System Settings
This tab shows the general information about your device. You can choose the power output and perform system resets and updates.
Figure 1: System tabDevice Version Information
- Hardware Version: Specific hardware version of the device.
- Firmware Version: The currently installed firmware version.
- Device EUI: Unique identifier assigned by the manufacturer.
- Device Model: The specific model name or number of the device.
- Serial Number: Serial number of the device.
- Device Type: The device category, defining its supported interface types and functionalities. For detailed specifications, refer to the model information.
- Frequency Band: Operating frequency band of the device.
Power Output
- DC Vout Output: Toggle to enable or disable the Vout power output. When enabled, Vout passes through the same voltage as the Vin input.
- DC 5V Output: Toggle to enable or disable the 5 V power output for connected peripherals or devices that require a 5 V supply.
- DC 12V Output: Toggle to enable or disable the 12V_Out power output, which provides a 12 V / 0.5 A power output when enabled.
If the device does not have its own power supply, you must enable the appropriate power output here to provide power to the device.
System Reset & Firmware Upgrade
- Reboot: Click Reboot to restart the device. This is typically used to apply configuration changes or recover from temporary system issues.
- Reset to Factory: Click Reset to Factory to restore the device to its factory default settings. This action will erase all user configurations and cannot be undone.
- Firmware Upgrade: Click Firmware Upgrade to upload and install a new firmware version on the device. This is used to apply feature updates, bug fixes, or performance improvements.
