Gateway Management
In this section, you can manage all gateways within your organization, view their information and health status, configure WAN/LAN interfaces, manage system settings, monitor LoRaWAN communication metrics, and utilize diagnostic tools for troubleshooting.
Fleet-Level Gateway Management
This page offers a consolidated list of all gateways within the organization. You can manage them in bulk or take action on individual gateways, including direct access to their details.
To access the management console, click Gateways in the left navigation menu. You can use the search bar to find specific gateways or filter the list by Status, Location, and Columns for easier navigation.
Figure 1: Gateways- Current firmware: The version currently running on the gateway.
- Sent firmware: The target version sent by WisDM during an upgrade, indicating the version pending installation.
Status Indicators
| Icon | Description |
![]() | Online - The gateway is connected to the Internet and accessible through WisDM. It supports real-time operations, monitoring, and instant configuration or firmware updates. |
![]() | Offline - The gateway is not connected to the Internet and temporarily unavailable. Pending configurations and updates will be applied automatically once it reconnects. |
![]() | Provisioning - The gateway enters the provisioning status when it has an internet connection issue and cannot connect to WisDM properly. To resolve this, check and restore the internet connection. |
![]() | Pre-Provisioning - The gateway was added to the WisDM organization in the factory through pre-provisioning offering by RAK. |
![]() | Central gateway under a Location when the network server mode is set to Built-In network server. |
![]() | Warning indicator - Hover over the icon to view detailed warning information. |
![]() | Power disconnected - The gateway has lost power. Check the power supply. |
![]() | Update available - A newer firmware version is available for this gateway. |
![]() | Upgrading - A firmware upgrade is currently in progress. |
![]() | Firmware upgrade pending - The gateway did not upgrade successfully. |
![]() | Configuration mismatch - The configuration stored in WisDM (LoRaWAN settings, system settings, or network interface settings) does not match what is currently running on the gateway. |
Single Gateway Management
Operations available for an individual gateway include renaming, viewing details, assigning and unassigning, checking logs, running diagnostics, and deletion.
Rename the Gateway
You can rename a single gateway by clicking the edit icon
next to the gateway name in the Name column.
For detailed rules and requirements, see Rename Gateway.
Assign a Gateway
You can assign an unassigned gateway to a target Location. Supported states for assignment:
- Online
- Offline
- Pre-provisioning
- In the actions menu, click Assign to Location.
- Select the desired Location and click Use selected location.
Figure 1: Select a locationWhen selecting a Location, ensure the gateway's frequency settings match the target Location's region configuration.
- The system performs a pre-validation process (verifying frequency compatibility, identifier validity, and assignment status):
- If the gateway configuration is compatible with the target Location, it is listed under Available.
- If the configuration does not match, it is listed under Unavailable. Refer to the Status column for the specific validation result.
Figure 1: Adding GatewayIf the selected Location operates in Basics™ Station mode and Use individual client keys is enabled, the system displays the authentication status for the gateway. You must upload, retrieve, or skip the required credentials before proceeding.
- Click Add gateways. The gateway will then appear in the Location’s Gateways list.
Figure 1: Gateway listUnassign a Gateway
To remove a gateway from a location.
When unassigning a gateway:
- The gateway’s LoRaWAN configuration is reset to default values.
- Online gateways are reset immediately and remain online after the reset.
- Offline gateways are reset automatically. Once they reconnect, their status changes to Provisioning after being unassigned.
- If a gateway is in Pre-Provisioning status, the reset command is not sent.
- Keys, certificates, and tokens on the gateway are preserved for future use.
- For Built-in Network Server Locations:
- A Central Gateway cannot be unassigned while extenders are still present in the location.
- Extenders must be detached from the Central Gateway before finalizing unassignment.
- In the actions' menu, click Unassign Gateway.
- Confirm your choice in the dialog by clicking Unassign gateway.
Figure 1: Confirm unassign gatewayDelete a Gateway
You can delete a gateway from the actions menu in the Gateway List. For complete rules and behavior, see Delete Gateway.
Multiple Gateway Management
Select multiple gateways from the list to apply actions in bulk. This feature is useful for large-scale operations and saves time when managing fleets.
Figure 1: Manage Multiple GatewaysUnassign Gateways
For removing the gateways in bulk, follow these steps:
- Offline gateways are reset automatically. Once they reconnect, their status switches to Provisioning after being unassigned.
- A Central Gateway cannot be unassigned while extenders are still present in the Location.
- Select multiple target gateways from the list.
- Click Unassign.
- In the confirmation dialog, confirm your selection by clicking Unassign gateways.
Figure 1: Confirm unassign gatewaysReset Password
You can select multiple gateways in the Gateway List and reset their passwords in bulk. For rules and requirements, see Reset Gateway Password.
