Environmental and Barometric Solution LoRaWAN Network Server
This section outlines the operational steps for connecting the device to the network server in both the LoRaWAN and LTE-M application scenarios, respectively.
Figure 1: LoRaWAN application scenarioLoRaWAN Application
Cloud Network Server Setup
The cloud network server deployment scenario involves connecting the gateway and devices to third-party cloud network servers. This server integrates visualization applications to manage real-time temperature, humidity and pressure sensor data.
- Register the Gateway
- Register an account and log in to the TTN v3 website. If you already have a TTN account, you can log in using your The Things ID credentials.
Figure 1: Configure the gateway frequencyYour gateway dashboard should look the same with Figure 7.
Figure 1: Successfully registered the gateway- Generate a Token
- To generate a key file, navigate to API keys from the Overview page of the registered gateway, then click Add API key.
Figure 1: Copy and save the API Key- Navigate back to the gateway management platform Web UI. Click on the left navigation bar to access the LoRa > Configuration tab. Complete the following settings and save them.
- Server URL:
8887 - Authentication Mode: TLS server & Client Token - Authentication
- Trust (CA Certificate): Click the link to download.
Figure 1: Select Create an application- Click + Create application to initiate the creation of a node.
Figure 1: Fill in the Application ID field- Click on the + Register end device button to add a new end device to the application.
- After completing the settings, return to the WisToolBox app, and click JOIN NETWORK to send the end device network join request.
Create Datacake Integration- In the TTN console, navigate to Integrations on the sidebar, proceed to the Webhooks section, and then click +Add webhooks to set up an integration.
Figure 1: Select the Datacake template- Generate an API key on Datacake to enable webhook authentication. To get started, register a Datacake account, and then log in.
Figure 1: Datacake IoT platform main page- Navigate to the Datacake workspace. Select Members on the sidebar, switch to the API Users tab, then click the Add API User button.
Figure 1: Create the Datacake Webhook- To add a new device, select Devices in the sidebar and click the +Add Device button.
Figure 1: Add a device- Choose LoRaWAN from the options and click Next to proceed.
Figure 1: Select LoRaWAN- As the Sensor Hub is a new device, there is no pre-existing template. Create a template by clicking New Product, enter the Product Name, and click Next to proceed.
Figure 1: Registered device- Click the successfully registered device and go to the Configuration tab. Scroll down to the Payload Decoder field, then copy and save the decoder code.
Figure 1: Configuration tab
Figure 1: Decoder codeClick to view the code
function lppDecode (bytes) {
var sensor_types = {
0: { 'size': 1, 'name': 'digital_in', 'signed': false, 'divisor': 1 },
1: { 'size': 1, 'name': 'digital_out', 'signed': false, 'divisor': 1 },
2: { 'size': 2, 'name': 'analog_in', 'signed': true, 'divisor': 100 },
3: { 'size': 2, 'name': 'analog_out', 'signed': true, 'divisor': 100 },
100: { 'size': 4, 'name': 'generic', 'signed': false, 'divisor': 1 },
101: { 'size': 2, 'name': 'illuminance', 'signed': false, 'divisor': 1 },
102: { 'size': 1, 'name': 'presence', 'signed': false, 'divisor': 1 },
103: { 'size': 2, 'name': 'temperature', 'signed': true, 'divisor': 10 },
104: { 'size': 1, 'name': 'humidity', 'signed': false, 'divisor': 1 },
112: { 'size': 2, 'name': 'humidity_prec', 'signed': true, 'divisor': 10 },
113: { 'size': 6, 'name': 'accelerometer', 'signed': true, 'divisor': 1000 },
115: { 'size': 2, 'name': 'barometer', 'signed': false, 'divisor': 10 },
116: { 'size': 2, 'name': 'voltage', 'signed': false, 'divisor': 100 },
117: { 'size': 2, 'name': 'current', 'signed': false, 'divisor': 1000 },
118: { 'size': 4, 'name': 'frequency', 'signed': false, 'divisor': 1 },
120: { 'size': 1, 'name': 'percentage', 'signed': false, 'divisor': 1 },
121: { 'size': 2, 'name': 'altitude', 'signed': true, 'divisor': 1 },
125: { 'size': 2, 'name': 'concentration', 'signed': false, 'divisor': 1 },
128: { 'size': 2, 'name': 'power', 'signed': false, 'divisor': 1 },
