RAK10727 WisMesh Pocket V3 Datasheet
The RAK10727 WisMesh Pocket V3 is a ready-to-use handheld device designed for the Meshtastic LoRa® mesh network. It comes pre-flashed with Meshtastic firmware and integrates an nRF52840 MCU and an SX1262 LoRa transceiver directly into the mainboard.
The device features a 1.3-inch OLED display, a GNSS location module, and a 3-axis accelerometer. An integrated buzzer provides audible notifications during operation.
The hardware is housed in an injection-molded enclosure with an IP67 protection rating. It is powered by a built-in 3200 mAh rechargeable battery with NTC temperature monitoring, providing a portable solution for off-grid communication and location sharing.
| Feature | Specification |
| MCU | Nordic nRF52840 integrated directly into the mainboard |
| LoRa transceiver | Semtech SX1262 integrated directly into the mainboard |
| Frequency range | 860–930 MHz with a single hardware version |
| Connectivity | LoRa mesh communication through Meshtastic Bluetooth Low Energy (BLE) for smartphone pairing |
| Display | 1.3-inch OLED display |
| GPS/GNSS | Built-in AT6558 GNSS module for location tracking |
| Motion sensor | LIS2DH 3-axis accelerometer |
| Antennas | Built-in GNSS and Bluetooth antennas SMA connector for a LoRa antenna |
| Buttons | Reset, user, and power buttons |
| Status LEDs | Indicators for device status and charging |
| Buzzer | Maximum sound pressure level: 85 dB maximum current: 95 mA |
| Charging method | USB Type-C |
| Battery | 3200 mAh rechargeable battery with temperature monitoring IEC 62133-2:2017 certified |
| Power Supply | 5 V / 1 A |
| Operating Temperature | −20° C to 60° C |
| Enclosure Dimensions | 94.5 × 52 × 30 mm |
| Weight | 170 g |
| Certifications | FCC, CE |
Specifications
The WisMesh Pocket V3 comes fully assembled with a built-in 3200 mAh rechargeable battery. It comes pre-flashed with Meshtastic firmware and features three buttons, status LEDs, a 1.3-inch OLED display, and a USB Type-C port for charging.
Hardware Interface
Buttons
The WisMesh Pocket V3 features three buttons for device operation and navigation.
| Button | Function |
| User Button | Short press: Navigate through menu options. Long press ( >0.5 s ): Confirm a selection or open a menu. |
| Reset Button | Press once: Reset the device and restart the software. Press twice: Enter DFU mode for firmware flashing. |
| Power Button | Press and hold for 5 seconds: Turn on the device. Press and hold for 5 seconds again: Turn off the device. |
LED Indicators
The WisMesh Pocket V3 uses three LED indicators (red, green, and blue) to display charging status, device status, and message notifications.
| LED | Description |
| 🔴 RED LED | Charging |
| 🟢 GREEN LED | Solid: Device powered on Breathing: BLE DFU mode Blinking: MCU activity |
| 🔵 BLUE LED | New message received |
Buzzer
The WisMesh Pocket V3 features an integrated PWM buzzer for audible notifications.
| Parameter | Specification |
| Maximum Sound Pressure Level | 85 dB |
| Maximum Current | 95 mA |
USB Port
The USB Type-C port is used for battery charging, firmware flashing, and debugging. It is recommended to use a 5 V / 1 A USB charger to recharge the battery.
Antennas
The WisMesh Pocket V3 features integrated antennas for GNSS and Bluetooth connectivity. An external LoRa antenna connects through the SMA connector.
Dimensions and Enclosure
The WisMesh Pocket V3 features an injection-molded enclosure with an IP67 protection rating.
| Enclosure Type | Injection-molded |
| Protection Rating | IP67 |
| Dimensions (L × W × H) | 94.5 × 52 × 30 mm |
| Weight | 170 g |
Figure 1: WisMesh Pocket V3 DimensionsRF Characteristics
| LoRa Transceiver | Semtech SX1262 integrated directly into the mainboard |
| Frequency Range | 860–930 MHz with a single hardware version |
Electrical Characteristics
| Battery Capacity | 3200 mAh rechargeable battery with temperature monitoring IEC 62133-2:2017 certified |
| Charging Method | USB Type-C |
