configuration- Application EUI: Confirm that it matches the device's Application EUI as registered in the network server.
- Application key: Verify its alignment with the device's Application key registered in the network server. Click GENERATE KEY to create a new key if needed.
- Device EUI: Confirm that it matches the Device EUI registered in the network server.
For the ABP join mode, configure the required parameters: Application session key, Device address, and Network session key.
Figure 1: ABP join mode- Data on LoRa® network
Figure 1: Data on LoRa® network- Confirm mode: Message confirmation mode.
- Network status: Indicates the status of the network connection. It will activate automatically once connected to the network.
- ADR: The Adaptive Data Rate optimizes the data rates in the network. Toggle the button to enable and disable it.
- JOIN NETWORK: After completing the network parameter configuration, click the JOIN NETWORK button to run the join network command.
- After clicking JOIN NETWORK, a Message sent message will appear, indicating that the join network command has been sent.
Figure 1: Join the NetworkNB-IoT/LTE CAT-M1 Configuration
Figure 1: View the LTE-M Parameters tab- OPERATOR: shows the Network operator. If the operator's name is displayed (for example, CHINAMOBILE), it indicates that the device has recognized the SIM card.
- STATUS: if the status is Activated, it signifies that the network of the SIM card is functioning normally.
- Server address: Input the server address. Using the external MQTT broker as an example, enter
broker.hivemq.com. Enter the address based on your specific use case. - Server Port: Specify the server port according to your configuration.
- Publish Topic: Specify the topic for publishing messages.
Figure 1: Apply the modified configuration- When configured correctly and successfully connected to the server, the Connection Status will display as connected.
This section details the configuration process of the water conductivity sensor. It shows how to access the monitoring data and device details of the water conductivity sensor. Additionally, there’s an option to configure other information for each monitoring parameter, such as the uplink data sending period and threshold.
- To start with, click the SENSOR PROBE tab to display the connected water conductivity sensor.
Figure 1: Water Conductivity sensor- Click the dropdown to expand the details of the water conductivity sensor.
Figure 1: Sensor details- Temperature
- Electrical Conductivity
- Device details
Figure 1: Sensor details- Set the payload sensing interval of the water conductivity sensor.
Figure 1: Set the payload sensing interval- Sensor interval(s): The payload sending interval in seconds. It determines how often the sensor sends uplink data to the server, with a range interval from 60 ~ 86,400 seconds.
After completing the modifications, a message Commands in queue will appear at the bottom of the interface. Click APPLY to send the parameter update commands.
When the message All commands applied successfully appears on the interface, it indicates that the parameter update commands have been successfully sent.
Figure 1: Commands applied successfully- IMPORT SETTINGS
- REMOVE SENSOR PROBE: Detach the sensor.
- UPGRADE SENSOR PROBE: Update the firmware of the Sensor Probe.