130: { 'size': 4, 'name': 'distance', 'signed': false, 'divisor': 1000 },
131: { 'size': 4, 'name': 'energy', 'signed': false, 'divisor': 1000 },
132: { 'size': 2, 'name': 'direction', 'signed': false, 'divisor': 1 },
133: { 'size': 4, 'name': 'time', 'signed': false, 'divisor': 1 },
134: { 'size': 6, 'name': 'gyrometer', 'signed': true, 'divisor': 100 },
135: { 'size': 3, 'name': 'colour', 'signed': false, 'divisor': 1 },
136: { 'size': 9, 'name': 'gps', 'signed': true, 'divisor': [10000, 10000, 100] },
137: { 'size': 11, 'name': 'gps', 'signed': true, 'divisor': [1000000, 1000000, 100] },
138: { 'size': 2, 'name': 'voc', 'signed': false, 'divisor': 1 },
142: { 'size': 1, 'name': 'switch', 'signed': false, 'divisor': 1 },
188: { 'size': 2, 'name': 'soil_moist', 'signed': false, 'divisor': 10 },
190: { 'size': 2, 'name': 'wind_speed', 'signed': false, 'divisor': 100 },
191: { 'size': 2, 'name': 'wind_direction', 'signed': false, 'divisor': 1 },
192: { 'size': 2, 'name': 'soil_ec', 'signed': false, 'divisor': 1000 },
193: { 'size': 2, 'name': 'soil_ph_h', 'signed': false, 'divisor': 100 },
194: { 'size': 2, 'name': 'soil_ph_l', 'signed': false, 'divisor': 10 },
195: { 'size': 2, 'name': 'pyranometer', 'signed': false, 'divisor': 1 },
203: { 'size': 1, 'name': 'light', 'signed': false, 'divisor': 1 },
function arrayToDecimal(stream, is_signed, divisor) {
var value = 0;
for (var i = 0; i < stream.length; i++) {
if (stream[i] > 0xFF)
throw 'Byte value overflow!';
value = (value << 8) | stream[i];
if (is_signed) {
var edge = 1 << (stream.length) * 8; // 0x1000..
var max = (edge - 1) >> 1; // 0x0FFF.. >> 1
value = (value > max) ? value - edge : value;
value /= divisor;
return value;
var sensors = [];
var i = 0;
while (i < bytes.length) {
var s_no = bytes[i++];
var s_type = bytes[i++];
if (typeof sensor_types[s_type] == 'undefined') {
throw 'Sensor type error!: ' + s_type;
var s_value = 0;
var type = sensor_types[s_type];
switch (s_type) {
case 113: // Accelerometer
case 134: // Gyrometer
s_value = {
'x': arrayToDecimal(bytes.slice(i + 0, i + 2), type.signed, type.divisor),
'y': arrayToDecimal(bytes.slice(i + 2, i + 4), type.signed, type.divisor),
'z': arrayToDecimal(bytes.slice(i + 4, i + 6), type.signed, type.divisor)
break;
case 136: // GPS Location
s_value = {
'latitude': arrayToDecimal(bytes.slice(i + 0, i + 3), type.signed, type.divisor[0]),
'longitude': arrayToDecimal(bytes.slice(i + 3, i + 6), type.signed, type.divisor[1]),
'altitude': arrayToDecimal(bytes.slice(i + 6, i + 9), type.signed, type.divisor[2])
break;
case 137: // Precise GPS Location
s_value = {
'latitude': arrayToDecimal(bytes.slice(i + 0, i + 4), type.signed, type.divisor[0]),
'longitude': arrayToDecimal(bytes.slice(i + 4, i + 8), type.signed, type.divisor[1]),
'altitude': arrayToDecimal(bytes.slice(i + 8, i + 11), type.signed, type.divisor[2])
sensors.push({
'channel': s_no,
'type': s_type,
'name': 'location',
'value': "(" + s_value.latitude + "," + s_value.longitude + ")"
sensors.push({
'channel': s_no,
'type': s_type,
'name': 'altitude',
'value': s_value.altitude
break;
case 135: // Colour
s_value = {
'r': arrayToDecimal(bytes.slice(i + 0, i + 1), type.signed, type.divisor),
'g': arrayToDecimal(bytes.slice(i + 1, i + 2), type.signed, type.divisor),
'b': arrayToDecimal(bytes.slice(i + 2, i + 3), type.signed, type.divisor)
break;
default: // All the rest
s_value = arrayToDecimal(bytes.slice(i, i + type.size), type.signed, type.divisor);
break;
sensors.push({
'channel': s_no,
'type': s_type,
'name': type.name,
'value': s_value
i += type.size;
return sensors;
// For TTN, Helium and Datacake
function Decoder(bytes, fport) {
// bytes = input.bytes;
// fPort = input.fPort;
// flat output (like original decoder):
var response = {};
lppDecode(bytes, 1).forEach(function (field) {
response[field['name'] + '_' + field['channel']] = field['value'];
// Enable only for Datacake
response['LORA_RSSI'] = (!!normalizedPayload.gateways && !!normalizedPayload.gateways[0] && normalizedPayload.gateways[0].rssi) || 0;
response['LORA_SNR'] = (!!normalizedPayload.gateways && !!normalizedPayload.gateways[0] && normalizedPayload.gateways[0].snr) || 0;
response['LORA_DATARATE'] = normalizedPayload.data_rate;
return response;
- Complete the fields for the configuration shown in Figure 36.
