Maintenance and Firmware Upgrade
Download IO.Box and connect Bridge IO device to IO.Box. Then, from the main menu of IO.Box, go to the System tab to view the Bridge IO device information, power output controls, and firmware update options.
System Reset & Firmware Upgrade
Figure 1: System reset & firmware upgradeFirmware Update
- Download the latest firmware of the RAK2461.
- Click Firmware Upgrade and select the firmware file.
- Confirm the firmware information, then click Upgrade and wait for the procedure to finish.
Figure 1: Confirm the firmware information
Figure 1: Upgrading procedure
Figure 1: Successful upgradeReboot
- Simply press the Reboot button.
Figure 1: Reboot button- After clicking OK, the device will reboot and disconnect from the IO.Box application.
Factory Reset
- To restore the device to factory settings, press the Reset to Factory button.
Figure 1: Reset button- After clicking OK, the device will restore to factory settings.
Device Version Information
Figure 1: Device version information- Hardware Version: Displays the specific version of the device’s hardware.
- Firmware Version: Displays the device's firmware version.
- Device EUI: Displays the unique identifier assigned by the manufacturer.
- Device Model: Displays the specific model name or number of the device.
- Serial Number: Displays the device’s serial number.
- Device Type: Indicates the category or classification of the device, defining its interface types and functionalities. For detailed specifications, refer to the device’s model information.
- Frequency Band: The device’s frequency band.
Power Output
Figure 1: Power output- DC Vout Output: Toggle to enable or disable the Vout power output. When enabled, Vout passes through the same voltage as the Vin input.
- DC 12V Output: Toggle to enable or disable the 12V_Out power output. When enabled, it provides a 12 V / 0.5 A power output.
- DC 5V Output: Toggle to enable or disable the 5V_Out power output. When enabled, it provides a 5 V / 0.5 A power output.
