WisDM v1.4.1 Release Note
Added
| No. | Feature | Description | Reference |
| 1 | Multi-add gateway | Can add multiple unassigned gateways to a location and also, to the location from a csv file | WisDM User Manual > Adding a Gateway to a Location |
| 2 | Bypass FOTA | Additional field feature that shows the state of the FOTA feature - enabled/disabled - for any connected gateway (An option is added to remotely change the state of the FOTA.) | WisDM User Manual > System settings |
Changed
| 1 | UI improvements for a better experience | - | - |
| 2 | Customer support | Improving the assistance and support request logic. The users can now attach files and images to the support request within the WisDM system. An option for temporary access to the user’s Locations is added. | WisDM User Manual > RAK Support |
| 3 | Renaming the terms: - Master/Slave to Center/Extender - Packet Logger to Packet Capture | - | - |
Fixed
| Daily Build No. / Bug No. | Description |
| - | General bug fixing |