Figure 1: Configuration fields- Add the field type under the Type input box. Select Integer for RAK1901, and Float for RAK1902.
- Enter an appropriate name in the Name field.
- When an uplink is received, refresh the page and the CURRENT VALUE field will be updated.
- Leave everything else as default and click Add Field to complete the setup.
- Repeat the above steps to add the Humidity/Temperature (RAK1902)/ Pressure fields, as shown is Figure 38 when completed.
Figure 1: Successfully added fields- To create a dashboard, click the edit mode switch (
) on the Dashboard tab of the device on Datacake.
- In the Title field under the Basics tab, name the widget. As an example, the temperature widget of RAK1901 is used, so name it as RAK1901_Temperature.
Figure 1: Name the widget- Under the Data tab, pull down the Field tab bar, select Temperature (for RAK1901), and set the unit to ° C.
Figure 1: Set the unit- Under the Gauge tab, select the gauge type and color, set the range of values for the widget, and then click Save.
Figure 1: Set the widget type- To add another widget, ensure the edit mode switch is ON, then repeat from Step 2-6 for the Humidity, Temperature (RAK1902), and Pressure fields.
Figure 1: Added Widget- When you finish adding the widgets, turn off the edit mode switch to save the edits.
Figure 1: Save the editsBuilt-In Network Server Setup
- Log in to ThingsBoard. If you don't have an account, create one before proceeding.
Figure 1: ThingsBoard homepage- Navigate through Integration center > Integrations > Data converters in the left navigation tree to create a data converter for the uplink.
Figure 1: Create a data converter- Click the Add Data Converter icon (
) and choose the Create new converter option.
Figure 1: Create a data converter- Enter the name of the decoder in the Name field (for example, Uplink decoder), leave the Type field as Uplink, and select the JavaScript option.
Figure 1: Add the decoder code- Edit the decoder code by copying the following code into the edit box, then click Add to include the uplink decoder.
/** Decoder **/
//decode payload to string
var bytes = atob(data).split('').map(function (c) {
return c.charCodeAt(0);
var values = {};
let i = 0;
var value;
switch (channelId) {
case 0x0167:
value = (bytes[i + 2] << 8) | bytes[i + 3];
values.temperature1 = value / 10.0;
i += 4;
break;
case 0x0268:
value = bytes[i + 2];
values.humidity = value;
i += 3;
break;
case 0x0367:
values.temperature2 = value / 10.0;
i += 4;
break;
case 0x0473:
values.pressure = value / 10.0;
i += 4;
break;
default:
break;
var deviceName = ' rak19012';
var result = {
deviceName: deviceName,
attributes: {
temperature1: values.temperature1,
humidity: values.humidity,
temperature2: values.temperature2,
pressure: values.pressure,
/** Helper functions **/
function decodeToString (payload) {
return String.fromCharCode.apply (String, payload);
return result;
In the above code, the marked word rak19012 is the device ID, i.e., the device name. This parameter must be consistent with the device name added in Configure the Gateway. In this example, it is rak19012.
- Navigate to the Integration Center > Integrations menu and click the Add Integration icon (
) to add the MQTT integration.
Figure 1: Add the MQTT integration- Enter the name of the integration (for example, MQTT Integration) in the Name field and select MQTT in the Type drop-down menu. Click Next to continue.
