Operation and Maintenance
The Operation and Maintenance extension is operation and maintenance tool that features scheduled device reboot and monitoring of the 4G network status. If the 4G network connection is lost, it automatically restarts the cellular module to recover the connection.
This extension is only compatible with WisGateOS 2 2.2.x and later.
Install the Operation and Maintenance Extension
Configure the Operation and Maintenance Extension
- To access the Operation and Maintenance extension, click Launch.
Figure 1: Launch the Operation and Maintenance Extension- On the Configuration page, configure cellular network monitoring and set a reboot schedule.
- Cellular Network Monitoring: When enabled, the gateway will monitor the cellular connection status every 2 minutes. If the 4G network connection is lost, it will automatically restart the cellular module to restore the connection.
- Schedule Reboot: When enabled, the gateway will reboot periodically based on the configured schedule.
- Gateway Current Time: The system time must be synced for scheduled tasks to function properly. To change the current time, go to User Preferences and set the time.
- Reboot Time: The time when the gateway will reboot.
- Repeat Time: The reboot cycle interval.
- To save the changes, click Save changes.
