WisDM Gateway LoRaWAN Network
In WisDM, each gateway inherits its LoRaWAN® configuration from the Location it is assigned to. This means LoRaWAN® network parameters cannot be configured directly on an individual gateway.
In this section, you can:
- View the current LoRaWAN® network configuration applied to the gateway
- Manually synchronize pending changes by clicking Resend, if updates from the Location have not yet been applied
When a gateway operates in Basics™ Station mode with Use individual client keys enabled, the certificate, client key, and token fields become configurable. This allows per-gateway authentication even within the same Location.
