RAK2560 WisNode Sensor Hub Payload Decoder
Sensor Hub LoRaWAN Payload and NB IoT JSON Format
Sensor Probe
The RAK1901, RAK1902, RAK1904, and RAK1906 all incorporate multiple sensors integrated into a single sensor IC.
| WisBlock Module | Sensor IC | Sensor Type | Sensor Data Values |
| RAK1901 | SHTC3 | Temperature and Humidity | Temperature (-40° C to +125° C) Humidity (0 to 100% RH) |
| RAK1902 | KPS22HB | Temperature and Barometric Pressure | Temperature (-40° C to +85° C) Pressure (260 to 1260 hPa) |
| RAK1904 | LIS3DH | 3-Axis Acceleration | 3-Axis (XYZ) |
| RAK1906 | BME680 | Environmental | Temperature (-40° C to 85° C) Humidity (0 to 100% RH) Pressure (300 to 1100 hPa) Gas (0 to 500 IAQ) |
The four (4) WisBlock modules will have four (4) sensor types as follows:
| Sensor | Type | Data Size |
| Temperature | 0x67 | 2 |
| Humidity | 0x68 | 1 |
| Pressure | 0x66 | 2 |
| 3-axis | 0x71 | 6 |
RAK Sensor Type is 1 Byte, which uses the IPSO Object ID minus 3200 in the below conversion rule:
RAK_DATA_TYPE = IPSO_OBJECT_ID - 3200
| Type | IPSO ID | RAK Data Type (Decimal) | RAK Data Type (Hex) | Data Size | Data Resolution per Bit | Sensor Hub NB IoT Json |
| Temperature sensor | 3303 | 103 | 0x67 | 2 | 0.1° C Signed MSB | "Temperature" |
| Humidity sensor | 3304 | 104 | 0x68 | 1 | 0.1% Unsigned | "Humidity" |
| Accelerometer (3-Axis) | 3313 | 113 | 0x71 | 6 | 0.001 G Signed MSB per axis | "Accelerometer" |
| Barometer (Pressure) | 3315 | 115 | 0x73 | 2 | 0.1 hPa Unsigned MSB | "Barometer" |
Sensor Hub
| Type | RAK Data Type (Decimal) | RAK Data Type (Hex) | Data Size | Data Resolution per Bit | Sensor Hub NB IoT Json |
| HUB Voltage | 187 | 0xBB | 2 | 0.01 V MAX: 655.32 | "HUB_Voltage" |
| X-Axis Gravity | 27 | 0x1B | 2 | 1 mg 2000 ~ -2000 | "X-gravity" |
| Y-Axis Gravity | 28 | 0x1C | 2 | 1 mg 2000 ~ -2000 | "Y-gravity" |
| Z-Axis Gravity | 29 | 0x1D | 2 | 1 mg 2000 ~ -2000 | "Z-gravity" |
RAKwireless Standardized Payload Decoder
On GitHub, you can find a standard version of the decoder that works with all solutions.
Sensor Probe IO
| Type | IPSO ID | RAK Data Type (Decimal) | RAK Data Type (HEX) | Data Size | Data Resolution per Bit | Sensor Hub NB IoT Json |
| Digital Input | 3200 | 0 | 0x00 | 1 | (ON/OFF) | "Digital-Input" |
| Digital Output | 3201 | 1 | 0x01 | 1 | (ON / OFF) | "Digital-Output" |
| Analog Input | 3202 | 2 | 0x02 | 2 | 0.01mA(V), Min: 0.0, MAX: 655.35 | "Analog-Input" |
| Nitrogen | 3216 | 16 | 0x10 | 2 | 1mg/Kg, Min: 0, MAX: 65535 | "NITROGEN" |
| Phosphorus | 3217 | 17 | 0x11 | 2 | 1mg/Kg, Min: 0, MAX: 65535 | "PHOSPHORUS" |
| Potassium | 3218 | 18 | 0x12 | 2 | 1mg/Kg, Min: 0, MAX: 65535 | "POTASSIUM" |
| Salinity | 3219 | 19 | 0x13 | 2 | 1mg/L, Min: 0, MAX: 65535 | "SALINITY" |
| Dissolved oxygen (DO) | 3220 | 20 | 0x14 | 2 | 0.01mg/L, Min: 0.0, MAX: 655.35 | "Dissolved-Oxygen" |
| Oxidation Reduction Potential (ORP) | 3221 | 21 | 0x15 | 2 | 0.1mv sign | "ORP" |
| Chemical Oxygen Demand (COD) | 3222 | 22 | 0x16 | 2 | 1mg/L, Min: 0, MAX: 65535 | "COD" |