Synchronize System Settings
System settings are configured for each gateway. To expedite up configuration, you can synchronize system settings from a sample gateway to other selected gateways.
You can choose which settings to apply:
- Enable FOTA settings
- Time zone
- Log settings
- NTP server settings
- In the actions' menu, click Synchronize system settings.
- Select the specific system settings to sync.
- Choose the sample gateway whose settings you want to copy.
Figure 1: Synchronize system settings- Click Synchronize settings to apply.
- Gateways in Provisioning or Unassigned states are skipped.
- Offline assigned gateways will receive the new settings the next time they come online.
Rename Gateways
You can select multiple gateways for bulk renaming. Apply a common name prefix, and WisDM will automatically append sequential numbers (e.g., MyGateway_1, MyGateway_2).
Export Gateway Configuration Data (CSV)
Export information for the selected assigned gateways (including general info, system settings, and network interfaces) to a .csv file.
- Select multiple target gateways in the list.
- In the actions' menu, click Export CSV.
- Choose the data to include.
Figure 1: Export CSV- Click Export. The system will generate the file and send it to your email.
Delete Gateways
You can delete selected unassigned gateways in bulk. For complete rules and behavior, see Delete Gateway
Gateway Health & Statistics
This section presents key health indicators and performance statistics for the gateway, enabling visibility into system status and network activity.
All health indicators and statistical data in this section are synchronized from the gateway at approximately 10-minute intervals.
Gateway Overview
This section provides essential details about a single gateway, including its identity, activity, deployment, and health indicators.
Gateway Information
Figure 1: Device Details- Model: The specific hardware model of the gateway (e.g., RAK7289CV2).
- EUI (Extended Unique Identifier): A globally unique identifier for the gateway, used for registration and device identification.
- MAC Address: The gateway’s network interface hardware address used for Ethernet or Wi-Fi connectivity.
- Serial Number (SN): A unique identifier assigned by the manufacturer, printed on the physical device.
- Frequency Band: The operating frequency of the gateway, inherited from the assigned LoRa Network Configuration under the gateway’s location.
- Number of LoRa Channels: The count of supported LoRa channels count (typically 8 or 16, depending on the model). The channel count determines how many simultaneous LoRaWAN connections the gateway can manage, and is a key factor in assessing its network capacity.
Traffic Statistics
This section offers a brief overview of gateway activity, highlighting the number of received packets, transmitted packets, and connected end devices. It enables you to quickly assess network load and device connectivity.
Figure 1: Traffic StatisticsDeployment Location
WisDM allows you to visualize the physical placement of gateways on a map. The way location data is displayed depends on the status of each gateway:
Figure 1: Gateway Deployment LocationAssigned and Online
- With GPS module: Real-time GPS coordinates are displayed on the map, refreshed approximately every 10 minutes.
- Without GPS module but with manually configured static coordinates in the gateway UI: The configured static coordinates are displayed.
- Without GPS data or manual coordinates: The system defaults to the Location Address defined in WisDM as the deployment coordinates.
Unassigned or Offline
- Offline: The map shows the last known GPS coordinates, which will not update until the gateway comes back online.
- Unassigned: Even if the gateway is online, WisDM retains and displays only the last known GPS coordinates. No further updates are collected once the gateway is removed from its Location.
SD Card Status
WisDM allows you to monitor the presence and condition of the SD card installed in the gateway.
- SD card detected and functioning properly.
- No SD card detected in the slot. This typically indicates that no card is inserted or that the card is loose.
- SD card detected, but it is not functioning properly due to read/write errors.
System Performance
WisDM provides visibility into key system performance metrics for your gateway. In the Performance section, click View details to access additional information.
Figure 1: System Performance-
CPU: Displays the current processing load of the gateway's CPU.
This information helps you assess the device's workload and identify potential bottlenecks. Refer to the Gateway Configuration Notifications guide for instructions on configuring alerts when usage reaches critical levels.
- Normal load: 0%-65%
- Medium load: 65%-80%
- High load: 80%-90%
- Critical load: 90%-100%
Used Memory: Shows how much system memory (RAM) is currently being used.
Useful for monitoring performance and detecting potential issues caused by memory saturation saturation, such as high traffic or logging. Refer to the Gateway Configuration Notifications guide for instructions on configuring alerts when usage reaches critical levels.
- Medium load: 65%-75%
- High load: 75%-85%
- Critical load: 85%-100%
Online Since- Indicates the duration the gateway has been running since its last reboot.
This metrics helps monitor device stability and detect unexpected restarts.
Performance Statistics
The Performance Statistics section offers historical metrics and visual analytics of your gateway’s operation. It assists in monitoring trends, diagnosing issues, and evaluating overall performance.
