Barometric Pressure Monitoring Solution LoRaWAN Network Server
Figure 1: Application ScenariosLoRaWAN Application
Cloud Network Server Setup
The cloud network server deployment scenario involves connecting the gateway and devices to third-party cloud network servers. This server integrates visualization applications to manage real-time barometric pressure data.
- Register the Gateway
- Register an account and log in to the TTN v3 website. If you already have a TTN account, you can log in using your The Things ID credentials.
Figure 1: Configure the gateway frequencyYour gateway dashboard should look the same with Figure 7.
Figure 1: Successfully registered the gatewayGenerate a Token
- To generate a key file, navigate to API keys from the Overview page of the registered gateway, then click Add API key.
Figure 1: Copy and save the API KeyConfigure the Gateway
- Navigate back to the gateway management platform Web UI. Click on the left navigation bar to access the LoRa > Configuration tab. Complete the following settings and save them.
- Server URL:
8887 - Authentication Mode: TLS server & Client Token - Authentication
- Trust (CA Certificate): Click the link to download.
Figure 1: Select Create application- Click + Create application to initiate the creation of a node.
Figure 1: Enter the application ID- Click on the + Register end device button to add a new end device to the application.
- After completing the settings, return to the WisToolBox app, and click JOIN NETWORK to send the end device network join request.
Create Datacake Integration
- In the TTN console, navigate to Integrations on the sidebar, proceed to the Webhooks section, and then click +Add webhooks to set up an integration.
Figure 1: Select the Datacake template- Generate an API key on Datacake to enable webhook authentication. To get started, register a Datacake account, and then log in.
Figure 1: Log in to the Datacake IoT platform- Navigate to the Datacake workspace. Select Members on the sidebar, switch to the API Users tab, then click the Add API User button.
Figure 1: Create the Datacake WebhookAdd Sensor Hub to Datacake
- To add a new device, select Devices in the sidebar and click the +Add Device button.
Figure 1: Add a Device- Choose LoRaWAN from the options and click Next to proceed.
Figure 1: Choose LoRaWAN connectivity- As the Sensor Hub is a new device, there is no pre-existing template. Create a template by clicking New Product, enter the Product Name, and click Next to proceed.
Figure 1: Registered deviceCreate a Payload Decoder
Figure 1: Configuration tab
Figure 1: Decoder codeClick to view the code
function lppDecode (bytes) {
var sensor_types = {
0: { 'size': 1, 'name': ' digital_in ', 'signed': false, 'divisor': 1 },
1: { 'size': 1, 'name': ' digital_out ', 'signed': false, 'divisor': 1 },
2: { 'size': 2, 'name': ' analog_in ', 'signed': true, 'divisor': 100 },
3: { 'size': 2, 'name': ' analog_out ', 'signed': true, 'divisor': 100 },
100: { 'size': 4, 'name': 'generic', 'signed': false, 'divisor': 1 },
101: { 'size': 2, 'name': 'illuminance', 'signed': false, 'divisor': 1 },
102: { 'size': 1, 'name': 'presence', 'signed': false, 'divisor': 1 },
103: { 'size': 2, 'name': 'temperature', 'signed': true, 'divisor': 10 },
104: { 'size': 1, 'name': 'humidity', 'signed': false, 'divisor': 1 },
112: { 'size': 2, 'name': ' humidity_prec ', 'signed': true, 'divisor': 10 },
113: { 'size': 6, 'name': 'accelerometer', 'signed': true, 'divisor': 1000 },
115: { 'size': 2, 'name': 'barometer', 'signed': false, 'divisor': 10 },
116: { 'size': 2, 'name': 'voltage', 'signed': false, 'divisor': 100 },
117: { 'size': 2, 'name': 'current', 'signed': false, 'divisor': 1000 },
118: { 'size': 4, 'name': 'frequency', 'signed': false, 'divisor': 1 },
120: { 'size': 1, 'name': 'percentage', 'signed': false, 'divisor': 1 },
121: { 'size': 2, 'name': 'altitude', 'signed': true, 'divisor': 1 },
125: { 'size': 2, 'name': 'concentration', 'signed': false, 'divisor': 1 },
128: { 'size': 2, 'name': 'power', 'signed': false, 'divisor': 1 },
130: { 'size': 4, 'name': 'distance', 'signed': false, 'divisor': 1000 },
131: { 'size': 4, 'name': 'energy', 'signed': false, 'divisor': 1000 },
132: { 'size': 2, 'name': 'direction', 'signed': false, 'divisor': 1 },