| Turbidity | 3223 | 23 | 0x17 | 2 | 1NTU, Min: 0, MAX: 65535 | "Turbidity" |
| NO3 | 3224 | 24 | 0x18 | 2 | 0.1ppm, Min: 0.0, MAX: 6553.5 | "NO3" |
| NH4+ | 3225 | 25 | 0x19 | 2 | 0.01ppm, Min: 0.0, MAX: 655.35 | "NH4PULS" |
| Biochemical oxygen demand (BOD) | 3226 | 26 | 0x1A | 2 | 1mg/L, Min: 0, MAX: 65535 | "BOD" |
| Illuminance | 3301 | 101 | 0x65 | 4 | 1Lux, Min: 0, MAX:4294967295 | "Illuminance" |
| Presence | 3302 | 102 | 0x66 | 1 | (Yes/No) | "Presence" |
| Temperature | 3303 | 103 | 0x67 | 2 | 0.1°C, Min: -3276.8, MAX:3276.7 | "Temperature" |
| Humidity Sensor Soil Humidity SCD30 humidity | 3304 | 104 | 0x68 | 1 | 1%RH Unsigned | "Humidity" |
| Air Quality Index | 3305 | 105 | 0x69 | 2 | 1 Unsigned MSB 1, Min: 0, MAX: 65535 | "GAS" |
| Humidity | 3312 | 112 | 0x70 | 2 | 0.1%, Min: 0.0, MAX:100.0 | "High-Precise-Humidity" |
| Pressure | 3315 | 115 | 0x73 | 2 | 0.1hPa, Min: 0.0, MAX: 6553.5 | "Barometer" |
| Battery Level (Battery Voltage) | 3316 | 116 | 0x74 | 2 | 0.01V, Min: 0.0, MAX: 655.35 | "BatteryValue" |
| Precipitation | 3317 | 117 | 0x77 | 2 | 1mm/h, Min: 0, MAX: 65535 | "Precipitation" |
| Percentage | 3320 | 120 | 0x78 | 1 | 1%, Min: 0, Max:100 | "Percentage" |
| CO2 concentration | 3325 | 125 | 0x7D | 2 | 1ppm, Min: 0, MAX: 65535 | "CO2" |
| EC | 3392 | 192 | 0xC0 | 2 | 0.001mS/cm, Min: 0.0, Max:65.535 | "EC" |
| EC | 3327 | 127 | 0x7F | 4 | 0.001uS/cm, Min: 0.0, Max:4294967.295 | "High-Precision-EC" |
| Distance | 3330 | 130 | 0x82 | 4 | 0.001 m | "Distance" |
| RAK Device Serial Number | 126 | 0x7E | 3 | 3 bytes Serial number in MSB "SSN" | "Serial Number" | |
| VOC | 3338 | 138 | 0x8A | 2 | 1, Min: 0, MAX: 65535 | "VOC" |
| Wind Speed | 3346 | 146 | 0x92 | 2 | 0.01m/s, Min: 0.0, MAX: 655.35 | "GustWindSpeed" |
| Strikes | 3347 | 147 | 0x93 | 2 | 1, Min: 0, MAX: 65535 | "Strikes" |
| Capacity | 3384 | 184 | 0xB8 | 1 | 1%RH, Min: 0, MAX: 100 | "Capacity" |
| DC Current | 3385 | 185 | 0xB9 | 2 | 0.01A, Min: -327.68, MAX: 327.67 | "DC_Current" |
| DC Voltage | 3386 | 186 | 0xBA | 2 | 0.01V, Min: 0.0, MAX: 655.35 | "DC_Voltage" |
| Moisture | 3388 | 188 | 0xBC | 2 | 0.1%, Min:0.0, Max:100.0 | "Moisture" |
| Wind Speed | 3390 | 190 | 0xBE | 2 | 0.01m/s, Min: 0.0, MAX: 655.35 | "Wind-Speed" |
| Wind Direction (0o - North) | 3391 | 191 | 0xBF | 2 | 1o , in 0~359o | "Wind-Direction" |
| pH | 3393 | 193 | 0xC1 | 2 | 0.01, Min: 0.0, MAX: 655.35 | "High_Precision_PH" |
| Normal Precision pH | 3394 | 194 | 0xC2 | 2 | 0.1 pH | "PH" |
| Pyranometer | 3395 | 195 | 0xC3 | 2 | 1 unsigned MSB (W/m2) | "PYRANOMETER" |
| PM10 | 3427 | 227 | 0xE3 | 2 | 1ug/m3, Min: 0, MAX: 65535 | "PM10" |
| PM2.5 | 3428 | 228 | 0xE4 | 2 | 1ug/m3, Min: 0, MAX: 65535 | "PM2.5" |
| Noise | 3433 | 233 | 0xE9 | 2 | 0.1dB, Min: 0.0, MAX: 6553.5 | "Noise" |
| Orientation | 3429 | 229 | 0xE5 | 2 | 0.1°, Min: -90.0, MAX: 90.0 | "ORIENTATION" |
| Raw Data in Binary (Modbus ADU) | 3441 | 241 | 0xF1 | / | TLV format binary raw data for Modbus, RS232 or other specific data format "BinaryRaw" (NBIOT Json Mode) | |