Figure 1: Performance Statistics Dashboard- Channel Usage
Displays the frequency of each LoRa channel's occupancy within the selected time span, helping to identify congestion or uneven distribution across channels. - Uplink Traffic
Shows the volume of uplink packets over time, categorized by data rate (DR). This is useful for analyzing end-device transmission patterns. - Downlink Traffic
Tracks the number of downlink packets sent to devices, also categorized by data rate. - SNR & RSSI
Visualizes the quality and strength of received packets:- SNR (dB): Measures signal clarity.
- RSSI (dBm): Indicates signal strength.
- End Devices
Displays the number of active devices communicating with the gateway during the selected time period.
- You can adjust the time span (e.g., 2 hours, 12 hours) and refresh the charts as needed to view updated statistics as needed.
- Performance statistics are available only for online gateways and are based on historical data collected during the selected timeframe.
Solar Battery Monitoring
If your gateway supports a solar battery and is connected to it, you can monitor its status by navigating to Gateways > Select your gateway > Overview > Solar battery. The Solar battery details section will only be available only after monitoring is enabled.
Solar Battery Monitoring Setup
- In the Solar battery section, click Enable monitoring.
Figure 1: Solar battery- Confirm and click Enable monitoring again to activate it.
Figure 1: Confirm info- In Solar battery details, click Refresh or Resend to apply the updates to the gateway.
Figure 1: Apply the updatesPerformance Dashboard
Figure 1: Solar Battery PerformanceThis dashboard displays live parameters of the solar battery:
- Temperature: Current operating temperature of the battery.
- Voltage: Present voltage reading of the battery.
- State of Charge (SoC): Percentage of remaining battery capacity.
- Current: Charging or discharging current.
Battery operating modes:
- Charging: The battery is currently charging.
- Fully Charged: The battery is fully charged.
- Discharging: The battery is supplying power to the gateway.
Active Events
The solar battery generates events whenever its state changes. Active events indicate ongoing issues and are categorized to assess their impact on performance:
Figure 1: Active event overview- Protect: The system detects a critical condition that could cause damage and temporarily shuts off battery power. Normal operation resumes automatically once conditions stabilize.
- Fault: The system detects potential permanent damage to the battery and recommends immediate replacement.
- Warning: The system identifies an abnormal condition that may escalate, but the gateway continues to run on battery power.
You can click View event log to access the event history. The log allows you to filter records by event type (Protect, Fault, Warning), date, and status (Unread, Read, or All).
Figure 1: View event log
: Click to mark the event as Read.
: Click to mark the event as Unread.
: Hover to view additional details about the event history.
Battery Health
This section provides additional health and lifecycle information:
Figure 1: Battery Health- State of Health (SoH): The overall condition of the battery compared to its original capacity.
- Cycle times: The number of full charge-discharge cycles completed.
- Remaining capacity: The current available charge in mAh.
- Full-charge capacity: The maximum charge the battery can hold when fully charged.
- Battery working mode: The current operational mode (Charging, Fully Charged, Discharging).
Network Interface Management
To ensure a stable and continuous Internet connection, WisDM gateways support multiple network interfaces through a feature called Multi-WAN. This feature allows the gateway to maintain an online presence automatically switching between available connections based on defined priorities.
Each WisDM-compatible gateway can support up to three types of Internet connections, which can be configured simultaneously:
- Ethernet: A connection provided via an Ethernet cable (default port type: WAN).
- Wi-Fi: A connection established through a wireless Wi-Fi network.
- Cellular: A connection provided via a SIM card using the cellular network (available on models equipped with a cellular module).
How Multi-WAN Works
- Automatic failover: Multi-WAN monitors all enabled interfaces and switches to the next available one if the primary connection becomes unavailable.
- Priority-based switching: The order of interfaces is user-defined, allowing control over which connection is preferred.
- High availability: The gateway remains online as long as at least one interface is active. It only goes offline when all enabled interfaces lose connectivity.
- Network interfaces are configured per gateway. However, to streamline the process and apply settings in bulk, you can use the Synchronize Network Interface Settings feature.
- Network interface status information is synchronized from the gateway at approximately 10-minute intervals.
Interface Priority
You can establish the priority order of network interfaces.
- Navigate to Gateways > Select a gateway > Network interface > WAN, then click Edit.
Figure 1: Network interfaces- Use the arrows (
) to adjust priority.
Figure 1: Configure network priorities-
Up arrow: Increases priority.
Down arrow: Decreases priority.
- Click Save priorities to apply the changes. The new configuration will be sent to the gateway.
Figure 1: Apply updatesIf priority updates are not applied within 3 minutes, you can either Delete pending changes (which will keep the gateway's existing configuration) or Resend them.