133: { 'size': 4, 'name': 'time', 'signed': false, 'divisor': 1 },
134: { 'size': 6, 'name': ' gyrometer ', 'signed': true, 'divisor': 100 },
135: { 'size': 3, 'name': ' colour ', 'signed': false, 'divisor': 1 },
136: { 'size': 9, 'name': ' gps ', 'signed': true, 'divisor': [10000, 10000, 100] },
137: { 'size': 11, 'name': ' gps ', 'signed': true, 'divisor': [1000000, 1000000, 100] },
138: { 'size': 2, 'name': ' voc ', 'signed': false, 'divisor': 1 },
142: { 'size': 1, 'name': 'switch', 'signed': false, 'divisor': 1 },
188: { 'size': 2, 'name': ' soil_moist ', 'signed': false, 'divisor': 10 },
190: { 'size': 2, 'name': ' wind_speed ', 'signed': false, 'divisor': 100 },
191: { 'size': 2, 'name': ' wind_direction ', 'signed': false, 'divisor': 1 },
192: { 'size': 2, 'name': ' soil_ec ', 'signed': false, 'divisor': 1000 },
193: { 'size': 2, 'name': ' soil_ph_h ', 'signed': false, 'divisor': 100 },
194: { 'size': 2, 'name': ' soil_ph_l ', 'signed': false, 'divisor': 10 },
195: { 'size': 2, 'name': 'pyranometer', 'signed': false, 'divisor': 1 },
203: { 'size': 1, 'name': 'light', 'signed': false, 'divisor': 1 },
function arrayToDecimal (stream, is_signed , divisor) {
var value = 0;
for (var i = 0; i < stream.length ; i ++) {
if (stream[ i ] > 0xFF)
throw 'Byte value overflow!';
value = (value << 8) | stream[ i ];
if ( is_signed ) {
var edge = 1 << ( stream.length ) * 8; // 0x1000..
var max = (edge - 1) >> 1; // 0x0FFF.. >> 1
value = (value > max) ? value - edge : value;
value /= divisor;
return value;
var sensors = [];
var i = 0;
while ( i < bytes.length ) {
var s_no = bytes[ i ++];
var s_type = bytes[ i ++];
if ( typeof sensor_types [ s_type ] == 'undefined') {
throw 'Sensor type error!: ' + s_type ;
var s_value = 0;
var type = sensor_types [ s_type ];
switch ( s_type ) {
case 113: //Accelerometer
case 134: // Gyrometer
s_value = {
'x': arrayToDecimal ( bytes.slice ( i + 0, i + 2), type.signed , type.divisor ),
'y': arrayToDecimal ( bytes.slice ( i + 2, i + 4), type.signed , type.divisor ),
'z': arrayToDecimal ( bytes.slice ( i + 4, i + 6), type.signed , type.divisor )
break;
case 136: // GPS Location
s_value = {
'latitude': arrayToDecimal ( bytes.slice ( i + 0, i + 3), type.signed , type.divisor [0]),
'longitude': arrayToDecimal ( bytes.slice ( i + 3, i + 6), type.signed , type.divisor [1]),
'altitude': arrayToDecimal ( bytes.slice ( i + 6, i + 9), type.signed , type.divisor [2])
break;
case 137: // Precise GPS Location
s_value = {
'latitude': arrayToDecimal ( bytes.slice ( i + 0, i + 4), type.signed , type.divisor [0]),
'longitude': arrayToDecimal ( bytes.slice ( i + 4, i + 8), type.signed , type.divisor [1]),
'altitude': arrayToDecimal ( bytes.slice ( i + 8, i + 11), type.signed , type.divisor [2])
sensors.push ({
'channel': s_no ,
'type': s_type ,
'name': 'location',
'value': "(" + s_value.latitude + "," + s_value.longitude + ")"
sensors.push ({
'channel': s_no ,
'type': s_type ,
'name': 'altitude',
'value': s_value.altitude
break;
case 135: // Color
s_value = {
'r': arrayToDecimal ( bytes.slice ( i + 0, i + 1), type.signed , type.divisor ),
'g': arrayToDecimal ( bytes.slice ( i + 1, i + 2), type.signed , type.divisor ),
'b': arrayToDecimal ( bytes.slice ( i + 2, i + 3), type.signed , type.divisor )
break;
default: // All the rest
s_value = arrayToDecimal ( bytes.slice ( i , i + type.size ), type.signed , type.divisor );
break;
sensors.push ({
'channel': s_no ,
'type': s_type ,
'name': type.name,
'value': s_value
i += type.size ;
return sensors;
// For TTN, Helium and Datacake
function Decoder(bytes, fport ) {
// bytes = input.bytes ;
// fPort = input.fPort ;
// flat output (like original decoder):
var response = {};
lppDecode (bytes, 1). forEach (function (field) {
response[field['name'] + '_' + field['channel']] = field['value'];
// Enable only for Datacake
response['LORA_RSSI'] = (!! normalizedPayload.gateways && !! normalizedPayload.gateways [0] && normalizedPayload.gateways [0]. rssi ) || 0;
response['LORA_SNR'] = (!! normalizedPayload.gateways && !! normalizedPayload.gateways [0] && normalizedPayload.gateways [0].snr) || 0;
response['LORA_DATARATE'] = normalizedPayload.data_rate ;
return response;
- Displace the menu bar to the +Add Field section, and click +Add Field.