| Binary2byte | 3443 | 243 | 0xF3 | 2 | Modbus content | "Raw2byte" |
| Binary4byte | 3424 | 224 | 0xF4 | 4 | Modbus content | "Raw4byte" |
| Generic Float (IEEE754) | 3445 | 245 | 0xF5 | 4 | "Float" | |
| Generic Integer (32bit) | 3446 | 246 | 0xF6 | 4 | Min: -2147483648, Max: 2147483647 | "Int32" |
| Generic Unsigned Integer (32bit) | 3447 | 247 | 0xF7 | 4 | Min: 0, Max: 4294967295 | "uInt32" |
| Raw Data in Binary | 3448 | 248 | 0xF8 | / | TLV format binary raw data "BinaryTLV" (NBIOT Json Mode) | "BinaryTLV" |
RK900-09 Weather Station Sample Payload Decoder
Click to view the Payload Decoder code
var decoded = {};
var str = bin2HexStr(bytes);
var i = 0;
while (i < str.length) {
var channelId = parseShort(str.slice(i, i + 4), 16);
var value = parseShort(str.slice(i + 4, i + 8), 16);
i += 8;
switch (channelId) {
case 0x01BE:
decoded.wind_speed = value / 100;
break;
case 0x02BF:
decoded.wind_direction = value;
break;
case 0x0367:
decoded.temperature = value / 10.0;
break;
case 0x0470:
decoded.humidity = value / 10.0;
break;
case 0x0573:
decoded.pressure = value / 10.0;
break;
default:
break;
try {
decoded.lorawan_rssi = (port && port.metadata && port.metadata.rssi) || 0;
decoded.lorawan_snr = (port && port.metadata && port.metadata.snr) || 0;
decoded.lorawan_datarate = (port && port.metadata && port.metadata.data_rate) || '';
} catch (e) {
console.log('Failed to read gateway metadata');
return decoded;
function bin2HexStr(bytesArr) {
var str = '';
for (var i = 0; i < bytesArr.length; i++) {
var tmp = (bytesArr[i] & 0xff).toString(16);
if (tmp.length == 1) {
tmp = '0' + tmp;
str += tmp;
return str;
// convert string to short integer
function parseShort(str, base) {
var n = parseInt(str, base);
return (n << 16) >> 16;
// convert string to triple bytes integer
function parseTriple(str, base) {
return (n << 8) >> 8;
| Sensor Data Unit | ID (Channel) | Type | Data |
| Serial Number | 1 Byte | 1 Byte | 3 Bytes |
| Wind Speed | 1 Byte | 1 Byte | 2 Bytes |
| Wind Direction | 1 Byte | 1 Byte | 2 Bytes |
| Temperature | 1 Byte | 1 Byte | 2 Bytes |
| Humidity | 1 Byte | 1 Byte | 2 Bytes |
| Air Pressure | 1 Byte | 1 Byte | 2 Bytes |
With the defined data, here's how to interpret the payload received data:
RK900-09 Weather Station Data Sample
Payload (hex) received data: 007E006F07 01BE0000 02BF0000 036700C6 047002E7 05732719
| Serial Number | 00 | 7e | 006f07 |
| Wind Speed | 01 | be | 0000 |
| Wind Direction | 02 | bf | 0000 |
| Temperature | 03 | 67 | 00c6 |
| Humidity | 04 | 70 | 02e7 |
| Air Pressure | 05 | 73 | 2719 |
Convert the sensor data from hexadecimal to decimal:
- Serial Number:
007e - Data:
006f07
SN: 006f07
- Wind Speed:
01be - Data:
0000
0000 (hex) = 0 (dec)
0 x 0.01 (conversion factor) = 0 m/s
- Wind Direction:
02bf - Data:
0000
0 x 1 (conversion factor) = 0°
- Temperature:
0367 - Data:
00C6
00C6 (hex) = 198 (dec)
198 x 0.1 (conversion factor) = 19.8° C
