Environmental and Barometric Monitoring Solution Quick Start Guide
Before proceeding with each step for using the Environmental and Barometric Monitoring Solution, make sure to have all the necessary items listed below:
Figure 1: Environmental and Barometric Solution Package InclusionHardware Tools
- Environmental and Barometric Monitoring Solution
- Solar Battery Lite for Sensor Hub (optional)
Sensor Hub Setup
SIM Card Installation
If the selected solution uses the NB-IoT/LTE CAT-M wireless communication mode, follow these steps to insert a SIM card. If you opt for the LoRaWAN wireless communication mode, skip this section, as a SIM card is not required.
Figure 1: Insert a SIM card Sensor Hub Mounting
Wall Mounting
Figure 1: Installation preparation- Secure the mounting bracket to the wall by using self-tapping screws.
- Secure the mounting bracket to the pole using a steel strap.
Figure 1: Fix the mounting bracketMount the bracket on a pole with a 50-80 mm diameter. For larger poles, use a bigger steel strap. The standard kit does not include a larger steel strap. Purchase separately if needed.
Figure 1: Fasten the device and the bracketRAK2560 WisNode Sensor Hub + Environmental and Barometric Monitoring Sensor Setup
Sensor Probe + Environmental and Barometric Monitoring Sensor Installation
The RAK1901 temperature and humidity sensor and the RAK1902 barometric pressure monitoring sensor comes pre-assembled with the Sensor Probe by default at the factory, so no additional assembly is required.
Figure 1: SensorHub and Sensor ProbePower Supply Setup
SensorHub supports three power supply methods: battery power, connection to a solar panel or a 12 VDC power supply.
- Secure the mounting bracket on the pole with two steel straps.
Figure 1: Secure the mounting bracket- Attach the mounting plate to the RAK9154 with two (2) M3 screws.
Figure 1: Attach the mounting plate- Install the RAK9154 to the back of the solar panel with four (4) screws and nuts.
Figure 1: Attach RAK9154 to solar panel- Connect the cable of the solar panel to the PV input connector of RAK9154. Install two (2) M6 screws to the mounting plate with a clearance of about 3 mm.
Figure 1: Connector the RAK9154- Suspend the solar panel on the mounting bracket, adjust its angle and direction, and then tighten the two (2) M6 screws along with the remaining two screws.
Figure 1: Install the solar panel combination- Connect Sensor Hub and RAK9154. Use a cable to link the remaining connection port of the Sensor Hub to the lithium battery Output 1 SP11 connection port of RAK9154.
Figure 1: Connect the Sensor Hub and RAK9154- Once the connection is complete, the Sensor Hub is ready to be powered up.
- Connect the power adapter to the external power cable of Sensor Hub using a circular DC connector.
Figure 1: Power Adapter Connection- Connect the external power cable to the Sensor Hub using the SP11 connector.
- Align the white dot mark on the SP11 connector plug of the external power cable with the white dot mark on the Sensor Hub SP11 connector socket, and push the plug firmly into the socket.
- After the plug and socket are connected, tighten the locking nut to secure the connection of the SP11 connector. The external power cable can connect to any Sensor Hub connection port.
Figure 1: Connect the external power cableSoftware Configuration Guide
Sensor Hub Configuration
Power Up Sensor Hub
Figure 1: Start App- On the Select connection mode menu, choose NFC Activation.
Figure 1: Click on the CONNECT button- Hold your mobile device close to the N symbol on the Sensor Hub device.
Figure 1: Uplink Settings option- Once configured, click SAVE SELECTION, and then the APPLY button to implement the configuration options.
LoRaWAN Configuration
- Click the LORA & LORAWAN PARAMETERS tab. Configure the following parameters:
- Global settings
Figure 1: Global Settings- Join mode: Configure the Join mode based on the device's network access mode: Over-The-Air Activation (OTAA) or Activation By Personalization (ABP). Make sure it matches the join mode registered on the network server.
- Active region: Set the Active region to the device's frequency plan. Ensure that it is consistent with the gateway and device frequency plan registered on the network server.
LoRaWAN keys, ID, EUI-
For the OTAA join mode, configure the following parameters: Application EUI, Application key, and Device EUI.
Figure 1: OTAA join mode configuration- Application EUI: Confirm that it matches the device's Application EUI as registered in the network server.
- Application key: Verify its alignment with the device's Application key registered in the network server. Click GENERATE KEY to create a new key if needed.
- Device EUI: Confirm that it matches the Device EUI registered in the network server.
For the ABP join mode, configure the following parameters: Application session key, Device address, and Network session key.
Data on LoRa® network
Figure 1: Data on LoRa network- Confirm mode: Message confirmation mode.
- After clicking JOIN NETWORK, a Message sent message will appear, indicating that the join network command has been sent.
Figure 1: Join the NetworkNB-IoT/LTE CAT-M1 Configuration
Figure 1: View the LTE-M Parameters tab- OPERATOR: Shows the Network operator. If the operator's name is displayed, it indicates that the device has recognized the SIM card. For example, CHINAMOBILE.
- Server address: Input the server address. Using the external MQTT broker as an example, enter
broker.hivemq.com. Enter the address based on your specific use case. - Server Port: Specify the server port according to your configuration.
- Publish Topic: Specify the topic for publishing messages.
Figure 1: Apply the modified configuration- When configured correctly and successfully connected to the server, the Connection Status will display as connected.
This section details the configuration process of the RAK1901 temperature and humidity sensor and RAK1902 barometric pressure sensor. You can view monitoring data and device details of the environmental and barometric sensors. At the same time, you can configure the uplink sending period, threshold and other information of each monitoring parameter.
- To start with, click the SENSOR PROBE tab to display the connected sensor.
Figure 1: Environmental and Barometric sensor- Click the down arrow to expand the details of the temperature and humidity sensor (RAK1901) and the barometric sensor (RAK1902).
Figure 1: Sensor details- (RAK1901) Temperature
- (RAK1901) Humidity
- (RAK1902) Temperature
- (RAK1902) Pressure: Barometric pressure value
- Device details
Figure 1: Sensor detailsFor this example, fetch the data of the Wind speed and set the parameters by then choosing the Wind speed feature.
- Configure the periodic uplink data sending, thresholds, and other relevant information for the sensor.
Figure 1: Set the sensor parameters- Sensor data: Information provided by the sensor.
- FETCH DATA: Retrieve the latest sensor data.
- Send uplink if value changes: If the sensor data changes, send uplink data.
- Sensor interval(s): The payload sending interval in seconds. It determines how often the sensor sends uplink data to the server, with a range interval from 60~86,400 seconds.
- Send periodic uplink: Send uplink periodically according to the sensor interval.
- Lower threshold, ° C: Specifies the minimum acceptable temperature value.
- Send uplink if below threshold: Send uplink data if the value is below the lower threshold.
- Upper threshold, ° C: Specifies the maximum acceptable temperature value.
- Send uplink if above threshold: Send uplink data if the value is higher than the upper threshold.
- Threshold, ° C: Range of acceptable values.
- Send uplink if between threshold: Send uplink data if the value is within the threshold range.
Click the downward arrow in the Humidity (Sensor 2), Temperature (Sensor 3), and Pressure (Sensor 4) tab bar to set the periodic uplink sending and thresholds of the remaining parameters.
After completing the modifications, a message Commands in queue will appear at the bottom of the interface. Click APPLY to send the parameter update commands.
When the message All commands applied successfully. appears on the interface, it indicates that the parameter update commands have been successfully sent.
Figure 1: Apply commands- REMOVE SENSOR PROBE: Detach the sensor.
