RAK7268CV2-V System Management
Access Settings in the Web UI to manage essential gateway configurations, perform firmware upgrades, synchronize time, and manage backups.
Firmware Upgrade
Keep your gateway up to date with the latest firmware to gain new features, bug fixes, and performance improvements.
You can upgrade the gateway manually by downloading the firmware package and uploading it through Settings > Firmware.
For detailed Web UI instructions, refer to the WisGateOS 2 User Manual > Firmware.
General Settings
Configure essential gateway settings, including the device name, system logs, time synchronization, and reboot controls.
- Log Rotation: Automatically manage log file size and retention.
Automatic Log Management
This guide explains how to configure log rotation rules to prevent storage overflow and maintain long-term log availability.
Guide Link: How to Configure Automatic Log Management on RAK LoRaWAN® Gateways - Remote Log Server: Forwards system logs to an external server for centralized monitoring.
Configure External Log Server
Learn how to forward gateway system logs to an external syslog server.
This guide explains how to enable remote log collection for centralized monitoring, long-term storage, and advanced debugging workflows.
Guide Link: How to Configure an External Log Server for RAK Gateways - Time Sync: Keeps the system clock accurate with public or custom NTP servers.
- Reboot: Restarts the gateway with one click when required.
Backup and Restore
Easily back up, restore, or reset your configuration.
- Backup / Restore: Creates encrypted or plain backups of your configuration and restore them when needed. You can secure backups with a password for added protection.
Encrypted and Plain Backup Options
This guide explains how to create plain or encrypted configuration backups in WisGateOS 2. You will also learn how to restore backups safely and use password protection to secure sensitive settings.
Guide Link: How to Safeguard Your Gateway With Encrypted and Plain Backup Options in WisGateOS 2 - Reset: Resets the gateway to its default state if needed for recovery or redeployment.
File Browser
The File Browser allows you to access the gateway’s file system directly through the web UI, making it easy to view or download files. It provides access to system log files, extension installation files, and other stored files, which are typically stored on the SD card.