- Humidity:
0470 - Data:
02E7
02E7 (hex) = 743 (dec)
743 x 0.1 (conversion factor) = 74.3%RH
- Air Pressure:
0573 - Data:
2719
2719 (hex) = 10009 (dec)
10009 x 0.1 (conversion factor) = 1000.9 hPa
RAK9154 Solar Battery Sample Payload Decoder
RAK IPSO Sensor type definition in JSON
- Filename: snsr_type_def.json
"7e": {
"name": "SSN",
"resolution" : 1,
"length": 3,
"unit": ""
"14": {
"name": "Dissolved-Oxygen",
"resolution" : 0.01,
"length": 2,
"unit": "mg/L"
"15": {
"name": "Oxidation Reduction Potential",
"resolution" : 0.1,
"length": 2,
"unit": "mV",
"sign": "-1000~+1000mv"
"67": {
"name": "Temperature",
"resolution" : 0.1,
"length": 2,
"unit": "°C"
"68": {
"name": "Humidity",
"resolution" : 1,
"length": 1,
"unit": "%"
"73": {
"name": "Barmoeter",
"resolution" : 0.1,
"length": 2,
"unit": "hPA"
"71": {
"name": "A",
"resolution" : 0.001,
"length": 6,
"unit": "G"
"be": {
"name": "Wind-Speed",
"length": 2,
"unit": "m/s"
"bf": {
"name": "Wind-Direction",
"resolution" : 1,
"length": 2,
"unit": "°"
"65": {
"name": "Illuminance",
"resolution" : 1,
"length": 4,
"unit": "lux"
"70": {
"name": "High-Precise-Humidity",
"resolution" : 0.1,
"length": 2,
"unit": "%"
"c1": {
"name": "High_Precision_pH",
"length": 2,
"unit": "pH"
"c2": {
"name": "pH",
"resolution" : 0.1,
"length": 2,
"unit": ""
"c3": {
"name": "Pyranometer",
"resolution" : 1,
"length": 2,
"unit": "W/m2"
"c0": {
"name": "EC",
"length": 2,
"unit": "mS/cm"
"7f": {
"name": "High-Precision-EC",
"length": 4,
"unit": "us/cm"
"13": {
"name": "Salt",
"resolution" : 1,
"length": 2,
"unit": "mg/L"
"b8": {
"name": "Capacity",
"resolution" : 1,
"length": 1,
"unit": "%"
"b9": {
"name": "Current",
"length": 2,
"unit": "A"
"ba": {
"name": "Voltage",
"length": 2,
"unit": "V"
"10": {
"name": "Nitrogen",
"resolution" : 1,
"length": 2,
"unit": "mg/kg"
"11": {
"name": "phosphorus",
"resolution" : 1,
"length": 2,
"unit": "mg/kg"
"12": {
"name": "potassium",
"resolution" : 1,
"length": 2,
"unit": "mg/kg"
"77": {
"name": "Dummy",
"resolution" : 1,
"length": 4,
"unit": "qq"
"7d": {
"name": "CO2",
"resolution" : 1,
"length": 2,
"unit": "ppm"
"82": {
"name": "Distance",
"length": 2,
"unit": "m"
"e5": {
"name": "ORIENTATION",
"resolution" : 0.1,
"length": 2,
"unit": "°",
"sign": "–90° to 90°"
"e9": {
"name": "Noise",
"resolution" : 0.1,
"length": 2,
"unit": "dB"
"f1": {
"name": "RS485",
"resolution" : 1,
"length": 1,
"unit": ""
"f2": {
"name": "BINARY",
"resolution" : 1,
"length": 2,
"unit": ""
"02": {
"name": "AIC",
"length": 2,
"unit": ""
"03": {
"name": "AIV",
"length": 2,
"unit": ""
Decoder in Python
import re, json
data='007e00280c15ba04f116b9000017b8641867011819f300401af30001'
pattern = re.compile('.{2}')
handle_data = re.findall(pattern, data)
snsr_id_index = 0
ssn = ''
value = ''
def twos_complement_hex(hex_str):
decimal_num = int(hex_str, 16)
twos_complement = (decimal_num + (1 << (len(hex_str) * 4))) % (1 << (len(hex_str) * 4))
return twos_complement # Return the integer value
