RAK10727 WisMesh Pocket V3 Firmware Upgrade
The WisMesh Pocket V3 comes with Meshtastic firmware pre-installed. No firmware upgrade is required for initial use. To use the latest Meshtastic firmware, download the firmware and follow the steps below.
- WisMesh Pocket V3
- Computer with a USB port
- USB Type-C data cable
Firmware
Download the firmware from Meshtastic Downloads and extract its contents.
Use the WisMesh Pocket V3 firmware file:
firmware-rak_wismesh_pocket-w.x.yy.zzzzzzz.uf2
Select the firmware specifically built for the WisMesh Pocket V3. Do not use the RAK4631 firmware file.
Upgrading the Firmware
Step 1: Download the Firmware
Locate the WisMesh Pocket V3 .uf2 file in the extracted firmware package.
Step 2: Enter DFU Mode
- Power on the WisMesh Pocket V3.
- Connect it to the computer using a USB Type-C data cable.
- Press the Reset button twice to enter DFU mode.
The green LED displays a breathing pattern in DFU mode. A USB drive should appear on the computer.
Step 3: Install the Firmware
- After entering DFU mode, a USB drive should appear on your computer.
- Copy
firmware-rak_wismesh_pocket-w.x.yy.zzzzzzz.uf2to the USB drive, using the actual downloaded filename. - Wait for the file transfer to complete. The WisMesh Pocket V3 automatically restarts and runs the new firmware.
The USB drive may disappear when the firmware transfer is complete and the device restarts. This is normal.
Step 4: Verify the Upgrade
Check the firmware version in the device information on the Meshtastic app that is already connected to the WisMesh Pocket V3.
Resources
For detailed instructions on flashing or upgrading Meshtastic firmware on nRF52 devices, refer to the Meshtastic nRF52 Firmware Upgrade Guide.