Figure 1: Fill in the integration name- In the Uplink data converter options, click Select existing to choose the previously created decoder (Uplink Decoder), then click Next.
Figure 1: Select the created decoder- In the Downlink data converter interface, no configuration is necessary and just click Skip to bypass this setup.
- Configure connection options. Host is the MQTT broker address used for messages. The Host of the external MQTT broker used in this example is
broker.hivemq.com. You can choose to use other brokers with a different Host. - Enter the address
Figure 1: Configure the connection optionsapplication/{{application_name}}/device/{{device_EUI}}/join
application/{{application_name}}/device/{{device_EUI}}/rx
application/{{application_name}}/device/{{device_EUI}}/tx
application/{{application_name}}/device/{{device_EUI}}/ack
application/{{application_name}}/device/{{device_EUI}}/status
- Modify the parameter values corresponding to the topics based on the actual application created and the device used. After configuring the details, click the Add button to save and complete the settings.
Figure 1: Configure and add the subscription topics- After clicking Add, the settings are saved and completed.
Figure 1: Configuration completedConfigure the Gateway
Figure 1: WisGate OS Web Management Platform- After successfully logging in, navigate to the LoRa® menu in the left navigation tree and set the Work mode of the gateway to the Built-in network server.
Figure 1: Applications tab- Configure the following information: Application name, Application description, and Application Type.
Figure 1: Configure the Application key- Unified Application key: Choose this option if all devices will use the same application key. Once selected, a field for the application key appears, where you can manually type in an application key or click the Autogenerate button to generate one.
- After enabling the Auto Add Device option, configure the Application EUI option. The value needs to be consistent with the node value. Once you have verified the application EUI and key, the device will be added automatically to the application.
Figure 1: End devices tab- Click the Add end device button. In the End device information interface, fill in the following information:
- Activation Mode: Select the activation mode of the device, OTAA or ABP.
- Class: Select Class A for device’s operating mode.
- LoRaWAN MAC Version: The protocol version (v1.0.3) of the end device.
Figure 1: Add the device to the device list- In the Adding end devices interface, enter the device EUI in the End Device EUI (Main) field and select the Add to End Devices list button. Then click Add end devices to complete adding the end device. Then click Add end devices to complete adding the end device.
- After selecting the device in the End devices list at the bottom left, click Add end devices to complete adding the end device.
Figure 1: End device createdConnect the Sensor Hub to the Built-In Network Server
Once completed, the device will join the network. As shown in Figure 70, the end device SensorHub has successfully connected to the gateway's built-in server.
Figure 1: Connected to Gateway Built-In ServerConfigure the MQTT Integration
Go to the LoRa® > Configuration > Integration Interface Parameters section.
Toggle the Enable Integration Interface option and select Generic MQTT as the Integration mode.
broker.hivemq.comthen click Save changes. -
Figure 1: Automatically created decoder device- Click the device and go to the Attributes tab, where you will see the node data.
Figure 1: Node data- To visualize the data, simply select the values you wish to display, then click the Show on widget button.
Figure 1: Data visualization- On the next page, select the required widget from the Current bundle dropdown menu. In this example, choose Outdoor Environment, and select the appropriate visualization chart for Humidity by clicking the slide icon (
Figure 1: Choose an appropriate visualization chart-
After selecting the widget, click Add to dashboard to proceed.
The Add widget to dashboard window will appear. By default, there is no dashboard in the profile, so you need to select Create new dashboard and enter a name for the dashboard in the new dashboard title field. Additionally, in this dashboard, the user can add more widgets for the device.
Figure 1: Enter the dashboard name- After setting the dashboard name, click the Add button to add more widgets. Alternatively, check the Open dashboard option to automatically open the created dashboard after adding the widget.
Figure 1: Dashboard createdIf the Open dashboard option is not selected, you can still easily view the added widgets via Dashboard groups > All > [Group Name].
- To set the appropriate name and unit of Humidity, click on Edit mode (
) > Edit widget (
) and complete the steps below:
- Select the humidity unit in the Value column, %RH in this example;
- Click the Apply button to apply the settings;
- Click the exit icon (
) in the upper right corner, and click on Save (
Figure 1: Edit Dashboard
Figure 1: Set appropriate name and unit of HumidityThingsBoard visualization dashboard editor supports adjusting the size and shape of widgets by dragging the edges of the widgets in the Edit mode.
