WisDM v1.5.2 Release Note
Added
| No. | Feature | Description | Reference |
| 1 | Search feature | When you have a growing number of locations and gateways to manage, you can now use the search feature to quickly find the one you need. You can use the search feature to filter results in the historical system log of the gateway. | WisDM User Manual > Location |
| 2 | Customized gateway list | A feature where you can customize the list columns in the gateways table, so you can see only relevant information you need right now. | WisDM User Manual > Gateway |
| 3 | Show progress in retrieving historical system logs | While retrieving historical system logs of gateways, the loading progress information is provided, so you can see the progress and be fully informed about it. | WisDM User Manual > Gateway |
