WisDM v1.11.3: Metrics Unit Conversion Release Notes
- New Feature: Metrics unit conversion for time- and storage-related metrics
- Improved gateway limit visibility and email notifications at 90% capacity
- More accurate memory usage calculation for gateways running WisGateOS 1.2.13 or later
- Improved organization creation and billing workflows
- Additional usability improvements and fixes for gateway management, Extensions, and dashboard ordering
New Features
| 1 | Metrics Unit Conversion | WisDM now supports unit conversion for time- and storage-related metrics. Users can select their preferred display units:
Metric values are automatically recalculated and displayed based on the selected unit, making dashboard data easier to interpret across different monitoring scenarios. |
Improvements
| 1 | Improved Memory Usage Calculation | For gateways running WisGateOS 1.2.13 or later, WisDM has updated the memory usage calculation to provide a more accurate representation of actual memory utilization. The updated calculation is consistently applied across:
| 2 | Gateway Limit Visibility and Notifications | WisDM improves gateway allocation monitoring by allowing organization administrators to track usage against their organization's gateway limit. These improvements include:
These changes help administrators monitor gateway capacity and plan subscription adjustments when needed. |
| 3 | Organization Creation and Billing | WisDM introduces several improvements to organization creation and billing workflows, including:
These updates help streamline organization setup and billing configuration while reducing input errors. |
| 4 | Extensions Page | Improved the empty-state layout on the Extensions page for a clearer and more consistent user experience. |
Fixes
| No. | Issue | Description |
| 1 | Payment Terms Selection | Fixed an issue affecting Payment Terms selection in Billing Information. |
| 2 | Gateway Unassignment Redirect | Fixed an incorrect page redirect after unassigning a gateway. |
| 3 | Dashboard Ordering | Fixed an issue affecting dashboard ordering after copying a Project. |
Why Upgrade to v1.11.3?
- Convert time- and storage-related metrics into preferred display units for easier monitoring.
- Monitor gateway allocation against organization limits and receive notifications when usage reaches 90% capacity.
- Access more accurate memory usage calculations across gateway lists, Performance pages, CSV exports, and email notifications.
- Experience smoother organization setup and billing configuration with improved validation and field interactions.
- Benefit from usability improvements and fixes to Payment Terms selection, gateway unassignment redirects, Extensions, and dashboard ordering.
FAQs
How can I change the units used to display metrics in WisDM?
You can select your preferred display units for time and storage metrics, such as showing time in hours instead of seconds or storage in GB instead of bytes. WisDM automatically recalculates the values to match the selected units.
How can I monitor my organization's gateway limit?
Organization administrators can check allocated gateway usage against the organization's maximum gateway limit. When usage reaches 90% of the limit, WisDM sends an email notification so administrators can review capacity and plan any necessary adjustments.
Why might gateway memory usage values differ from previous reports?
Gateways running WisGateOS 1.2.13 or later use an updated memory calculation that more accurately represents actual memory utilization. The updated values are reflected in gateway lists, Performance pages, CSV exports, and email notifications.
