Check Your Deployment
Check Your Deployment is the pre-deployment workspace of WisMesh Pad. It helps you evaluate the radio environment and plan node placement before installing or expanding a Meshtastic network.
| Feature | Description | When to Use |
| Spectrum Scan | Scans local RF conditions on Meshtastic channels and evaluates channel quality based on detected noise levels. It provides channel comparison results to help you select a cleaner operating channel. | Use before deployment or when changing channels to identify potential interference and improve network reliability. |
| Site Planner | Simulates expected radio coverage based on the planned transmitter location, radio parameters, and environment settings, helping you determine suitable node locations before installation. | Use during the planning stage to estimate coverage and optimize node placement. |