with open('snsr_type_def.json', 'r', encoding='UTF-8') as f:
unit_dict = json.load(f)
while (snsr_id_index+1) < len(handle_data):
ipso_index = snsr_id_index+1
if handle_data[ipso_index] not in unit_dict.keys():
pass
elif (len(handle_data[ipso_index-1:]) -
(2+unit_dict[handle_data[ipso_index]]['length']) ) < 0:
pass
else:
inner_dict = unit_dict[handle_data[ipso_index]]
name = inner_dict['name']
resolution = inner_dict['resolution']
unit = inner_dict['unit']
data_index = ipso_index+1
sensor_id_type = ''.join(i for i in handle_data[data_index-2:
data_index])
if name == 'RS485':
inner_dict['length'] = len(handle_data[data_index:])
hex_data = ''.join(i for i in handle_data[data_index:
data_index+inner_dict['length']])
dec_data = ''
if name == 'SSN':
dec_data = hex_data
ssn = hex_data
elif name == 'RS485':
dec_data = hex_data
elif name == 'A':
for A in range(3):
dec_data +=
'%s,'%round(twos_complement_hex(hex_data[A*4:(A+1)*4])*resolution,2)
dec_data = dec_data[0:-1]
else:
dec_data = round(twos_complement_hex(hex_data)*resolution,
len(str(resolution ))-1)
value += '%s: %s%s, ' %(name, dec_data, unit)
snsr_id_index += (1+inner_dict['length'])
snsr_id_index += 1
print(value)
| Battery Voltage | 1 Byte | 1 Byte | 2 Bytes |
| Battery Current | 1 Byte | 1 Byte | 2 Bytes |
| Battery SOC (State of charge) | 1 Byte | 1 Byte | 1 Byte |
| Battery Temperature | 1 Byte | 1 Byte | 2 Bytes |
| Battery Error | 1 Byte | 1 Byte | 2 Bytes |
| Battery FW Version | 1 Byte | 1 Byte | 2 Bytes |
RAK9154 Solar Battery Data Sample
Payload (hex) received data: 007e 00280c 15ba04f1 16b90000 17b864 18 670118 19 f30040 1af30001
| Serial Number | 00 | 7e | 00280C |
| Battery Voltage | 15 | ba | 04F1 |
| Battery Current | 16 | b9 | 0000 |
| Battery SOC | 17 | b8 | 64 |
| Battery Temperature | 18 | 67 | 0118 |
| Battery Error | 19 | f3 | 0040 |
| Battery FW Version | 1a | f3 | 0001 |
- Serial Number:
007e - Data:
00280c
SN: 00280C
- Battery Voltage:
15ba - Data:
04f1
04F1 (hex) = 1265 (dec)
1265 x 0.01 (conversion factor) = 12.65 V
- Battery Current:
16b9 - Data:
0000
0 x 0.01 (conversion factor) = 0 A
- Battery SOC:
17b8 - Data:
64
64 (hex) = 100 (dec)
100 x 0.01 (conversion factor) = 1.00 = 100%
- Battery Temperature:
1867 - Data:
0118
0118 (hex) = 280 (dec)
280 x 0.1 (conversion factor) = 28.0° C
- Battery Error:
19f3 - Data:
0040
Battery Error = no error
- Battery FW Version:
1af3 - Data:
0001
Battery FW Version = v00.01
RAK200-03 Pyranometer Sample Payload Decoder
var decoded = {};
var i = 0;
i += 8;
case 0x01C3:
decoded.pyranometer = value;
break;
default:
break;
try {
} catch (e) {
return decoded;
var str = '';
tmp = '0' + tmp;
str += tmp;
return str;
} var n = parseInt(str, base);
| Pyranometer | 1 Byte | 1 Byte | 2 Bytes |
RK200-03 Solar Pyranometer Data Sample
Payload (hex) received data: 007e 006f03 01c3 0000
| Serial Number | 00 | 7e | 006f03 |
| Pyranometer | 01 | c3 | 0000 |
- Serial Number:
007e - Data:
006f07
SN: 006f03
- Pyranometer:
01c3 - Data:
0000
0 x 1 (conversion factor) = 0 W/m2