Figure 1: Add Field- The Add Field window appears. Fill out the fields shown in Figure 37 to configure the stored data in the device.
Figure 1: Configuration fields- Enter a suitable name in the Name field.
- When an uplink is received, refresh the page, and the CURRENT VALUE field will be updated.
- Repeat the above steps to add the Temperature field. Once completed, it should look like the example shown in Figure 38.
Figure 1: Successfully added fieldsCreate a Dashboard
- To create a dashboard, toggle the edit mode switch on the device Dashboard tab.
- In the Title field under the Basics tab, name the widget, for example, Barometric Pressure.
Figure 1: Name the Widget- Under the Data tab, pull down the Field tab bar, select Barometric Pressure, and set the unit to hPa.
Figure 1: Setting Parameters- Under the Gauge tab, select the gauge type and color, set the range of values for the widget, and then click Save.
Figure 1: Set Gauge- When you finish adding the widgets, turn off the edit mode switch to save the edits.
Figure 1: Added WidgetBuilt-In Network Server Setup
Figure 1: Gateway built-in NS application scenarioConfigure ThingsBoard
- Log in to ThingsBoard. If you don't have an account, create one before proceeding.
Figure 1: ThingsBoard Homepage- Navigate through Integration center > Integrations > Data converters in the left navigation tree to create a data converter for the uplink.
Figure 1: Create a Data Converter- Click the Add Data Converter icon and choose the Create new converter option.
Figure 1: Create a new Converter- Enter the name of the decoder in the Name field (for example, Uplink decoder), leave the Type field as Uplink, and select the JavaScript option.
Figure 1: Add the decoder code- Edit the decoder code by copying the following code into the edit box, then click Add to include the uplink decoder.
/** Decoder **/
//decode payload to string
var payloadStr = decodeToString (payload);
var data = JSON.parse ( payloadStr ).data;
var bytes = atob (data).split('').map(function (c) {
return c.charCodeAt (0);
var values = {};
let i = 0;
var channelId = (bytes[ i ] << 8) | bytes[ i + 1];
var value;
switch ( channelId ) {
case 0x0367:
value = (bytes[ i + 2] << 8) | bytes[ i + 3];
values.temperature = value / 10.0;
i += 4;
break;
case 0x0473:
values.pressure = value / 10.0;
i += 4;
break;
default:
break;
var deviceName = ' rak1902 ';
var result = {
deviceName : deviceName ,
attributes: {
integrationName : metadata[' integrationName '],
temperature: values.temperature ,
pressure: values.pressure ,
/** Helper functions **/
function decodeToString (payload) {
return String.fromCharCode.apply (String, payload);
return result;
return String. fromCharCode. apply (String, payload);
return result;
In the above code, the word rak1902 marked is the device ID, which is the device name. This parameter must match the device name added in section Configure the Gateway. In this example, it is rak1902.
- Navigate to the Integration Center > Integrations menu and click the Add Integration icon to add the MQTT integration.
Figure 1: Add the MQTT Integration- Enter the name of the integration (for example, MQTT Integration) in the Name field and select MQTT in the Type drop-down menu. Click Next to continue.
Figure 1: Basic Settings- In the Uplink data converter options, click Select existing to choose the previously created decoder (Uplink Decoder), then click Next.
Figure 1: Select the created decoder- In the Downlink data converter interface, no configuration is necessary and just click Skip to bypass this setup.
Figure 1: WisGate OS Web Management Platform-
Enter the address
Figure 1: Configure the connection options
Configure the subscription topic
application/{{application_name}}/device/{{ device_EUI }}/join
application/{{application_name}}/device/{{ device_EUI }}/ rx
application/{{application_name}}/device/{{ device_EUI }}/ tx
application/{{application_name}}/device/{{ device_EUI }}/ack
application/{{application_name}}/device/{{ device_EUI }}/status
- Modify the parameter values corresponding to the topics based on the actual application created and the device used.
Figure 1: Configure and add the subscription topics- After configuring the details, click on Add to save and complete the settings.
Figure 1: Configuration completedConfigure the Gateway
Figure 1: WisGate OS Web Management Platform- After successfully logging in, navigate to the LoRa® menu in the left navigation tree and set the Work mode of the gateway to the Built-in network server.
Figure 1: Applications Tab- Configure the following information: Application name, Application description, and Application Type.
Figure 1: Configure the Application key- After enabling the Auto Add Device option, configure the Application EUI option. The value needs to be consistent with the node value. Once you have verified the application EUI and key, the device will be added automatically to the application.
- Separate Application keys: Each device has its own application key. Add the key when registering the device.