- If the above settings are correct, the final Dashboard visualization widget should look like Figure 110.
Figure 1: Visualization widget settings completed- After repeating the above steps to complete the visualization of the remaining parameters, the results are as follows:
Figure 1: Visualization completed- When adding the visualizations of the remaining parameters, in the Add widget to dashboard step, you should click Select existing dashboard to select the previously created dashboard SensorHub_RAK1901&2.
- The visualization parameter values of the RAK1902 barometric pressure sensor (Temperature2 and Barometer) will be automatically rounded due to the different types of widgets selected for the data. If needed, please set the decimals in the icon edit mode.
NB-IoT/LTE CAT-M1 Application
In the Network Server and Visualization Configuration section, the server has been set as a public MQTT broker: broker.hivemq.com. You can also choose other brokers or servers, such as AWS IoT Core (optional), according to the actual usage scenario.
Figure 1: NB-IoT/LTE CAT-M1 Application ScenarioVisualize Data Through Datacake
Add Sensor Hub to Datacake
Figure 1: Add the end device, SensorHub- Select the API option and click Next to proceed.
Figure 1: Keep the serial number- Select the preferred subscription plan, then click Add 1 device. For this example, choose Free.
Figure 1: Copy the serial number- Scroll down to the API Configuration option and copy the Serial number. Save it locally for later use.
Figure 1: Configure the external MQTT Broker- Fill in the relevant information based on the actual server used, then click Test Connection to verify whether Datacake can successfully connect to the MQTT Broker.
Figure 1: Configure the relevant parameters- After successfully adding the MQTT server, click on +Add Uplink Decoder to add a decoder.
Figure 1: Configure the relevant parameters- A new window will appear, and fill in the fields according to your project.
return payload
.match(/.{2}/g)
.map(function (hex) {
return parseInt (hex, 16);
.map(function ( charCode ) {
return String.fromCharCode(charCode);
.join("");
var decoded = [];
var data = payloadStr;
var bytes = Array.prototype.map.call(data, function (char) {
return char.charCodeAt(0);
console.log(bytes);
var values = {};
var i = 0;
var value;
case 0x0167:
i += 4;
break;
case 0x0268:
i += 3;
break;
case 0x0367:
i += 4;
break;
case 0x0473:
values.barmoeter = value / 10.0;
i += 4;
break;
default:
break;
var data = {
barmoeter: values.barmoeter,
for (var key in data) {
if (data.hasOwnProperty(key)) {
decoded.push ({
device: "53f86e9f-24e6-4dd3-bc8b-07c4b7e6feb8" ,
field: key,
value: data[key],
return decoded;
In the above code, make sure that the parameter serial_number (device: 53f86e9f-24e6-4dd3-bc8b-07c4b7e6feb8) matches the serial number saved locally earlier.
- In the Fields option, click + Add Field to show the monitoring values of the devices. Each device can create a certain number of fields, also known as a data point.
Figure 1: Add Field- Set the necessary parameters of the Field. For Fields with multiple data points, add them one by one. Once done, click Add Field.
Figure 1: Added sensor monitoring values- Follow Steps 11-12 to add other monitoring parameters.
Figure 1: Add other monitoring parameters individuallyDue to the different precision of the RAK1901 and RAK1902 sensors when creating fields, select Integer for RAK1901, and Float for RAK1902.
Create a Dashboard to Visualize Data
On the device details page, navigate to the Dashboard tab, then toggle on the edit mode switch (
Click on the + Add Widget button to add a widget for visualizing data.
Figure 1: Open the edit mode- Choose what type of widgets you want to display. For this example, select Value to visualize temperature monitoring values.
Figure 1: Add widgets for visualizing data- Click on the Data tab. Choose the field for visualization from the Field options (for example, Temperature) and set the unit of the field, which is ° C.
Figure 1: Select the visualization data field- After configuring the widget, click Save. You should now see the successfully created widget on the Dashboard interface.
Figure 1: Successfully created solar radiation widget- To add more parameter widgets, click the +Add Widget button again with the edit mode toggle switch ON (
), then repeat Steps 4-6.
Figure 1: Close edit mode to save the settings- Once done with the dashboard configuration, turn OFF (
) the edit mode switch to save the settings.
Figure 1: Visualization completed1
