Add an Extension
- To install an extension, access the gateway by referring to the Access the Gateway section, using the RAK7240V2 WisGate Edge Prime documentation as a reference example.
- Once logged in successfully, navigate to the Extensions tab (
- You can click on the WisGate logo (
) to expand the menu on the left and see the full names of the tabs.
- By default, no extensions are installed.
- Proceed with the installation by clicking on the Add new extension button or the install one now link. This will open the Add new extension window.
- In the window, either drag and drop the extension file into the Drop your Extension file here area, or click the choose file link in the form to browse and select the extension file manually.
The extension files are in .ipk format, specifically created for the WisGateOS 2 and WisGate Edge hardware platform. A general .ipk file for OpenWrt cannot be installed.
- Once the extension file is selected, click Add extension to begin the installation. The process may take a few moments to complete.
- When the installation is complete, the WisGateOS will automatically reboot, and you will need to log in again.
- After logging in, navigate back to the Extensions tab. The newly installed extension should now be listed and visible in the interface.
- To install additional extensions, use the Add new extension button or manage existing ones by clicking the Launch button next to the desired extension.