Figure 1: Add Application Key-
Figure 1: End Devices Tab- Click the Add end device button. In the End device information interface, fill in the following information:
- Class: Select Class A for device’s operating mode.
- LoRaWAN MAC Version: The protocol version (v1.0.3) of the end device.
Figure 1: Add the device to the device list- In the Adding end devices interface, enter the device EUI in the End Device EUI (Main) field and select the Add to End Devices list button. Then click Add end devices to complete adding the end device.
Connect the Sensor Hub to the Built-In Network Server
Once completed, the device will join the network. As shown in Figure 70, the end device SensorHub has successfully connected to the gateway's built-in server.
Figure 1: End device SensoHub has been connectedConfigure the MQTT Integration
Go to the LoRa® > Configuration > Integration Interface Parameters section.
Toggle the Enable Integration Interface option and select Generic MQTT as the Integration mode.
broker.hivemq.comthen click Save changes. -
Figure 1: Automatically created decoder device- Click the device and go to the Attributes tab, where you will see the node data.
Figure 1: Node data-
To visualize the data, simply select the values you wish to display, then click the Show on widget button.
On the next page, choose the desired widget for your data from the Current bundle drop-down menu. In this example, select Outdoor Environment, and then select the appropriate visualization chart for the Barometer by clicking the slide icon.
Figure 1: Select Widget- After selecting the widget, click Add to dashboard to proceed.
By default, the profile does not have a dashboard, so you need to select Create new dashboard and enter a name for the dashboard in the New dashboard title field, for example, Sensor Hub.
Figure 1: Enter the dashboard name- After setting the name of the dashboard, click the Add button to add more widgets. Alternatively, check the Open dashboard option to automatically open the created dashboard after adding the widget.
Figure 1: Dashboard created- If the Open dashboard option is not selected, you can still easily view the added widgets via Dashboard groups > All > [Group Name].
- Click the Edit mode icon in the upper right corner to set the appropriate name and unit of Pressure.
- The ThingsBoard visualization dashboard editor allows you to adjust the size and shape of widgets by dragging the edges of the widgets in the Edit mode.
- If the above settings are correct, the final visualization widget on the Dashboard should resemble Figure 79.
Figure 1: Dashboard createdFollow the previous steps to add the Temperature data if you need to monitor this variable as well.
NB-IoT/LTE CAT-M1 Application
In the Network Server and Visualization Configuration section, the server has been set as a public MQTT broker: broker.hivemq.com. You can also choose other brokers or servers, such as AWS IoT Core (optional), according to the actual usage scenario.
Figure 1: NB-IoT/LTE CAT-M1 application scenarioVisualize Data Through Datacake
Figure 1: Devices Page- Select the API option and click Next to proceed.
Figure 1: Add Devices- Select the preferred subscription plan, then click Add 1 device. For this example, choose Free.
Figure 1: Copy the serial number-
Figure 1: Configure the external MQTT Broker- Fill in the relevant information based on the actual server used, then click Test Connection to verify whether Datacake can successfully connect to the MQTT Broker. The information shown in Figure 89 is just an example.
Figure 1: Connection established successfully- After successfully adding the MQTT server, click on +Add Uplink Decoder to add a decoder.
Figure 1: Add MQTT Server- A new window will appear, and fill in the fields according to your project.
var decoded = [];
var data = JSON.parse ( payload.replace (/\s*/g,""));
for (var key in data) {
decoded.push (
device: "e2517219-bc32-482c-af3f-dbc95200adce" ,
field: key,
value: data[key]
return decoded;
In the above code, make sure that the parameter serial_number (device: e2517219-bc32-482c-af3f-dbc95200adce) matches the serial number saved locally earlier.
- In the Fields option, click + Add Field to show the monitoring values of the devices. Each device can create a certain number of fields, also known as a data point.
Figure 1: Add Field- Set the necessary parameters of the Field. For Fields with multiple data points, add them one by one. Once done, click Add Field.
- Once the uplink data is received, the Current Value column in the Fields list will display the current monitoring value from the sensor.
Figure 1: Added sensor monitoring valuesCreate a Dashboard to Visualize Data
- On the device details page, navigate to the Dashboard tab, then toggle on the edit mode switch.
- Click on the + Add Widget button to add a widget for visualizing data.
Figure 1: Open the edit mode- Choose what type of widgets you want to display. For this example, select Value to visualize the Barometric Pressure values.
Figure 1: Select and add widgets for visualizing data- Click on the Data tab. Choose the field for visualization from the Field options and set the unit of the field, which is hPa in this example.
Figure 1: Select the visualization data field-
Repeat the above steps to add the Temperature field. After configuring the widgets, click Save.
Once done with the dashboard configuration, turn off the edit mode switch to save the settings.
Figure 1: Barometric Pressure data visualization
